Question about GE JSP46 Electric Kitchen Range
What amp breaker is required for the GE JSP46 convection electric range?
  • GE Master
  • 3,361 Answers
40 or 50 double pole.
Either one will work.
Most people use a 50.
Posted on Mar 04, 2009
2 Suggested Answers
SOURCE: what is the required amps for a JSp46 range
if the range you have is just like a regular 4 burner & oven all you will need is a30amp breaker
Posted on Jan 03, 2009
I have a GE JSP46 and the burners work but the key pad and the oven are not coming on please help
You will need to replace the control board on the unit. This model is famous for the control going out on it.
Nov 22, 2011 | GE JSP46 Electric Kitchen Range
GE microwave/convection oven 1790 there is a #8 displayed in the right upper corner of display
HELLO.
When the F8 code appears,it means that electric control requires replacement because the relay drive circuit has been lost.
Attempt to clear the code by pressing Cancel and cutting power to the range for 30 seconds.
If the code cannot be cleared, replace the electric control.
thanks.
Sep 21, 2011 | GE JVM1790SK Convection/Microwave Oven
Range takes 2 1/2 hours to reach 350 degrees
Check for proper voltage at connection. breaker may be half off. Check for burnt wires
Jul 12, 2010 | GE 30" Self-Cleaning Freestanding Electric...
What is blue wire on ge built in oven for
The blue wire goes to a seperate 15 Amp circuit breaker or fuse.
This breaker should be powered by the L1 (black) supply feed in the breaker box. The circuit supplies power to the display and control buttons. The red and black wires go to a double ganged 20 Amp breaker. Check inside the oven back cover for a wiring diagram.
Sep 07, 2009 | GE Profile 30" Built-In Single Electric...
Ge electric range ahas no power, circuit breaker wont reset.
Unplug the range and try to reset breaker. If it holds, you have a shorted element or some kind of fault in the range. If it won't hold in, change breaker
Aug 04, 2009 | GE 30" Self-Cleaning Freestanding Electric...
GE Profile elec range JSP40 Locked door flashing can't use oven
Replace the oven temperature sensor to solve the F3 problem.
You may need to replace the oven lock micro switch to solve the locking problem.
Change the sensor first. Then try the oven.
Mar 04, 2009 | GE JSP46 Electric Kitchen Range
Installing ge profile double oven not convection in new build trying to find out electrical requirements ( size breaker 50,60amp ?)
You must use a three-wire, single-phase A.C.
208Y/120 Volt or 240/120 Volt, 60 hertz
electrical system. If you connect to aluminum
wiring, properly installed connectors approved
for use with aluminum wiring must be used.
That means that you ned a double 40 amp breaker.
Good Luck
Jan 18, 2009 | GE Profile JT952 Electric Double Oven
What is the required amps for a JSp46 range
Jan 03, 2009 | GE JSP46 Electric Kitchen Range
Open Questions:
GE JSP46 Electric Kitchen Range Logo
99 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
