Question about Philips Cineos HTS9800W System
Lg tv hts9800w
I have a LG TV Model 60PK550N I have problems getting the sound to my home theatre..
    Master:
  • 444 Answers
What have you tried? Is there any sound at all?
Posted on Oct 29, 2012
2 Suggested Answers
  • 910 Answers
SOURCE: My Philips HTS3051B/F7 A will not play sound
The TV will not output sound through the HDMI Cable to your Home Theatre.
You need to connect the Audio Out from your TV (f it has one) to one of the Audio Ins on your Home Theatre.
You then need to change your TVs setting to the Audio Output instead of the TVs Speakers and then using the SOURCE Button on your Home Theatre Remote select the Audio In you've used.
If you can advise the Model No for your LG TV I can confirm what if any Audio Output it has and give you more details as to what type of cable you'll need to use.
Posted on Jul 15, 2011
Hi, I am having trouble hooking up my new LG home theatre system with my Rogers cable. I connected the home theatre system to the TV with an HDMI cable. The sound works with watching DVDs on TV and...
To listen to Tv program sound through your home theater system you will have to connect a pair of RCA to RCA cables (Red and White pair ) from the audio out socket of the TV ( some times three sockets Yellow/Red/White labeled Monitor out. Ignore the yellow as it is video out ) to the Aux or CBL/Sat input of the LG system. Then to listen to the sound through your LG HT system switch the Input selector of the LG to Aux or CBL/SAT. Will work for sure.
Mar 08, 2011 | Audio Players & Recorders
Purchased LG's LHB335 home theatre 5 days ago to enhance my LG 42LBX TV. Problem with home theatre sound as the audio cuts out for a couple of minutes every 15-20 minute intervals. Problem is intermittant...
i bought mine in january 2011 and just started having the same problem. i have to turn the head unit off and back on again to get sound back. any fixes for this yet?
Dec 06, 2010 | LG LHB335 Theater System
Installing a LG Network Blu-ray Disc/DVD Home
YOU NEED TO CONNECT OPTICAL CABLE (NOT INCLUDED) TO OPTICAL1 CONNECTION ON YOUR HB405 AND OPTICAL OUT OF YOUR TV. IF YOU ALREADY HAVE DONE THAT TRY PRESSING SIMPLINK BUTTON ON YOUR TV REMOTE NAD CHANGE THE SPEAKER OUTPOUT FROM TV TO HT(HOME THEATER).
Jun 19, 2010 | LG Televison & Video
No sound through home theatre with blu ray connected
Make sure that your receiver says optical 1 or 2 on the front display.
Nov 21, 2009 | LG BD370 BLU RAY PLAYER
LG dvd player connected to 5.1 home theatre
Dont now your sytem but check Home theatre sytem must be switch to 5.1 display and not dvd display. if stil no sound check in setup off dvd for soundsetting like PCM, RAW , 5.1etc and select each one till you get desired sound.
Presume your conections from dvd to hometheater is conected 5.1 cables or 1 digital cable and not stereo(2cables)
Jan 05, 2009 | LG RH177 DVD Recorder/HDD Recorder
Sound goes off
You probably have too much power running to your power strip that you probably have your xbox, playstation, tv and home theatre system plugged into, try using seperate wall outlets for your tv and home theatre system
Dec 20, 2008 | LG LHT854 Theater System
No sound though home theater when watching tv
There is an orange button on the remote, half way down in the middle. I belive it has orange lettering and says something like "TV-?" press that, and the sound should start to come through your speaker system. You can then use the original remote that came with your TV and turn the sound off on the TV to use just the theatre system. I noticed that if you use the TV speakers in conjunction with the theatre system, that it echo's.
Nov 23, 2008 | LG LHT854 Theater System
Mini Home Theatre - FB162 - HELP!!
If I am not mistaken, you would have to connect the yellow video from home theatre to your yellow video on the TV, doesn't sound like your TV has the Component video capability/
Sep 28, 2008 | LG 42LC2D 42 in. LCD HDTV
How to redirect the sound of my new LG 52" HDTV LCD to my LG home theatre?
Flemflam-   There is a couple of options here. If you are using a DirecTV Receiver or a box from the cable company then you want to run the Audio out lines to your Audio/Surround Sound Receiver. If you are running cable directly into the TV then you want to use the Audio Out Plugs on the TV. In some cases there is no Audio out but there is a Headphones out. In this case you can run a Mini-Plug to Composite Audio cable to the receiver.    You can also Call 1-800-GeekSquad and they will dispatch an Home Theater Installer to resolve your problem! They are great for Turn Key Solutions!
Jul 11, 2008 | Insignia LCDTV26 26 in. Television
There sould be audio outputs on the back of it, and the manual should clearly show how to set up a home theatre with an external sound system and all.
I don't know what kind of sound system you have, but I think it might be best to connect your video source (typically DVD player) to your sound system, as it usually can be done better that way. No need to introduce another link in the chain (your TV) that could degrade sound. Also any external tuner could (should) be connected to your sound system directly.
If you use the internal tuner in your TV to watch TV the audio out is your option. Best way to get this right is to consult the manual. They usually have some diagrams that shows a few options of how to do it.
Dec 05, 2007 | LG 42LC2D 42 in. LCD HDTV
Philips Cineos HTS9800W System Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
