I have an iflops "Share the tunes" stuffed animal and the little circuit board that hold a switch keeps shorting out. I need to find the board with the switch, can you help?
  • cheryldegros Jan 05, 2009
    brand new iFlops, and the switch is bad. Store won't take return because it was a Christmas item. Need new switch!
fellowesrep
  • 102 Answers
SOURCE: aurora as1010tx shredder won't run unless
you will probally have a tough time getting specs on a pc board from the manufacturer you will probally have to find a service dealer in your area that works on shredders or you will probally need to purchase a new pc board from the manufacturer if they still have one available or you may be able to find one online if you know the item number for a pc board replacement.
Posted on Mar 02, 2008
SOURCE: Maxent 26" lcd tv, shorted circuit board
the best and easiest way to track down a short is with a digital multimeter just check for continuity throughout the circuits.If you you cannot get your hands on a multimeter use a compass.It will detect and move left to right when there is a complete circuit and as soon as you hit the short the needle will be dead still. Fix the short and test.It would probably be alot cheaper than trying to track down a part with no certainty of it.Hope this helps
Posted on Mar 18, 2009
  • 4 Answers
SOURCE: My Bissell started to **** up my daughter's
Did you check the hose. The vacuum won't **** if there is a clog in the hose.
Posted on Apr 25, 2010
bronk50
  • 27725 Answers
SOURCE: Faulty Power Circuit board Short Circuit on
Test your power supply unit if the PSU units fans not working its faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error computer error a computer needs its connections continue its cycle and have an end to function
hope this helps
Posted on May 12, 2011
  • 552 Answers
SOURCE: Can the circuit board in the gemmy animated trophy buck be repaired?
anything can be repaired - it is a cost issue.
Posted on Dec 09, 2014
Westinghouse dishwasher SB908 short-circuiting power board
Your symptom is a little confusing, it's best to post a complete model number as written on the ID tag of the unit. This will help to provide better information. PLeazer Appliance...
Jan 14, 2015 | Westinghouse Dishwashers
HI, I would like to clean Kota...got any suggestions? Thanks, Terri
  • How to Wash Stuffed Animals ' eHow.com
    • By eHow Hobbies, Games & Toys Editor ·
    • Difficulty: Moderately Easy
    While there are many methods of cleaning stuffed animals, experts agree on one thing: always be gentle when cleaning vintage stuffed animals. Some experts may ...
    www.ehow.com/how_2054654_safely-wash-stuffed-animals.html · Cached page
  • Cleaning Stuffed Animals Cleaning Stuffed Animals, How to wash and clean stuffed animals.
    www.stretcher.com/stories/980813b.cfm · Cached page
  • The Best Way to Clean Stuffed Animals ' eHow.com Stuffed animals pick up dust and dirt easily. If you are an allergy and/or asthma sufferer, this can have negative effects on your health. Cleaning stuffed animals ...
    www.ehow.com/way_5272684_way-clean-stuffed-animals.html · Cached page
  • Cleaning Tips: How To Clean Stuffed Animals A stuffed animal offers unconditional love. The least we can do is keep them clean and dust free. Advice for cleaning different materials.
    www.essortment.com/cleaning-tips-clean-stuffed-animals-58624.html · Cached page
  • Sep 18, 2011 | Hasbro Playskool Kota and Pals Stompers -...
    My 603 integrated keeps stopping mid cycle and beeps (3 x 2 short beeps). this can happen 2-3 times in the same cycle
    I had the same problem; it turns out that there is a little plastic clip that holds the main circuit board in place and aligns the sensor on the circuit board with a little hole on the unit. This clip was broken and hence the circuit board was moving around, causing misalignment of the sensor and hence the unit would turn on and off during cycles. This may be your problem.
    Dec 15, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
    Need a ode to adopt a pet
    You can get a code from buying a stuffed animal pet from the store. Most toy stores sell them. Or you can buy one from webkinzstore.com.
    Sep 18, 2009 | Ganz Webkinz Chocolate Lab Stuffed Animal
    Will not turn on or off.
    I very carefully removed the cover (total of 8 screws,KEEP TRACK of where they go!!) pry off cover carefully,watching the mini usb port connector. The back where the joystick is located has a little circuit board that can be removed to expose the switch/joystick dial. There is a little steel indented piece that fits into the plastic dial edge. Carefully pull out the steel piece and see if the dial rotates. I used a bit of silicone on a q-tip for lube, carefully reassembled and have a fully functional easily rotatable dial once again. Take your time, it's worth it to save 125$!!
    Dec 04, 2008 | Kodak EasyShare Z760 Digital Camera
    Laptop system board
    you have a dead short in electrical most probably everything is stuffed
    Jul 25, 2008 | Intel Motherboard
    Channel keeps changing
    it seems to be continusly scanning channels and never ends
    Jun 28, 2008 | RCA F32649 32" TV
    Computers & Internet Logo
    102 people viewed this question
    David Payne
    David Payne
