Question about ASUS Z83V Notebook
No Wireless/ wi-fi
After reloading a complete install of windows Xp into my Gateway MX 6426 Laptop, I have had problems with drivers etc. I seem to have most drivers proper except, a few ethernet, and pci driver are showing confict? But my main problem is no wireless Lan. I tried all the downloaded drivers from gateway, etc. But I seem to not have any means to connect to the enternet, the only modem i seem to have is a fax, Can;t connect striaght to router or through wireless connections, neither do anything. as in if i plug in a ethernet cord nothing happens and the is no wireless on computer help please
  • tommyhendren Jan 04, 2009
    dont fix it buy a new computer
  • 340 Answers
did you install the modem driver aswell? the modem and WiFi wireless is a mixed unit, as need both drivers to funktion.
/Teis
Posted on Jan 03, 2009
Wi-Fi stopped working on my Gateway NV77H19u. I can connect to the Wi-FI from a different laptop. Is there an external switch on the NV77H19u to use Wi-Fi?
Your Gateway either has corrupt drivers or has forgotten your WiFi.
Go into your device manager and remove the WiFi device. Then have your computer search for any hardware changes. It will find your wifi device and reload drivers. If this does not work, you have a bad wifi card.
Semper Fi,
Z
Jan 31, 2018 | Gateway Computers & Internet
IBM ThinkPad T40 no LAN or internet connection
Fot that first you need wi fi router with intenret connection .
Then check in your laptop that your wi fi network adapter driver are installed.
Also check its wi fi switch is turn on it is on laptop.
Check your wireless in router is enabled.
also check your wi fi network adapter is enabled in your LAPTOP.
Let me know if you want to configure your router and if you need more assistanse .
thanks.
Aug 26, 2009 | IBM ThinkPad T40 2373 Notebook
Netgear WN111v2 Adapter disconnected
Is the Netgear Wi-Fi Management software installed on the computer? If it is, you may have a conflict between Window's built in Wi-Fi Manager and the Netgear Wi-Fi Manager. If it isn't, you may need to install it.
Assuming it isn't, there's links to download the software at the Netgear Global Download Center.
I would default to the most current version, if you're running Windows XP, you may need to install the v2.1, however, I would assume the v3.1 would be backward compatible with XP.
Install the software and follow the prompts that will guide you through the installation/setup.
Now, if the software is already installed, you need to find the program and configure it through that avenue. If that does not fix the issue, you should uninstall the Netgear software, remove the Wi-Fi adapter and reboot the computer. After it completely boots back up, you should either plug in the Wi-Fi adapter, let Windows recognize it and install the drivers, (they should still be in the system even after you uninstalled the software). Once Windows successfully locates and installs the drivers, reboot the computer again, (no need to remove the adapter). Once Windows completely loads again, open Start, Control Panel, and System. On the resulting window, click the hardware tab at the top then click the "Hardware Manager" button in the middle about 1/3 down the window. Click the "+" next to "Network Adapters" and verify that your WN111v2 is indeed installed.
Assuming it is at this point, close out everything but the Control Panel and open "Network Connections". Find the wireless adapter there, (may be listed as "wireless connection2" depending on how many times it's been installed). Right click on the wireless device and select "Show Available Wireless Networks"
I'm also uploading a video showing what needs to be done.
Establishing WiFi Access in WinXP
Jan 27, 2014 | NetGear Computers & Internet
Lost wi-fi facility
Hi, Well you have formatted the system, so you need to install the Wi-Fi driver in order to access the Wi-Fi. ou must be having the driver CD, If you dot have just download the wi-fi driver from internet and install it on your Laptop and re-start the laptop and you will be able to access the Wi-Fi again.
Regards, polysandy
Apr 26, 2010 | Acer Travelmate 2200 Notebook
Gateway 8510gz laptop with no wirless
go to the manufacturer web site (download/support) and download the XP wireless driver for your laptop
Jun 29, 2009 | Gateway 8510GZ Notebook
Gateway PC crashing when connecting to Wi-FI
if i was you i would load up a version of win xp on another hard drive inserted into your laptop, load the drivers for the laptop including wi fi drivers then see if ok. if not you can be sure its a faulty wi fi card in your laptop,you need to disable internal wi fi card remove,replace it.but first try borrow a pcmcia wi fi card just to check if everythings ok
Dec 06, 2008 | Gateway MX6438 Notebook
New Hard Drive
Here is likely what happened.. Your original Hard drive Probably had the Operating System and System Drivers/Software Embedded onto it from the manufacturer.....which uses a Restore CD set
You added a New Drive.. which comes Blank, Then loaded XP.. Now you still need your System Drivers... this will have the drivers for your Wireless and sound and the right display driver etc... You should go to the Manufacturers website of your Laptop and Download the default drivers from their website
Jun 04, 2008 | Computers & Internet
Problems with wifi lan configurantion.
hmmm... is the wireless card listed in the device manager at all? even as a yellow question mark?
do you have a USB wifi adapter you can test on this computer?
Mar 29, 2008 | Acer InviLink 802.11b (91.49C10.002)...
ASUS Z83V Notebook Logo
182 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
