Question about Maytag Neptune MDG6800 Gas Dryer
My neptune mdg6800aww wont heat up
I have replace the thernal fuse but it still will not heat up. Suggestions?
    President:
  • Maytag Master
  • 1,922 Answers
Replace the gas valve coils on the top of the gas valve body as they get weak and dont have enough force left to pull up on the gas valves in the body to open them,easy and inexpensive to replace,there are 2 coils and one has 2 wires to it and the other has 3 wires so you cant reverse them,also there are alining ping in the coils so you mount them correctly
Posted on Oct 30, 2012
vanni7
  • 163 Answers
SOURCE: I have a Maytag Neptune Model #MDG6800Aww
Hi!! You seem to have a problem with your heating element on the dryer..Also make sure that your breaker going into your dryer is on..Good luck..
Posted on Jan 21, 2009
Illeagle
  • 525 Answers
SOURCE: my Neptune dryer mdg5500awgg wont heat up. Any suggestions?
I am providing some links courtesy of www.repairclinic.com that will assist you in the diagnose/repair of your dryer.
Firstly, ascertain that you have made a positive heat selection on the control panel switch, then proceed onward.
Parts breakdown/disassembly procedures:
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
1. Gas Valve Coils image:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500awg-%3d%3di3479&PartID=3479
2. Ignitor image:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500awg-%3d%3di3018&PartID=3018
3. Thermal Fuse image:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg5500awg-%3d%3di516650&PartID=516650
Posted on Aug 27, 2009
Ranglo
  • 1194 Answers
SOURCE: my Maytag Neptune gas dryer
When the dryer wont heat it is the thermal fuse that is bad, you can test it with a voltmeter before replacing. This fuse is located inside the rear panel and it cannot be reset.
Hope this will help...
Posted on Jan 01, 2011
mc1bean
  • 3053 Answers
SOURCE: How do you release the front panel on a maytag
Hello, tom I was trying to helpyou out here. I am not sure if this well help you, but here is a link to abouteverything you want to know about your dryer, from repair to trouble shootingit. If you go to this link and click around, I am sure you will find out so muchabout your dryer, you will know more that the company that made it. Here Is thelink for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helpedyou at all, if you can find the time to rate my help and some kind wordswritten would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
mc1bean
  • 3053 Answers
SOURCE: my dryer neptune mn MDG6800AWW
Hello, viv I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Dryer not hating up after changing heat sensor
Check this site out------http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-4-630749-/Maytag-Dryer-doesn-t-heat-MDG6800AWW-------------
Oct 09, 2014 | Maytag Dryers
Maytag neptune #mdg6800aww burner lights but wont stay lit after about 15 seconds
Well that could be a blocked vent causing over heat, bad blower wheel, simply cleaning out the dryer and opening up the vent helps a bunch. Ya gotta take the door off first to get in the machine. Then the front comes off then you can check the innards for airflow issues.
this un is electric model but they come apart the same. If the glowbar comes on and the flame sensor shuts down the glowbar ok and flame comes on and runs about 30 seconds that seems to be the norm for this style dryer. The heat does not stay on. Clean it up and put it back together and if it does better ok if it dont then you gonna need to replace the cont stat and gas valve coils.
Sep 30, 2014 | Dryers
Maytag MDG6800aww dryer wont heat?
first check that there is he correct power going into the machine #2 inspect heating elements
Aug 26, 2014 | Maytag Neptune MDG6800 Gas Dryer
Maytag neptune stacked MLG2000AWW wont heat
It's either the fuse, heating element, thermal cut-off or thermostat
May 20, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
My Maytag Neptune gas dryer has stopped heating The button pannels turn on, dryer spins but no heat I cleaned the vents Model no. MDG6800AWW How do I fix it? Can I repair it myself? Is there a...
Dec 30, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My Neptune dryer mdg5500awgg wont heat up. Any suggestions?
Igniter
Gas valve coils
Thermal fuse
2. Ignitor image:
Aug 26, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Where is the thermal cupple on the maytag neptune GAS DRYER MODEL#mdg6800aww
It sounds like the unit is cycling on the thermal limiter. To verify, disconnect the vent from the back of the unit, if this improves and you have longer cycles, then its more than likely just a dirty vent, However, If you disconnect it and it still continues to short cycle then its the hi limit thermostat & it needs to be replaced
May 05, 2009 | Dryers
Jan 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
Oct 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG6800 Gas Dryer Logo
255 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
