Question about Pioneer DEH-P75BT CD Player
Hi, the front panel opens but no cd comes out! It seems to switch itself off but as it should if i take the face plate off the mechanism retracts as normal!
3 Suggested Answers
cvance1226
SOURCE: DEH-P9600MP front flip half opens and switches system off.
there is a ribbon cable that connects to the main board that needs to be replaced the best thing to do is to have the radio sent off since the is tedious sodering involved unless you know how to repair these thing its pretty easy is to good of a head unit to go to waste the part cost about 33.00 including shipping go to pioneers web site and get the 800 number
Posted on Jun 06, 2009
SOURCE: Face plate won't open far enough to insert a CD
clarion vrx925vd. display screen don't display and the tv screen don't open.- solve this
Posted on Dec 05, 2009
Ge 11-2120 cd stuck behind cd changer
GE 11-2120 CD Stuck. Unplug from power supply, detach speaker wires, detach antennae wires. eject any cassette tapes, remove any CD's you can reach. Then, hold the unit upside down, front panel facing you. agitate to let the CD fall down. With care, roll unit so that front faces downward briefly, then back to the upside down position, facing you. With care, roll it clockwise so that the top is upward, all the while keeping the front panel facing you. Now agitate lightly again, to seat the loose CD in one of the five openings in the revolving tray. set the unit on a table, plug it in to an outlet, open the CD mechanism, hit "skip" on the remote control until CD is visible. remove it.
Mar 07, 2014 | Bosch Audi A4 1.8l Engine Motor Turbo 02...
Dual CD770 (Same as XDMR7700) face stuck open (down)
Change the Flex cable that connects from main chassis to the front face plate. This is a common problem with Dual drop down face plates, since the flexible wires break and lose connection.
Mar 06, 2013 | Dual XDMR-7700 CD Player
Hi. I have a blaunpunkt CD34 stereo in my car and it seems to be locked into one radio station as no buttons work accept the volume. It will allow me to play a cd but I can only adjust the volume on this...
is your radio come with remote control? you can confirm other function with remote control, if still working, then most likely the face plate connector connection is loose, you have to dismantle the radio out from car, and then open out the side screw secure the face plate to radio body, Unplug the face plate out from body and re assemble back to test.
Aug 20, 2011 | Blaupunkt Car Audio & Video
Player will not play a loaded CD and No CD message comes up Also CD drawer opens and shuts on it`s own !!!
the tray opening by itself could be a faulty limit switch on the tray mechanism
the switch tells the system if the tray has reached the open or closed position.
if it closes then opens itself then this is the most likely
check that first
could be closing then opening without actually loading due to the switch
you will need to open it up to find the switches
usually at the bottom front were the tray goes in
darren
May 28, 2011 | NAD C542 CD Player
There is no display on the faceplate. The faceplate is stuck in the CD eject position. If I remove the faceplate the mechanism rotates to the position where the controls would be visible but when I attach...
I would try cleaning the connectors on the face plate with an pencil eraser and on the unit itself with a very fine sand paper. And make sure you get rid of any dust after cleaning before putting the face plate back on.
Please leave me a good feedback.
Thanks
Jan 06, 2011 | Kenwood KDC-8021 CD Player
Missing face plate
What part is missing? Is it just the faceplate, or the gear mechanism as well?
I have one of these that the ribbon cable is bad and can't seem to find a replacement. I am debating just buying a new stereo. If i do, I could sell you the faceplate. email me at rad73082 (at) yahoo
Sep 12, 2009 | Dual XDMR-7700 CD Player
Braun Pulsonic Razor - Pop up trimmer will not retract entirely
I ran into this problem several months ago. I just shook it and forced it until it retracted and never thought anything of it. The trimmer recently broke (still functioned but extended beyond its normal point) and I took it apart. I realized that there were a few broken parts inside (possibly because of my earlier experience). So I removed the few parts and now it still extends to far, but otherwise functions ok if I'm careful.
I would recommend taking yours apart and seeing if you can find any parts floating around which may be causing it to not retract all the way. It may be broken beyond complete repair, but you may be able to get a little more use out of it.
If nothing else, you can order a new casing for it from here
Here are the instructions for taking it apart:
The shaver itself is easy to take apart. The part on the bottom(opposite from the shaver mechanism) pops off with just a slight bit ofprying. Be careful not to break the pins though. Once you have thatoff, the narrow sides pop off pretty easily. Then you can remove the 4screws opening up the interior.
Be careful at this pointbecause there are a lot of parts that may fall out. (Perhaps take apicture as soon as you open it so you know where everything was whenyou opened it). At this point you can try your hand at fixing it (minehad 3 parts broken and loose inside), or you can simply switch it withthe new casing (Which i'm going to do when I get it). Good Luck!
Jan 25, 2009 | Braun Activator 8595 Electric Shaver
CD drawer stuck, then won't close
1. Most of the player drawer fixed over the chasis for a rigid support
2. try to remove the drawer safely without damagind the chasis and drive mechanism
3. there might be some shaft jam.
4. Look for the thread. how does the player drawer moves in and out
5. there may be some sensors to sense the door close/open. if it is jammed then open/close function cannot be done. why because this problem occurs
6. unwear the mechanism read the mechanism moving technique. see which has got jammed.
7. if you feel too risky then
8.contact service centre... all the best
Dec 21, 2007 | NAD L40 CD Player
Face plate will not close, retract into dash,radio plays!
Get your Shifter shortened, it will give you faster more controlled shifts, and keep your knuckles out of the dash.
Nov 18, 2007 | Kenwood KDC-MP628 CD Player
Kenwood KDC 7024
Some flip face stereos use a tiny micro switch to tell the onboard computer when the face is down or up and sometimes it uses the same switch for both positions sensing. It could be this switch is not working properly (dirty contacts, broken, bad wire, mis-aligned, etc.) and that is causing the problem. Good luck.
Feb 12, 2007 | Kenwood KDC-7024 CD Player
Pioneer DEH-P75BT CD Player Logo
22 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
