Question about Garden
I have a leak from the pressure washer output manifold and sears model 580752050. (pump model mtpv93517) The check valve kit Briggs and Stratton # 193806gs I ordered was correct from but the check valves are too tall to seat into the output manifold and be flush when reinstalling. Did I order the wrong check valve kit or is there another problem?
4 Suggested Answers
Tnsiouxfalls
  • 617 Answers
SOURCE: Briggs and Stratton pressure washer fuel leak
You've hit the nail on the head.The float,needle and seat are stuck wide open.Once the carburetor bowl is full of fuel the float rises up on top which pushes the needle back into the seat shutting of the flow of fuel.As the engine consumes that fuel the float drops and opens the needle and seat filling the bowl and shutting off the fuel again.Things that cause this process to not work are:forgetting to empty or run out the fuel before storing it for the winter.Sediment buildup in the bowl.Mineral deposits in the needle and seat.
Not emptying out the carb can leave water in the bowl which freezes,crushing the float.It also promotes sediment buildup and mineral deposits.The float when crushed or cracked will not float,nor shut off fuel.Sediment takes away capacity of fuel in the bowl,very necessary for wide open throttle.Mineral deposits build up to the point that the needle and seat can't make a good seal so fuel will continue into the carburetor.
Enough information yet?
To repair,take the nut off the bottom of the carburetor bowl.There are the float and needle and seat assemblies.All three need to be replaced,$10 max.After you get the parts replace one piece at a time so you can see how they go together.Next replace the spark plug, engine oil and air cleaner.They are fuel fouled and even if you could get the engine started will only add more damage to your engine.BEFORE you put the new plug in cycle the engine by pulling the starting cord a few times to get rid of the excess fuel.When there's now more fuel in the cylinder replace the plug,filter and oil.
That's it!Take your time and you can do it just fine.Re-post if you have any more troubles.
Posted on Jan 13, 2010
mxc2
  • 146 Answers
SOURCE: Hi, My Dewalt 3100 pressure
The Dewalt 3100 came with 2 different pumps. The Blue Cat pump and the oil free pump that was made by DeWalt.
You may just have a bad Thermal relief Valve on the unit.
You can find the parts diagram at www.allpartsinc.com
Posted on Oct 01, 2011
spraydoctor
  • 97 Answers
SOURCE: leaking pump protector valve in a Landa SEA series pressure washer
"Protector Valve" could mean several different things. There is "pop-off" safety pressure relief valve and there is a "Thermal Relief Valve". Your pump could be protected with both, or only one of these. A pic would nail it down quickly.
Don
Posted on Mar 15, 2012
Is the pump seal bad when doesn't spray /pump well?
The sign of bad seals are water leaking out of the bottom of the pump. The high pressure seals get bad enough the low pressure oil seals will fail as well and water will get into the crankcase.
Weak or fluctuating pressure is a sign of a problem with your check valves or seal problems with your unloader valve.
Jun 11, 2014 | Craftsman 2500 PSI Briggs Stratton...
Will not produce pressurized water
check the pressure regulator valve. It may be set wrong or stuck open. If that is not the problem then a valve may be stuck in the pump.
May 17, 2013 | Briggs & Stratton Briggs Stratton 1800...
My briggs and straton troy bilt 675 pressure washer has no pressure
This means overhaul the valves on the pump. You can get a kit for this that has all the seals and valves. The pressure regulator might also be stuck open
Oct 13, 2012 | Briggs & Stratton Garden
I have an old briggs stratton 2001 power washer its hard to read model number it looks like EXYRB2321 or EXVRB2321 its 6 hp when i put in ether number at B&S sit they say no results i need a...
Excell pressure washers used a series of numbers such as yours. I believe that that number will be for pump or pressure washer as a whole unit. Check Excell web site for a match. If you are looking for the engine model number check the fan shroud or valve cover or tag on engine itself. Good luck
Sep 06, 2010 | Briggs & Stratton 020324 3700 PSI Pro...
No water pressure coming from pump
The pump is bad and needs to be replaced. you have done all the test. On the Briggs they do have kits to rebuild the pump on your system you can just go to there website and get the rebuild kit. It is safer to go through them because they have jsut started producing the rebuild kits, and other companies have tried to copy them, but there kits are worthless. Please rate
Jun 04, 2010 | Briggs & Stratton Prosumer 20324 Gas...
No pressure
force feed the pump with water it sounds like its sucking air rather than water if no leaks check the 6 valves regards
Jan 06, 2010 | Briggs & Stratton Prosumer 20324 Gas...
Not much pressure,after building pump
It sounds like one of the pressure valves is leaking
Jul 26, 2009 | Briggs & Stratton Garden
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
