Question about Canon CanoScan LiDE200 Flatbed Scanner
Cannot communicate with scanner on MAC
I used the scanner at 9 AM, then had to run an errand. I shut down, left my Mac PowerPC G5 running OS X 10.5.8, returned 1 hr. later, rebooted and went back to work. But this time I got the "Cannot communicate with scanner" prompt. I get the prompt often but can usually re-establish contact by disconnecting the USB cable, waiting 60 sec., reconnecting, and re-clicking SCAN. But this time... the same prompt. I used a different cable but still the same prompt. Did it die on me?!!!
  • 97 Answers
SOURCE: Scanner won't communicate with my Mac
Uninstall the software with scanner unplug from your MAC. Install the software with the scanner disconnected, then connect it b4 the first use of the software.
Posted on Mar 31, 2007
  • 111 Answers
SOURCE: Canon CanoScan LiDE 60 not recognized by iMac or Mac Powerbook Laptop
Is the scanner detected in Apple System profiler? If so, what applications have you tried to access the scanner from?
Posted on Jul 09, 2008
SOURCE: canoscan 9950F won't scan, says scanner locked, but it isn't
I was surprised by the same problem this morning. First time I've had a problem with in years. Checked the lock... it was already unlocked. I solved the problem by unhooking the USB cable from the hub, restarting my Mac (seems to be the key), replugging the cable and restarting the scanner. Worked like a charm. Hope it works for you!
Posted on Apr 11, 2009
trisha8765
  • 120 Answers
SOURCE: Every once in a while (after 10 or so scans) the
unplug the connections and power supply for a minute or so and plug back in. Make sure you have the latest driver as well.
Posted on Dec 27, 2009
SOURCE: Canon LIDE 500F scanner does not scan - returns error message about releasing lock switch, detaching interface cable and reconnecting
I had the exact same problem with another scanner (LiDE 80) after years of use. It stopped being able to calibrate itself so I couldn't use it on computers where it had never been installed on before (since on freshly installed computers, the driver requires calibration to be carried out at least once).
Hopefully my solution will work on the 500F, albeit with some modifications you'll have to figure out yourself. :P
What I did was open it up, the two strips of plastic to the left and right of the platen can be used to remove the glass surface:
1. release the oval catch at the front of each strip by prying them upwards.
2. slide the glass towards the front of the scanner a bit till a gap appears between the end of each strip and the back of the scanner.
3. pry a bit of the back of both strips upwards and keep them away from the glass so they won't stopped by the back of the scanner.
4. slide the glass all the way to the back, you should be able to remove the glass since the two plastic strips aren't blocked anymore.
The reason the scanner fails to calibrate is because it tries looking for the black/white strip hidden between the plastic case and glass panel at the front but fails. There are three possible reasons:
1. Dirty glass panel/damaged black/white strip
2. Covered/dirty CIS module
3. Loose drive belt
Mine was a combination of the first three. A little washing and thorough drying of the glass panel and black/white strip and careful wiping of the imaging element and led strips (the black bar is the imaging element and the white bar is the led strips) fixed the problem.
I didn't have a loose drive belt, so I didn't look into fixing that, but I see a spring loaded catch holding the drive belt tension; if you have a loose belt, it may be worth it looking into that.
A tip of advice: If somehow, after reassembling your scanner after tinkering with it it still refuses to calibrate, you can do a dirty workaround by doing the calibration with the scanner disassembled and placing the black/white strip manually above the CIS module at the front, making sure to hold it steady. Your images will look a bit muted, but at least it works! (I did this step before I reassembled the scanner just in case it wasn't fixed, but thankfully its working now!)
Posted on Jun 29, 2010
Driver for mac os 10.7.5
The last Mac OS X version officially supported by that scanner is Mac OS 10.4 Tiger. You *MAY* be able to get it to work under Mac OS 10.5 Leopard or 10.6 Snow Leopard but otherwise there is NO way to get it to work with 10.7, 10.8 or 10.9 since these are Intel only platforms (the scanner software is PowerPC PPC.) Your only option is to run a Windows XP virtual machine inside your Mac and to it that way. I can assist you with that if you like.
Jan 06, 2014 | Minolta Dimage Scan Dual III Film Scanner
How to upgrade from mac os x 10.4.11 to a higher version
If your computer has OS X 10.4 installed on it, it's likely that you have a PowerPC processor. Apple used these for years before switching to Intel processors in 2006. The highest version of OS X that you'll be able to run on a PowerPC Mac is 10.5 (Leopard). You will not be able to install Snow Leopard, Lion, or Mountain Lion.
Easy way to check if you have PowerPC or Intel is by clicking on "About This Mac" in the Apple menu (top left of your screen).
Oct 16, 2012 | Apple OS X 10.8 Mountain Lion
Sims 3 wont install onto my powerbook G4
Sims 3 will not run on a mac that isn't using an Intel based processor. You will have to upgrade from a Power-PC processor in order to use the latest version of sims.
Oct 15, 2012 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Install Snow Leopard on a macmini Power-PC ?
If it is a G4 PowerPC processor No
If it is an Intel Processor Yes
Jan 06, 2010 | Apple Power Mac G5 Desktop
I am trying to download PCAnywhere 12.0 to windows 7 and it tells me they are not compatible
That is correct Symantec list supported operating systems and Windows 7 is not compatible..
System RequirementsWindows 2000 Professional/Server/Advanced Server
Windows XP Home/Professional (32-bit and 64-bit)
Windows 2003 Server Standard/Enterprise (32-bit and 64-bit)
Windows Vista Ultimate/Business/Enterprise/Home Premium/Home Basic (32-bit and 64-bit)
Windows 2008 Server
Internet Explorer 6.0 or later
Regards
Nov 10, 2009 | Symantec pcAnywhere 12.0 Host & Remote...
Wont install on Mac i use leopard and it states it needs classic envinroment
"In any case, you will not be able to use the Classic Environment in any OS with your MacBook Pro. The Classic Environment functions only on PowerPC-based Macs, of which the MacBook Pro (and all other currently sold Macs) is not. Mac OS 9 was never designed for Intel Macs, and cannot run on them without full PowerPC hardware emulation."
Hope it helps
Jun 20, 2009 | Scholastic I Spy Collection for Windows,...
Popcorn3
Not unless that dell is running a Mac OS.
Popcorn 3 System Requirements
  • Macintosh computer with PowerPC G4, G5, or Intel® processor
  • Mac OS X v10.4.10 or higher
  • 300 MB of free disk space to install
  • Up to 15 GB of temporary free disk space during usage
  • QuickTime 7.1.6 or higher
Sorry about that!
Apr 10, 2009 | Dell Dimension XPS PC Desktop
Mac os x Snow Leopard
Apple's next major Mac OS X released, will focus solely on under-the-bonnet changes, the Mac maker has revealed. PowerPC-based machines might be left in the cold?
Apple is promising a version of Mac OS X that "dramatically" reduces the amount of storage space the operating system requires. Undoubtedly, some of that will come from the re-engineered core technologies, but it's hard to conclude that Snow Leopard's release will come not as a "universal" binary capable of running on both Intel and PowerPC processors, but as a single-platform product.
Universality has been handy in ensuring users can run the same installed code on both Intel- and PowerPC-based Macs without resorting to emulation. But just as Leopard lacks the ability to run Mac OS 9 apps - a feature present in previous Mac OS X releases - there will come a time when Apple drops Rosetta, its PowerPC emulation mechanism.
Early rumours concerning Snow Leopard suggested PowerPC support was to be dropped, though that was subsequently denied by Apple.
How can these two claims be reconciled? Only by Apple shipping native-only versions of Snow Leopard. Owners of Intel-based Macs will finally be free of all that redundant PowerPC code in the system software, freeing up space for, as Apple puts it, "their music and photos".
With any luck, Apple will finally allow users to readily remove unwanted languages from their system software, a process that can free up a fair bit of hard drive space too.
Apple won't be ditching support for universal binaries, or PowerPC Macs, because there, for now, too many of them out there. But if Snow Leopard's Grand Central technology does as promised and improves the OS' ability to work with multi-core CPUs, Intel-based Macs are going to shoot even further ahead of old G5 and G4 models.
Apple is also promising that Snow Leopard will offer more pervasive support for 64-bit computing, leading to the ability to support up to 16TB of memory, though the motherboard hardware to do this isn't there yet. In any case, limits to CPU memory controllers mean they don't physically support the full range of 64-bit memory addresses, only a subset.
Snow Leopard will also feature QuickTime X, a "streamlined" revamp of Apple's multimedia foundation, and OpenCL (Open Compute Library), a non-proprietary programming system for running complex code on a machine's graphic chip(s).
Oh, and it'll get Microsoft Exchange support too, in a bid to make Macs more business-friendly.
Aug 27, 2008 | Apple Mac OS X 10.4
Canon CanoScan LiDE200 Flatbed Scanner Logo
old marine
old marine
