Question about Electrical Supplies
Powermate pm54-2200 coleman generator missing carburetor/governor linkage parts looking for a parts breakdown so I can get the parts it needs and reassemble
Coleman portable generator model pm54-2200 horizontal shaft 5hp briggs & stratton engine. engine runs well, generator produces electricity but the throttle and governor setup is rigged with bailing wire, so the rpm is constant to whatever I set it for, it doesn't fluctuate the rpm under the current demand electrical load.
  • 195 Answers
SOURCE: Coleman Powermate 5000 no electricity, runs fine
Hello;
Take a look at your outlets. Some of these units use pretty cheap outlets and short out. You will know if it is bad when you look at it. Hope this helps.
Thanks;
Rich
RPM Northwest
Posted on Jan 23, 2009
  • 83 Answers
SOURCE: Runs great but will not produce electricity
To flash the excitor circuit on a coleman ( the generator is built by generac) you need a 12 volt battery. You quickly apply 12 volts via your 120vac recepticals. NO MORE THAN ONE OR TWO SECONDS! Then check you ac voltage. Most of the time the brushes are burnt up when voltage is low. Check the brushes first. You can access them by taking the end cap off of the generator via two to four screws. The brush holder is easy to spot, two wires leading to the front of the amature. Hope this solves your problem.
Posted on Mar 30, 2009
jan mczeal
  • 632 Answers
SOURCE: engine runs fine but no electrical power to the outlets
check field exciter..check fuses also if there are..
Posted on Jun 19, 2009
  • 57 Answers
SOURCE: Generator with Briggs & Stratton,no gas is getting in carburetor
The needle valve may be stuck which would not let gas into the carb. I don;t think rebuild kits are too expensive. Pull the carb and take it to a lawnmower repair shop and they should have the parts. Before that though pull the bowl and make sure it has gas in it. If no then remove the fuel line and make sure gas flows from it. If no then could be the fuel shutoff valve is not operating properly or junk in the gas tank is obstructing the line.
Posted on Jul 31, 2009
  • 202 Answers
SOURCE: Briggs & Stratton 135212/0129 - Homelite HL2500
the choke should be in the off position when running. YOU put the choke on to start it then when it starts u turn it off. If the choke is on the engine will die when reving
Posted on Aug 02, 2009
How do I get a powermate 8hp brigs and Stratton generator to idle. I bought it and it wouldn't start. I cleaned the carb and it started on 1st pull, now it won't idle it run wide open all the time.
You have jet clogged, or still some obstruction in the carb. Hopefully you have a good inline filter .I'd take it back apart all the Jets and seats & Chem soak or a cheap complete rebuild.
Feb 09, 2016 | Coleman Powermate 4000 Watt Generator...
My coleman 2500 powermate generater leak from top of carburater, help
The carburetor needs to be rebuilt - the float valve is stuck open.
Jul 05, 2014 | Coleman Powermate Portable Generator...
Need a wiring diagram/schematic for the power output end/recepticals for the coleman powermate 5000 model pc0545305.01 generator
Couldn't get you a wiring diagram but the contact info should get you to someone who can. The other links will get the manual and parts breakdowns.
Coleman Powermate Powermate 5000W Generator
http://www.powermate.com/contact.php
http://www.powermate.com/pdfs/2007/11/12/manual_pc0105000.pdf
http://www.powermate.com/pdfs/2007/11/12/parts_pc0105000.pdf
Oct 01, 2012 | Coleman Powermate Powermate 5000W...
I have a coleman maxa 5000 PM525202; I bought it at a garage sale (didn't run); cleaned and rebuilt carb, changed oil, etc, and now it starts great and idles great. But ther eseems to be a part of the...
Parts lists for Coleman generators are here: http://www.jackssmallengines.com/coleman_parts_lookup.cfm
More detailed information about the engine can be found by using the engine model number. Look around the fan shroud or engine block. Coleman used different engnes, however your gen may have incorporated a Tecumseh 10 hp engine. Good luck
Sep 02, 2010 | Coleman Powermate Powermate 5000W...
Unstable frequency
check your governor and linkage for build up of dirt and grime. You should be able to move the governor by hand, with some resistance from the springs. The governor arm should not rotate about the shaft protruding from the engine.
If governor seems to be in order, and engine cannot maintain RPM that it needs to (hunts), look towards the carburetor being fouled (clean out best you can, but don't soak since it is an EPA carburetor), air cleaner dirty (replace even if looks good), or loss of compression (check with compression tester, should be around 90 psi or better with engine warm).
Jun 08, 2010 | Coleman Powermate Premium Plus 6250W...
Fipped over
This is a search and find type of problem. Check all wiring, especially if the generator has a low oil cut off switch. Check the wiring to that. Also, check carburetor linkage and for any springs that may have come off. Check the linkage to the governor on the engine to make sure the linkage is not binding.
Aug 08, 2009 | Coleman Powermate Premium Plus 6250W...
I have a porter cable 5250 generator that bounces off the governo
there 2 linkages that conect that would be the problem. you have on conected to the throttle switch that runs to the govener than on that govener os another linkage hooks up to it and runs to the carborator that ajusts the flow. if you don't have both linkages than you need to order 1.
Jun 14, 2009 | Coleman Powermate Powermate 5000W...
Coleman 5000 generator will not idle up under load
Hi
You have to find the governor linkage.There is a spring adjusting by a screw to increese speed to get more power.Try to locate it.
best regards savumihai71
Feb 03, 2009 | Coleman Powermate Powermate 5000W...
ENGINE OVER SPEEDS WHILE RUNNING
This is almost surely a problem with the governor, check it like this.
Have someone with a finger on the kill switch.
Watch the governor arm while starting the engine, if it does not move almost immediately after starting the engine it is broken.
This is not a simple repair as it involves taking the crankcase apart, you'll have to contact robin/subaru to get a parts list in order to get the right governor spool and weights.
For an experienced technician this is about a 2 hour repair task.
Hope this helped,
Carl
Dec 03, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman generator OHV3000
The carburetor is probably clogged up. Mix a bottle of carburetor cleaner with the gas to see if that would help. Also check/replace the fuel filter.
Sep 10, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
307 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
