Question about Craftsman Briggs & Stratton Generator, 3600 Watt 7 HP
Need a 7 hp 3600 w craftsman generator manual
Need maintenance starting help
Maunual for generator #580.32670
How do you replace the cam in the motor of a craftsman model 580327360
Nov 06, 2013 | Craftsman Briggs & Stratton Generator,...
High idle
most cheaper generators do not have a idle kick down and are made to run at 1850 rpm's the older ones run at 3600 rpm if it has a no load idle system there will be a switch
Aug 27, 2012 | Craftsman 5600 watt Generator
Can we get a maintenance manual for this generator ?
I would go to the manufacturers website and check your model number. I am a plumber and do this frequently for different pumps and other things. Most of the time you can download and print the manual. Just look for literature or manuals.
Nov 25, 2011 | Multiquip GA6HA Recoil Start 6000 Watt...
I need the maitenance manual for your sdmo 500kva generators
Regular maintenance for generator is necessary that can help prolong the service life of the generator.
Generator Maintenance Tips
Generators
Generator Set Maintenance Tips
Useful Maintenance Tips for Diesel Generator Set
Maybe You Are Interested VOLVO generator Volvo Generator Volvo Generator Set Supplier Manufacturer Factory in China
Aug 30, 2011 | Computers & Internet
I have HP Deskjet 3420 printer, which I am using with my Compaq 7500 computer (window xp). Printer was purchased by me some 7 years back. I now want to use this printer with my dell laptop having windows 7...
There are no official drivers Win 7 avaliable for your AIO hp DJ 3420, but you can use an alternate compatible drivers for your model ie. hp DJ 3600 series. Read this link from hp Installing the Printer with an Alternate Driver in Windows 7 for a USB Cable Connection. Suggestions What have you tried to get Windows Update to work? I would suggest the following: Go to the Devices and Printers folder, Add a printer, Local Printer, LPt1, etc...when the list of printers comes up select Windows Update. After several minutes the list of printers should be updated and the Deskjet 3600 should be in the updated list. (Also keep in mind to look under 'HP' section of the driver (hp 3600) list and not 'Hewlett Packard'). Cancel the install the wizard & select "hp 3600" drivers to install on your Win 7 system. Hope it helps.
Jun 11, 2011 | Office Equipment & Supplies
Just up graded from a homelite 4400 to a craftsman 5600 generator 5600 does not have enough output as did the 4400 why
Some manufacturers tend to fudge the numbers and throw around the 'peak' output power as continuous and it isn't. Peak (or surge) is the power a generator will handle as starting current (for example) for a motor and can be 120-140% of the actual continuous power.
Check you owner's manual, find the detailed specs which will normally contain the maximum continuous current rating. If it is listed separately for 120 and 220 (240) volts look for separate current ratings for each output.
By multiplying the current(s) times the output voltages you can find the total resistive output into a purely resistive load such as an electric heater.
For example: 120VAC X 20 A=2400 watts. If other outputs are available such as 220VAC, multiply its current rating: 10A. or 2200 watts Adding those two results 2400 2200=4600 watts will give you the rated power of a unit.
You can also recognize stupid power claims if the engine's horsepower is given. One (US) HP = ~746 watts. Since no generator is 100% efficient, its a fair rule of thumb to guesstimate the available electrical power at ~70% of the engine's rating (although, this is often also wildly optimistic). 10 HP X .7= ~746 X 7 or a bit over 5,000 watts.
Oct 03, 2010 | Craftsman Electrical Supplies
Craftsman Briggs & Stratton Generator, 3600 Watt 7 HP Logo
Top Craftsman Electrical Supplies Experts
BJ Russell
wadingriver
wadingriver
Chuck Graybill
Are you a Craftsman Electrical Supply Expert? Answer questions, earn points and help others
