Picture size cuts off edges
Want to decrease picture size
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
For a possible answer a brand and model number are needed.
Posted on Oct 30, 2012
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
Cannot see full picture mitsubishi
Look for a button on the remote that says either P-Size, Aspect, View Mode, Zoom or Ratio. Press the button on the remote to change the size to Stretch, Full etc..
www.aaatvservice.com
Jun 26, 2012 | Mitsubishi Televison & Video
My picture is zoomed in. Cannot go back to 'normal' and see everything. Credit names, etc are cut off on both sides.
Hi
Thanks for using FixYa. First of all please check your cable box settings first. Sometimes the remotes have a picture size button on them, and someone might have pressed that by accident. Check the TV settings, press Menu Button & then go to Window/Image size. Now select Full Size.
Also check the settings of the converter box (if you are using it). The boxes also have a peculiar problem: Unless users manually change settings from show to show, the picture from many stations either won’t fill the screen, or it will be so big that part of the picture is cut off by the edges of the screen. The solution is to press the “zoom” button on the remote that comes with the converter box. That will expand the picture so it fills the screen.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 26, 2009 | Sharp LC46SB57UN 46 in. LCD HDTV
Viewing area is cut off at sides
It's not your tv. It's your cable box setting. Go into settings on your cable remote and set picture size to normal and not zoom or any other setting. Also make sure your picture format is set to 16:9 on your tv. If you cannot figure how to change picture size on your cable box, contact your cable provider. Good Luck.
Nov 04, 2008 | LG 37LC7D 37 in. LCD HDTV
Why does the top of my picture cut off when i print it
Ladydiw,
Are you trying to print the image to the full size of the paper if so does you printer support edge to edge printing?
If not or if you are unsure try resizing the picture to leave a border round the edges.
Regards
Nick
Oct 26, 2008 | HP Office Equipment & Supplies
Printing card
Postcards, 3-by-5 inch (index) cards, and other custom-sized media can be printed from tray 1. The minimum media size is 76 by 127 mm (3 by 5 inches) and the maximum media size is 216 by 356 mm (8.5 by 14 inches). Note You might experience some jams when using any media with a length less than 178 mm (7 inches). This might be caused by paper that has been affected by environmental conditions. For optimum performance, make sure you are storing and handling the paper correctly . Using media from another manufacturer might also help. Printing on odd sizes or weights of media (for example, small, long, or narrow paper) can decrease print speed. The decreased speed helps to prolong the life of internal printer parts. It also improves print quality with these types of media. Guidelines for printing on custom-sized media and cardstock Always insert the short-edge first into tray 1. If you want to print in landscape mode, make this selection through your software. Inserting paper long-edge first might cause a jam. Use the rear output bin to reduce curl. Do not print on media smaller than 76 mm (3 inches) wide or 127 mm (5 inches) long. In your software application, set margins at least 6.4 mm (0.25 inch) away from the edges of the media.
Aug 21, 2007 | HP LaserJet 2300dn Printer
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
