Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
97 k1500 jerks when turning right at slow speeds
When in reverse or just starting out my right tire will **** like the brakes are locked on that side. the tire will squeal a little as if the brakes where on as well. What could cause this. I have replaced cv axle because when this first happened I noticed some grease on the cv boot. That didn't help it.
  • akanagy
    akanagy Oct 29, 2012
    Sorry this question is not about the ignition switch.
    New Friend:
  • 16 Answers
I would change the brake hos going to the caliper on the right side. In fact, I would change them both.
Posted on Jan 18, 2013
    Scholar:
  • 155 Answers
You have a sticking brake caliper on the Right front. You can verify this by feeling the temperature of the tire rim after you have been driving it awhile. The metal will be very hot compared to the other front tire. Get it fixed - otherwise, you risk a flat tire and possibly a fire when the grease in the hub ignites.
Posted on Oct 29, 2012
Over 89000 miles. Noise has not lead to a wheel bearing. No change by turning right or left, even with sharp turning trying to get a change. Louder at 50 mph but always there. Never without rumbling a
It could be a universal joint.
Also it could be a warped brake rotor. Does the noise change when you lightly put on the brakes, you might try using the brake and gas at the same time for a short test.
Feb 01, 2015 | 2007 Kia Amanti Sedan
Steering jerks left a bit when slowing down
How new are your tires and when was the last time for a front end aliment?That might be it.
Jan 01, 2013 | 1998 Kia Sephia
97 k1500 on 38" tires, gear ratio?
Changing tires does not affect gear ratio. It only affects actual vehicle speed vs. the speed hat the computer "thinks" the vehicle is doing.
May 02, 2012 | Cars & Trucks
2005 Kia Sorento - on dry pavement going forward in 4 wheel drive at slow speed turning left the rear wheel driver side seems to be trying to go reverse, can hear is catching or locking on the road,...
you shouldnt use 4x4 on dry road its made for pulling or snow mud etc type situations if you feel its ok then check tire size are they all the same size tires and the pressure all the same if you dont have a check eng light on then there is nothing wrong with the 4x4 but dont forget all wheel drive works with abs tcm if one wheel spins faster or slower then the rest it puts on the abs to slow it down or the trans shifts up to speed it up so there are a few things to check
Jun 21, 2011 | Kia Sorento LX Cars & Trucks
Front Axle making noise and jerking while turning
It is probally in 4 wheel drive. It is supposed to **** while turning in 4 wheel drive because all 4 tires are trying to turn at the same speed and when you turn one tire slows down and the other tire speeds up but it cant in 4 wheel drive so it skips or jerks. If there is also a clicking noise the CV joint might be going out.
Jun 11, 2011 | 2000 Chevrolet Tahoe
HI I have a1989 chevy p/u c-1500 sometimes backing out of my driveway the rear right tire locks up the wheel cylinders and rear lines are new brake shoes and drums are good I though it was the emergency...
With the older drum brake system going in reverse will often tighten the adjuster on the brake mechanism. The adjuster has a thumb wheel to adjust the shoes in and out. BUT there should be a little plate that locks the thumb wheel once you are where you want it to be. I would guess that either you don't have that little plate or it is not keeping that thumb wheel from turning on the right side.
Jun 07, 2011 | 1989 Chevrolet K1500
My antilock brakes are activating at low speed stops 97 silverado K1500
From pads may be low causing the rear brakes to over brake and the anti-lock kicks in. Could be a sticking caliper piston and last the proportioning valve may need bleeding as it is offset.....
Feb 13, 2010 | 1999 Chevrolet Silverado 1500
Rear tire locking up on 1992 chevy k1500 4x4 seems like after u joints were installed on drive shaft rear tire locks up periodically truck will not move
thats serious... need to find out if its a brake problem or rear end , or trans problem. I would not think universal replacement would have anything to do with it, but thats strange.
Sep 26, 2009 | 1993 Chevrolet K1500
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
