Question about Sterling Heating & Cooling
Honeywell smartvalve flashing 6 times, pilot lit but burners won't light
  • 499 Answers
Smatvalves of certain year were bad, check the module and see if its a bad one recalled, if not see the codes youmention for the brand its on.
Posted on Oct 31, 2012
protek480
  • 1723 Answers
SOURCE: pilot light is lit, burner will not come on
The thermocouple must be in the flame of the pilot and producing a signal to the gas valve. Also check thermostat
Posted on Jul 18, 2009
luker711
  • 91 Answers
SOURCE: Pilot is lit, but burner will not come on. I jumped TH/PP to TH t
More than likely the tempature control is defective, since you effectively bypassed that connection. I found a manual for your unit which shows different types of ignition. I'm not even sure if the millivolt system is covered in this manual. Here's the sight
http://shop.solardirect.com/pdf/pool-heaters/gas-pool-heaters/jandy-lite2manual.pdf
Posted on Jul 14, 2009
  • 53 Answers
SOURCE: i have a vulcan freeloader 230 gas hot water
Clean the pilot assembly if has any orange at the tip. If its burning clean and blue, then its most likely the thermocouple. Safer to get a gasfitter to check it out.
  • 80 Answers
SOURCE: WE can get the pilot light lit but it will not stay on
You will need to check the pressure regulator for the gas.
It sounds like the gas pressure is to low to keep the pilot lit.
John
Posted on Oct 01, 2009
  • 33 Answers
SOURCE: pilot stays lit, but burners underneathe do not light up or burn.
Check pump is working, if so could be stuck flow switch or gas valve fault get unit serviced
Posted on Jan 17, 2010
My Honeywell smartvalve stop opening the gas valve, inducer motor started, glow and pilot happen, just no fire...I replaced said smartvalve and upon installation, the inducer motor wouldnt run, no glo
Double check the wiring connections, maybe you have the pilot valve and the main valve wiring reversed. I had a call one time where the homeowner installed the gas valve backwards, so no flow and of course and the wiring on the three terminals was reversed.
The inducer should start whether or not the gas valve is wired wrong, unless it is wired in parallel with the pilot valve.
Jan 21, 2015 | Honeywell Heating & Cooling
My Honeywell smartvalve stop opening the gas valve, inducer motor started, glow and pilot happen, just no fire...I replaced said smartvalve and upon installation, the inducer motor wouldnt run, no glow or...
Smartvalves are tricky and a certain sequence must happen. Without going into this in depth, try this:
Install new smartvalve
Set thermostat to the off position
Kill the power to the unit
Restore power to the unit
Turn the heat on with the thermostat
In this order!
Aug 29, 2017 | Honeywell Heating & Cooling
New Reliance gas water heater won't stay lit
There is a sensor that shuts off the gas to the burner if a flame isn't detected within a few seconds. It will usually look like a tube that extends into flame of the burner. It may be defective or it may just need to be repositioned so more of it is directly in the flame.
Mar 17, 2014 | Reliance Water Heaters
I changed the thermo coupler and the pilot light does stay lit but the burners won't light
If you are referring to a gas fireplace:
  • Make sure the pilot knob is turned from "pilot" to "ON" or it will never run.
  • If the pilot knob is "ON", and the pilot is lit, but the burner won't light, it could be a bad Thermopile. The thermopile is the other safety mechanism in the pilot assembly that controls the burner.
Dec 19, 2012 | Heating & Cooling
Pilot light won't stay on
What is the model number of the unit?
Nov 27, 2012 | Tappan Kitchen Ranges
Burner won't light, pilot is burning just fine.
Once you get the pilot to light and stay lit did yall move the burner knob to the ON position? Is the temp knob all the way up?
Nov 27, 2011 | Procom Heating & Cooling
What should ther honeywell relay read in ohms on a r8222u 1006
did you check power to the gas valve? Pilot lit? Or electronic pilot on? Need more info on boiler.
Nov 05, 2011 | Honeywell Programmable Thermostat Heater
When i turn on oven all i smell is gas i cleaned with a wire brush still nothing. also is the pilot light always have to be on and can you see it when oven is off
Most gas ovens that aren't electronic ignition usually have a pilot light.
Usually one in the oven area and one for each burner. (Sometimes shared between two burners.)
These pilot lights must lit at all times...otherwise it won't light up and you'll smell gas.
Usually the pilot light is in the very back of the oven and can be seen with the broiler drawer opened.
There is a small set screw located at the pilot light assembly in the oven and also at every burner.
This allows you to adjust pilot light up or down, thereby letting you set pilot light flame to a level that doesn't get blown out by a draft...or you can turn it off completely.
If you use that set screw to turn off the pilot light gas, you'd need to strike a match to light the oven or burners everytime you needed them.
Jul 17, 2011 | Ovens
Heating & Cooling Logo
236 people viewed this question
Top Sterling Heating & Cooling Experts
Paul Carew
bobalix
deton8 von Splosion
Are you a Sterling Heating and Cooling Expert? Answer questions, earn points and help others
