Question about Whirlpool Whirpool 3.5cu ft Top Load Washer w/
Whirlpool washer lsq8520jq0 will not spin
Will not spin to remove water
I have a whirpool energy star washer and the door is stuck in lock position. The lights that are on are spin and door lock
If you remove the bottom panel under the door, you can see a lever or tab that will allow you to open the door. Before you do that though, there is a drain plug that is visible. Remove the plug and get ready for WATER to come out. Have towels or wet vacuum cleaner ready. There will be a filter trap that is in the drain. Clean it out too.
Nov 28, 2014 | Whirlpool Whirpool Energy Star Dishwasher...
Whirlpool trouble shooting
All Spin cycles regardless of load or even when unloaded and spinning?
If so suspension is broken.........Technician repair only, even the balance weights in the tub are too heavy for DIY to remove and replace springs
Sep 07, 2014 | Whirlpool WFW9550WW Duet 27" 4.4 cu. ft....
My GWH 715 ES cannot restart after hot into cold water crossover
Check for obstruction in your watervalve. It has a flow meter, that needs to spin freely. Remove the watervalve and blow through it, you should hear it spin.
Also make sure you dont have an error code showing. Hold down your reset button for 5 seconds to reset an error code and get back to your set temp.
Jan 02, 2014 | Bosch ProTankless GWH 715 ES LP Tankless...
Washer does not drain
1.), Pump may be bad. Check voltage to water pump in Spin Cycle. If you have voltage at the pump, but it does not run, replace the pump.
2.) If you have voltage to the water pump, and can hear or feel it running, cut power off, and remove the boot which is directly below the wash bin. The boot empties into the water pump. You will need long needle nose pliers or better, use water pump pliers to remove the straps holding the rubber piping to the pump and the boot. Remove debris from the boot, i.e., bobby pins, coins, socks, pens, keys, etc.
3.) If no voltage comes to the pump in spin cycle, you may need a new timer.
4.) Install a new belt on the motor pulley. You will regret not replacing the belt later.
Feb 02, 2013 | Whirlpool Whirpool 3.5cu ft Top Load...
Have a atwood m#91043 hot water heater.pilot will not stay light.Have changed temocouple.Still the same problem.
If you've replaced thermocouple with new proper one, and you have a good blue flame under it when pilot held on. Try removing the thermocouple where it connects to gas control and spray WD-40 or similar in the hole where the thermocouple was removed from, and take some steel wool (fine) and twist a piece of it small enough to fit in the hole and get to bottom where contact surface is and spin it to clean the contact surface well. Clean it out after with compressed air if possible, then re-install thermocouple and snug it up good and retry it. If that doesn't do it, your going to have to replace the gas control valve.
Mar 03, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
PowerStar. Model 45-557701 tankless water heater water wont get hot...it slowly quit getting the water hot
Hot Water Hot to Cold And back. I had that problem for 2 years. I had a very large shower head from the time I installed the tank-less hot water heater and the water temp would change from one extreme to another. Over time my shower head had stopped working as well as it did so I bought a smaller shower head and installed it and amazingly my water temperature quit changing temperature. I now turn my water to what temp I want and it stays there. It's been working correctly for 6 months now ... until yesterday and it quit working completely which is the reason I'm on here. lol
Jan 07, 2010 | Bosch & Tankless LP Hot Water Heater
Are st5 eapansion tanks hard to install can home
to remove, just spin out, (make sure boiler pressure has been relieved) tephlon tape new threads and spin in. Home owners with any mechanical skills should have no problem doing this
Oct 16, 2009 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
How to replace a magnesium rod on a John Wood electr. water tank?
You can buy these at any good hardware store- two types- Aluminium and manganese- if you replace and have a odor from water remove and replace with other. Really easy to do. Turn off water pressure to tank . Drain pressure at lowest tap in house. Put hose on drain spiggot of tank and drain off 1-2 gallons .Turn off electrical to tank. Unscrew old with socket- yes socket - do not use a pipe wrench.You will need a power bar Or good solid ratchet to remove and reinstall. Apply a pipe dope or teflon tape to new and srew in place- wrap tape counter clockwise or it will spin off as you turn in place and it will leak. Do not drain tank completely - you require this weight to keep tank from spinning as you remove and reinstall. After tightening slowly put pressure back on system - never shock pipes etc.Just as you do not slam your brakes- don't slam your pipes,Turn power back on after checking for leaks -tighten as required. Double check spiggot after removing hose as dirt can sometime cause a slow leak- monitor all areas for at least 3-5 mins and then check again at end of week. Also know that the lifespan of a tank should max at 15 yrs after that - replace or accept the flood when it happens. Good luck at poat me if you need me. Allen
Nov 26, 2008 | Water Heaters
Whirlpool Whirpool 3.5cu ft Top Load Washer w/ Logo
Top Whirlpool Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
jdthefixer
Mike
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
