It shut down at times
Struggle before shuuting down
  • 27,725 Answers
Check to see if there are any keys stuck/depressed.
If so, use a paperclip and fit it underneath the key and gently pry the end that is stuck.
Make sure the laptop is off before attempting this.
Observe where the boot process ends and starts over.
In most cases, this will give an indication where the problem occurs.
If the laptop reboots early on in the process, for example when it is detecting the hard drive, chances are good it is a hardware issue.
If the reboot occurs further along in the process, like when it is loading operating system files, there may be an issue with operating system software.
Test all power and data leads that attach to your hard drive SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as faulty fan lead can cause you problems
computers need all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all power and data leads make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU central processing unit make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
if your computer runs long enough scroll to bottom toolbar (bottom of screen) right click select task manager
applications you will see whats running
if you see anything you dont need running select end now and you might uninstall that specific
program if you or computer does not require it to run and
some unnecessary programs that could be running your computer over its limits causing memory dumps
also under processes see what is ticking over in the background you might have a virus again if you see something you
dont need to be and users you will see who is using your computer
you might need to add more computer ram
if you're not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always ask for a guarantee on the compatibility of the ram before making any purchase
might be getting hot
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
hope this helps
Posted on Oct 30, 2012
Shutting down power on my fridgidaire 2008 dryer that stops and lights start flashing
without make/model we have a real hard time looking for a solution
Mar 22, 2015 | Dryers
GMS90904CXA IR Blower continues to run after it
it sounds like the fan control switch is not shuutting off when it cools down look at the fan diff settingson the fan control you may be able to adjust this
Feb 03, 2010 | Goodman GMS90703BXA Heater
Cooling Fan Acting Up
in that it doesn't run like it used to hasn't started up while riding in 95 degree days and after I shut off the bike it may or may not start and sometimes starts a few minutes after I shut it down, at which time it sounds like it is struggling for a few seconds.  The blades spin freely when I spin them manually, and I can't find any troubleshooting procedures in the manual. ,Check the fuse and the temp sensor.,,,
Nov 10, 2008 | 2003 Buell Firebolt XB9R
Vizio L23 HDTV 10A
Sounds like the power supply board blew. You can purchase a new one directly from Vance Baldwin. They are the only parts supplier for Vizio. http://www.vancebaldwin.com/
It's just plug and play. remove the old circuit board and replace with the new one. Not difficult and it should solve your problem for less than $100.
Jul 18, 2008 | Vizio L32 32 in. LCD HDTV
Kepps going to sleep
your setting in the screen saver has been set to shut down go to control panel then appearances and theme select screen saver you shoul see where the computer is set you can change it
Jun 30, 2008 | Gateway FPD2275W LCD Monitor
Hp xw 6000, keeps shuuting down during initial boot up.
reseat ram if not i'd say to take 1 stick of ram at a time and start the computer with such might be a ram issue or run memtest 1.7 which can be downloaded here http://www.memtest86.com/ boot to cd once downloaded and burned to test ram
Mar 19, 2008 | HP XW6000 PC Desktop
Computers & Internet Logo
David Payne
David Payne
