Question about Frigidaire GLTF1670A Front Load Washer
Frigidair model crtr 9300aso front load washer makes noise while spinning and does not get all of the water out of the clothes
  • 10 Answers
SOURCE: Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Posted on Dec 15, 2007
  • 125 Answers
SOURCE: frigidaire front load washer problems
most likely something is stuck in the pump. it could also be that you are not using high effiency detergent.
Posted on Jan 06, 2008
  • 25 Answers
SOURCE: load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
Posted on Feb 16, 2008
  • 1314 Answers
SOURCE: FRIGIDAIRE FRONT LOAD MODEL 417.39012891 PURCHASED 3-9-00
i tell customers to remove the drain hose from the stand pipe and vacuum the water out of the washer from the drain hose but because of the pillow this might not work in your case. Now remove the two screws on the front lower panel and pull the panel
in side you will see the drain pump if you did not have a shop vac go to the auto parts store and buy a pair of radiator hose clamps and clamp the hose line as close to the washer as possible.(but put down some towels as water always stays there) then pull the tub to pump hose by depressing the squeeze clamp(now while your at the auto parts id get a screw clamp to replace the spring clamp it makes putting the hose back on a lot easier)pull the hose off.Then pull the pump to drain hose off .Remove the two 5/16 in screws securing the pump to the washer base.Unplug the connector and remove the pump inspect the pump for foreign objects,broken or stripped impeller blades . if the impeller are stripped you will have to replace the pump then form the front of the washer take a piece of water hose with one end cut off and run it down the pump to drain end of the drain and reassemble the unit
Posted on Jun 11, 2008
SOURCE: frigidaire front load washer model LTF530DS loose drum
I have the same issue with the broken spider...in the us and they say it is $300 for labor and $360 for parts. My washer is only 3+ years old...what can I do?
Posted on Aug 07, 2008
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
Load noise and will not spin out clothes
Good Morning PJ, this is AP with Electrolux.
Thank you for submitting your question concerning your Frigidaire front load washer, ATF6000ES. Typically if your washer is making a banging noise it could mean one or two problems, but primarily the tub is off balance or your washer is not level. In this regard, since the tub is spinning it would be advisable to reach out to a local service provider to properly diagnose your washer. You can often locate a qualified tech through the manufacturer website.
Mar 04, 2014 | Frigidaire ATF6000ES Front Load Washer
My Washing Machine is not spinning all the water out of my clothes.
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Frigidaire FAFW3517KN Affinity Series...
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
We have a front loading washer Model FWTR647GH
buy a new washer... to replace the bearing u have to replace the outer tub assembly..... 500-800 dollars
Jan 28, 2010 | Frigidaire FWT647GH
Frigidare affinity model # atf6000es won't spin in
sometimes in the bottom right hand corner of the machine there is a little face plate and allows to you unclog foreign material that collect over time.
Nov 06, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
No final spin
is there stil standing water in the unit at the end??
Jan 26, 2008 | Frigidaire GLTF530DS Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
32 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
