My existing emote doesn't power up or doesn't function at all. I order a new one and it doesn't work either. I call Direct TV and they said I would need for the Protron manufacture to program the TV to the new remote control. They ask if I had a code number for the TV to see if it was compatible to Direct TV. I told them I didn't have a code number nor did the instruction books have a code. The remote that I was sent was a PLT3250 should I order a PLTV32C. Is that the problem?
SOURCE: searching for TV remote control code for PLTV-32
I spoke with their tech support in India and was told this tv will not work with a universal remote.
SOURCE: Programing codes for a Protron TV
The codes for the 32' Protron are 1004 or 1011. However be aware that this may disable your defaults permanently. When we had the cable installed they changed the codes but on doing so, the TV was useless. On power up the led will go from red to green, then go back to red instead of giving a source option. Customer service is agravating and useless; this is Chinese company that is using the name ProtRon to ride on the better make of Proton. We bought it through ShopNBC, definitely a big mistake since they are of no help either. We have taken the TV to a repair shop; they say its a main board but they are having extreme difficulty getting help from Protron; only delays and excuses. There are more issues riding on all this that has prompted my wife and I to seek a class action.
SOURCE: i have a protron 32 inch tv
I just had a Verizon FIOS sytem installed and my Protron remote won't work. To use the mute or volume I have to use the TV remote. Verizon can't find a code. I purchased this on ShopNBC so I would be careful of purchasing anything else from them. I had to raise hell with them to get Protron to send me a manual which I did not receive with the shipment. Protron is a worthless and irresponsible manufacturer. ShopNBC also was lax in their responsibility to screen their products and ensure they're of first quality.
SOURCE: Remote control programming- Directv
if you have gone through all of the programming codes; you will just have to use the remote that came with the TV set. there is no way to program more codes into the remote, due to its list of codes it was made with can not be updated. i hope this helps
