Question about GE JSP46 Electric Kitchen Range
What is the required amps for a JSp46 range
I have a 40 amp breaker and am installing a GE JSP46 convection electric range. What is the required amps needed for this appliance?
If the range you have is just like a regular 4 burner & oven all you will need is a30amp breaker
Posted on Jan 03, 2009
Can I use the existing 40 amp double pole breaker?
Rule of live by: Each unit must have its own breaker. Cooktop needs 30 amps and a double oven needs 40 amps. Never combine the unit as the amps flow if too high can cause the wires to melt. I hope this helps. Be safe!
Sep 13, 2012 | Thermador Ovens
I have a GE JSP46 and the burners work but the key pad and the oven are not coming on please help
You will need to replace the control board on the unit. This model is famous for the control going out on it.
Nov 22, 2011 | GE JSP46 Electric Kitchen Range
Broiler doesnt' turn on, does a viking range need a separate designated electric electrical breaker?
The documentation for this range calls for a 240 volt, 40 amp, dedicated circuit for the electrical supply on 30 & 36" ranges. 48 & 60" ranges require a 240 volt, 50 amp supply.
Mar 08, 2010 | Viking VDSC365-6B Dual Fuel (Electric and...
3 Answers How to get rid of flashing lock door on JGBP35
There is a button on the left upper corner by the door when you open oven. Hold the button down and press the clear button on the panel till the display clears itself. Just like that you have a functional oven.
Jun 25, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Electric service requirements
Number 6 wire and a 40-50 amp breaker. Anything smaller will overheat and become a fire hazard, especially at 139 feet.
May 11, 2009 | Whirlpool Kitchen Ranges
Circuit breaker 30 or 40 amp
Electric range normally takes 50 amp breaker. Are you installing new line for this range? Normal practice is seu aluminum cable #6/ 3 conductor
Apr 16, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
GE Profile elec range JSP40 Locked door flashing can't use oven
Replace the oven temperature sensor to solve the F3 problem.
You may need to replace the oven lock micro switch to solve the locking problem.
Change the sensor first. Then try the oven.
Mar 04, 2009 | GE JSP46 Electric Kitchen Range
Installing ge profile double oven not convection in new build trying to find out electrical requirements ( size breaker 50,60amp ?)
You must use a three-wire, single-phase A.C.
208Y/120 Volt or 240/120 Volt, 60 hertz
electrical system. If you connect to aluminum
wiring, properly installed connectors approved
for use with aluminum wiring must be used.
That means that you ned a double 40 amp breaker.
Good Luck
Jan 18, 2009 | GE Profile JT952 Electric Double Oven
What amp breaker is required for the GE JSP46 convection electric range?
40 or 50 double pole.
Either one will work.
Most people use a 50.
Jan 03, 2009 | GE JSP46 Electric Kitchen Range
Amperage Requirement
an electric stove requires a 40 amp double breaker in the fuse panel. good luck. Also read the manual to make sure.
Dec 16, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Open Questions:
GE JSP46 Electric Kitchen Range Logo
165 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
