Question about Maax Pearl By CS60wh Pearl CS60 in White
How do i reset the controller on Maax pearl bathtub
Have clunking noise and then "E01" shows up on controller screen
3 Suggested Answers
  • 659 Answers
SOURCE: Hydro maax wirlpool bathtub Model # J6061 Pump will start
Can either be a bad motor or if the motor has a capacitor, it needs to be replaced. I would call a service professional to come out.
Posted on Apr 06, 2009
  • 10865 Answers
SOURCE: Maax bathtub Palace model Error code C01 jets don't turn on.
first of all check the circuit breakers to be sure one or both aren't kicked. be sure to turn the breaker all the way off and then fully on as a tripped breaker is in a halfway off position. if that doesnt fix your problem remove the access panel to the mechanical space in your tub. there are generally one or two reset buttons in there which can also kick off and need to be reset.
Posted on Sep 01, 2009
Maax c02 error
[PDF]WHIRLPOOL BATHTUB OWNER'S MANUAL BAIN ... - Maax
www.maax.com/~/media/.../10050073_2009-04-17.p...
Translate this page Never operate the whirlpool system if there is less than 2". (5 cm) of water over the highest whirlpool jet (except for the back jets) or if the bathtub is empty.
Maax co2 error Bathtubs & Whirlpools Questions & Answers ...
www.fixya.com > Forum > Tags > co2 error > Bathtubs & Whirlpools
Maax bathtubs & whirlpools co2 error related questions and answers. Ask your Maaxquestions. Get free help from bathtub and whirlpool experts.
Maax bathtub c02 and e06 error - Fixya
www.fixya.com/support/t19321104-maax_bathtub_c02_e06_error
Aug 10, 2013 - maax bathtub c02 and e06 error - Maax URBAN 6032 HYDROFEEL AEROFEEL ... Jan 18, 2013 ' Maax Adagio True Whirlpool System.
How to Troubleshoot a Maax Tub ' eHow
Jan 05, 2016 | Maax Home
Pearl Trillium diverter and hand held shower
The faucets on your Pearl tub do not come from Pearl. They were supplied by the local plumber who installed the tub.
Go to your local plumbing store and match up what you have.
Rod
US Parts Center
Jan 04, 2014 | Maax Pearl By TRILLIUMbla Pearl Trillium...
MAAX Bathtub 101056-004-007 Owners Manual
Has water got near or on the connections to the panel? Look for any signs of water below it or mould on the floor etc.
Dec 14, 2013 | Maax Home
The pump surges where's the impeller
if your pump is surging then you do not have enough water in the bathtub or you have a jet that is blowing air into the suction fitting. this happens a lot when a jet faces the suction and the air control is wide open. the suction pulls in too much air and causes the pump cavitation (surging). Try pointing the jet opposite the suction cover upwards and see if that doesn't solve the problem.
Feb 16, 2011 | Maax Pearl By CS60wh Pearl CS60 in White
Sep 01, 2009 | Maax PALACE DROP-IN BATHTUB - 100082-000-B...
MAXX code E01, jets don't work
well first of all i have to assume that this tub is equipped with jet's on the floor and lights,if not then there's no reason for it those buttons to light up, now if it is equipped with these features and your getting a error code all this means is that this tub need to Re Configured to run this type of system,this is something a tech needs to look at because you wouldn't be getting error codes if the tub was configured wrong the reason your getting error codes is because something isn't plugged in correctly at the control box and the computer detected a fault.
Justin 503-547-3483
Mar 13, 2009 | Maax Calla 6042 Bathtub - 101058-000
Broken back massage jet unable to purchase locally
Hi robrezza,
Here's the number the Pearl/maax Plant.
For maintenance, installation or general technical queries about your MAAX products, we encourage you to contact us at: Tel.: 1-888-957-7816 option # 2 Fax: 1-800-201-8308 (418) 387-9086
Have your tub model when you call. They usually are pretty helpful. Sometimes it goes to voice mail for the tech person but they call back after a bit
Please rate this response and Good Luck, Phil
Jan 18, 2009 | Whirlpool Pearl Ballade True Bathtub with...
I have a Maax Calla tub that the led is flashing E06 and it has been flashing for three days.
What does this control look like? Can you email us a photo of the control?
usually that error code is a water level problem.
Jan 10, 2009 | Maax Calla 6042 Bathtub - 101058-000
Maax Pearl By  CS60wh Pearl CS60 in White Logo
90 people viewed this question
Top Maax Home Experts
Mike
James Feragola
James Feragola
Level 1 Expert
Tim Whalen
Are you a Maax Home Expert? Answer questions, earn points and help others
