Question about Patton PRH11 Electric Heater
Patton phr 11 won't heat
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
Heat 1 & 2
Typically 'Heat 1' means first stage heat and 'Heat 2' means second stage heat. Essentially a Lo and Hi setting. Just like a hair dryer.
Feb 26, 2014 | Patton PUH680-U Utility Heater
I know there is data on my phr-250a mcally external hard drive but it's showing empty folder
Leave it connected to your computer and try a restart.
If the folder is still showing as empty, power down the computer then disconnect the external drive.
Power on the computer and connect the external hard drive to a different usb port.
I had this exact problem with a 1000 Gb external drive that was full of movies and music. I thought it had all been lost .. After 2-3 days and repeated attempts of restarts and power-downs/different usb ports it suddenly was recognised again and has worked perfectly since
Jun 07, 2013 | Macally Phr-250a - Usb 2.0 2.5-inch Ide...
NEED REPLACEMENT MOTOR FOR PATTON 1010MP-HY FAN. WHERE CAN I PURCHASE THE MOTOR?
CTG ' Order 1010MP from PATTON ELECTRIC CO INC Now from CTG !
It looks like you can purchase a motor here.
Make sure you have the correct data from your motor.
There is also a contact button so you can probably call, too.
Good Luck,
Your FixYa Texpert,
Gary
Aug 17, 2011 | Patton U2-1487 Floor / Box Fan
I lost my ac adapter for my PHR-100ACB external drive. I do not have a manual for same. Please point me to where I can download a manual and the part number, relative price, and/or where I can get a...
Here is the manual for the PHR-100AC, this is for e, but it will work for your B model as that's just a revision I believe.http://www.macally.com/techsupport/manual/phr100ace_manual.pdf
Unable to find a replacement ac adapter. You could try calling Macally directly @ 909. 230.6888 or techsupport@macally.com . My experience this will cost you about $20 anyway. It may be worth just picking up a new enclosure. At least you'll have spare parts for everything else. It's $40 on newegg.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817146602
Good luck! I know this isn't everything you were looking for, but if this helps at all please give a positive rating. Thank you.
Jul 01, 2011 | Macally 1 Bay (phr-100acb) Firewire/USB...
I have an PATTON PUH 9000, it works when it want too on/off never really heating anything.As there is a RECALL on this unit, where do i get it fixed or my money back?
Here's a link to the site that has a phone number to call concerning the recall of last December.
Use it to determine if your model Patton heater was included in the recall.
http://thestir.cafemom.com/home_garden/113974/huge_walmart_heater_recall_over
There was also a recall in 1985.
Feb 10, 2011 | Patton PUH9000-U Heater
I have a patton puh682 1500 watt heater and after a while it just seems to turn off is there some kind of timer or heat control?
Under the main black knob is a bi-metal switch which shuts down the heat at various temps depending on your setting. Their is no timer.
Sep 21, 2010 | Patton Electric Patton PUH680-U Electric...
I'm thinking about buying a Patton PCH 199 Twin Ceramic Heater. Do you recommend this product?
Twin ceramic heaters are intense, but, not intended for indoor use without adequate ventilation.They radiate heat and patton is a reputable brand in heating devices.
May 16, 2009 | Patton Electric Heating & Cooling
Macally PHR-250A
There should have Quick installation guide and CD with manual inside.
You may download the manual from http://www.macally.com/EN/Techsupport/Manuals.asp
Feb 13, 2007 | Macally 1 Bay phr-250a (PHR-100A) USB 2.0...
Patton PRH11 Electric Heater Logo
50 people viewed this question
Top Patton Heating & Cooling Experts
Mack Baxter
tractorman44
tractorman44
Jay Finke
Jay Finke
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
