Question about LG Televison & Video
LG tv flickers really badly for 10 minutes but not on all channels. It works OK with DVD. Any ideas please before I go buy a new TV. We do use a Free sat box.
    Top Expert:
  • LG Master
  • 14,553 Answers
You have really ruled OUT THE TV. Set is not smart enough to only have the issue on certain channels---consider if using a box for signal routing it to one of the rear audio/video inputs especially if the tv sets now getting signal via a coax/cable fitting---the box if used would be suspect number two.
Posted on Oct 30, 2012
jerryg50
  • 1667 Answers
SOURCE: screen flickers
This an be the power supply, or there is a component on one of the processor boards that is starting to fail.
The only way the tech can service this is to have the set opened, and wait for the fault to occure. When the set is doing the fault, he has to check the power supply distribution outputs, and at the same time use a digital scope to follow the video path through the various stages. This is a long an complicated process to find the exact fault.
Once the tech knows which board is giving the fault, he can then change the complete circuit board to fix the set.
I think what is happening is that when the set is coming in, they are not spending the adequate amount of time on it to find the fault. This type of problem is very time consuming to find.
What you can do is make a video of the fault, write the video to a DVD, and bring the set back with the DVD to show them the fault.
If you have a friend with an HDTV you can bring your DVD player to his place and try it for a while on his TV set. This would verify the player for sure.
I doubt you have an AC power problem. You can easily prove the AC power by putting a lamp on it.
When I have had this type of fault, I ended up finding the defective board in the TV and replacing it. One time, it was the customer's DVD player that was causing a fault.
Next time you buy a TV set I would suggest to you to pay a little more and stick with a major brand of TV set. They have better factory support, and are of better quality.
Jerry G.
Posted on Apr 27, 2008
  • 3 Answers
SOURCE: LG 42LC7D TV does not want to chg channels after 5 min of use
There are some inductors that are out of spec. LG's original SB said to replace some of these with a jumper, but it only lasted a couple months.
You need to have the Total Main Assy replaced.
Posted on Jul 30, 2008
lightnbaby
  • 36 Answers
SOURCE: No Picture on LG 50PC3D
No power?
Unplug power cord- safety first!
open backcover
check powersupply- top center right is p.s.
top left side of powersupply you'll see 5 capacitor 3300uF 10V.
see any pop up on top? replace it All with same rate or 16v is O.K.
do not use temperature rate 75c. Use 105C.
if you know how to solder. you could save $300 at least!
Posted on Mar 15, 2009
anoopsnoop
  • 43 Answers
SOURCE: lg flat screen tv flickers when cold
Hey,
This is nothing to be afraid of. In LCD screens, it takes some time for the liquid crystal to heat up. Thats why manufacturers warn you not to change screen settings immediately after switching your TV on.
Hope this helps
Thanks
Posted on Apr 16, 2009
nostechjb
  • 28 Answers
SOURCE: LG LCD flickers and turns itself off
I'm guessing here.. most probably its the ccfl tubes..
Posted on Nov 15, 2009
My lg plasma really flickers but it does this randomly. Sometimes it will happen all the time other days not at all. I have tried sorting the cables and unplugged etc. it is 10 years old but just wanted...
I suspect its a component (Capacitor) aging and eventually would need to be replaced. How do you have it connected? Is there a cable box or Direct TV receiver that you use to display TV Channels? If 10 years old does it even have an HDMI input? Should be very happy you got 10 years of life out of this Plasma. My thoughts is that it would take more to repair this than to purchase a new LCD or LCD/LED thinner TV. Plasma does have the best color but the LCD and LED TV's are much lighter/take less energy and are much brighter. Good luck.
Dec 10, 2014 | LG 42PX4DR 42 in. Plasma TV
LG hd tv..only on the hd channels does the screen flicker black every 10 seconds or so...why?
A way to test the HD on your TV is to hook it up to another HD source. (HD DVD player, Xbox, ect.) If it does fine, then you know It's not your tv. It sounds like you have a bad cable box or cable service. I'd contact your cable company.
Dec 09, 2013 | LG Televison & Video
Ps3/trinitron no work
buy a new tv or ur dvd is srachted
May 04, 2013 | Video Game Consoles & Games
Plasma tv takes time to start then picture flickers really badly then picture returns as normaal for a few hours then goes black but still has sound i turn off tv for a number of hours & repeat the...
This tv seem to have two problems.The problems that the tv take a long time the tv to turn on,the tv power supply board have dying capacitors most likely.That the board where the power a/c cord plug into it.The picture flickers badly this problems is harder to determine because this causes by two backlight buffers boards X,Z buffers boards could be either one it is dying.This tv should get an estamate by a shop or shops and repair it by them,bcause the tv must have to be doing replacing x munbers capacitors components to the tv power supply board and alot more work to trouble shoot and to detrmine which of the buffers boards it is the causes of to the picture screen to be badly flickers and replacing it.
Jun 10, 2011 | LG 42PX8DC Plasma TV
Lcd26805hd manual FOR A ACOUSTIC SOLUTIONS LCD TV
My acoustic solutions lcd26805hd tv has started flickering really badly every time I switch it on. The flickering goes on for about 30 minutes before it calms down. I have checked all the connections at the back of the tv - all ok. This happens whether I watch cable or a dvd.
Jan 10, 2010 | Televison & Video
36 inch tube tv - Screen flickers
my problem is don't sound in my mobile LG CE 0168 please help me.
Aug 17, 2009 | Toshiba Televison & Video
TV/DVD Combo will not switch back to live TV when DVD is ejected.
I had the same problem with the same unit when I first bought it a few months ago.
First up remove the DVD. If the TV stations do not appear within a couple of seconds press the "TV" button (top, second from left) on your remote control.
Let me know if this doesn't work.
Apr 28, 2009 | LG 26LG30 26 in. LCD TV
TV switches off after 3 minutes
You have a bad Fan,if fan stops turning on while tv is trying to come on lamp will not light and tv turns off.
Nov 24, 2008 | LG RU-52SZ51D 52" Rear Projection...
LG DVD/HDD recorder RH2T80 hard disc problem
I've got the new firmware. Email me @ damian.hocking@gmail.com
It'a 7MB file, just copy it and play & you should be ok.
Jan 12, 2008 | Televison & Video
Televison & Video Logo
370 people viewed this question
Computer Repairing
Computer Repairing
