Question about Samsung P2270HD 22" LCD Monitor
I moved my tv, from a flat to student accommodation, there is cable connection, but the Samsung 22270HD - TV would not work. i WAS TOLD TO RESET IT LIKE THE FIRST TIME I BOUGHT, that was 2010. I just cant remember. Please help
    Master:
  • 444 Answers
Go into the menu on it, It has to be set for (Cable)
Posted on Oct 29, 2012
4 Suggested Answers
SOURCE: samsung series 5 500lcd tv just black & white colors.
thanks for rapid comm.resolved issue .stb is a old version ,does not support hdtv ,changed to a newer version,everything worked fine.once again thank u
Posted on Nov 29, 2008
SOURCE: samsung syncmaster 910mp TV connection
I believe you are describing this connector adapter.
http://www.thesource.ca/estore/ catalog number 2780265
Posted on Mar 06, 2009
  • 22 Answers
SOURCE: connect flatscreen tv,cable/dvr box and dvd player
try a banana
Posted on Jan 04, 2011
I can't get audio to work on my Samsung UN40HU6950F UHD TV HDMI 1 input using the Time Warner Cable Cisco 4742HDC cable box.
if all 4 inputs work with another input source(i.e. your Motorola box) it indicates the issue is with the TWC input source. Also check your HDMI cable to be sure it is in good condition & properly plugged in on both ends.
Jan 12, 2015 | Samsung UN40HU6950 40 Inch Ultra Smart
While dusting, the tV went off and we can't get it back on. It is a Samsung, about 2011 or 12, about 46inch, hooked up to a sattelite.
It seems you accidentally touched either a signal cable connected to the TV from the Satellite receiver or the power cable from the electrical outlet. Try removing and reconnecting both cables. If the power cable is not connected right then the TV will not turn on at all; and if the signal cable is loose then the TV should turn on but there will be no picture. Another possibility is that the fuse at the fuse box tripped due to an accidental short circuit. Go to the main fuse panel and reset/replace the fuse depending on what kind you have. Most fuses these days can be simply reset. Hope this works. Electronic parts inside the TV rarely go bad so soon. Solid state electronics are pretty sturdy.
Jun 27, 2013 | Samsung Televison & Video
New samsung p2270hd out of the box. Have run the quick setup and everything was working. After approximately 5 mins the picture/sound has been lost and the menu is unreadable. Is there a way of factory...
Trevor,
That looks like a pretty cool Monitor. I would need a bit more info regarding your setup to fully assist you.
However, below are a couple of links to specific info for your monitor with regards to reseting it.
How to adjust image distortion
The full manual in pdf format. Open the manual and search (Ctrl + F) for the word reset. There are several areas to reset.
There is also a diagnostic to run that will check the monitor for you which you can find via the on screen menu. You can find those instructions as you make your way through the "reset" search in the manual (described above).
I hope this helps.
Best regards,
Steven G4ITBiz
Mar 29, 2011 | Samsung P2270HD 22" LCD Monitor
I have a Samsung TV model LN40C530F and I have 2 problems with it. 1. Suddenly, the sound rises for a few minutes and it comes back at the initial level. It can happen several times during a program. 2 ....
This happens a lot. I would blame the tv itself. I've worked on samsungs with faulty CCFL lamps, faulty backlight inverters....faulty mainboards ETC. I believe this is a video signal issue going from digital to analog which corrilates with the tuner board (AKA mainboard) of this television. If you have a warranty, demand new...if you don't, try and replace the mainboard and see if it works for awhile (long-term, unliekly)
Rate if this helps :)
Mar 07, 2011 | Samsung LN40C530 TV
I have a flat screen hdtv samsung television and it was moved to another bedroom and the sound stopped working the picture is fine, I just don't know what happened to the sound.
Check the inputs on the back of the TV. A cable might have gotten mixed up in the move, if not, maybe the TV is on mute. Turn up the volume and secure all connections. Restart the TV at the end. Hope this helps =]
Mar 01, 2011 | Televison & Video
Audio sync issues between my stereo and my new LG 42PG20.
i have samsung home cinema and a lg 42lc2d.
the samsung has 6 speakers but all i can get to work 1 front speaker.
when i trythe speakers on test mode they all work with the test sound
could you please help me
best regards ron mcneill
Dec 25, 2008 | LG 42PG20 42 in. Plasma HDTV
Magnavox -Reset
Maybe they mean you need to rescan for channels (and possibly switch the tuner to cable mode).
Jun 10, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Bottom of screen is moving. I need help!
It looks like you got a bad Power Surge thought your Power Cable. There is a card in your TV that handles that. Unfortunately their is little you can do but bite the bullet and pay to have it fixed. First call Samsung and ask if this has happened to anyone else.
Feb 01, 2008 | Samsung HP-R4262 42 in. Plasma Television
Samsung P2270HD 22" LCD Monitor Logo
157 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
