Question about Maytag PAV2300 Top Load Washer
Maytag top loader spins when suppose to agitate
When the washer is suppose to spin it agitates instead. how to fix it??
  • onthethejob1
    onthethejob1 May 11, 2010
    when washer is agitating does it also spin???
  • Maytag Master
  • 8,220 Answers
Bad timer.
Posted on Jan 21, 2009
My maytag bravos top loader washer does not agitate or spin out how can i fix it
sounds like it could be a door switch, when they go bad it will not spin or agitate depending on the model? could also be a bad clutch or motor coupler.. or belt if not direct drive
Jul 25, 2014 | Washing Machines
Washer will not spin. Does fill and agitate.
Any error code associated with fail to Spin?
Is this a FAV6800A LED console model or a FAV9800A LCD console model?
Like one of these?
Jul 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag will agitate instead of spin
http://allrepairmanuals.com/maytag-washer.htm?model_number=MAV7901AWW
Please download, the above, service manual, use the troubleshooting procedures, you should be able to locate and repair your problem.
May 05, 2010 | Maytag Neptune Washer
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
MAYTAG top loader makes high pitched squeal when agitating/spinni
This is a classic symptom of pulley/motor shafts/bearings in need of lubrication. It's not the agitator. You'll need to take the back off (with power unplugged) to access.
May 12, 2009 | Maytag PAV2300 Top Load Washer
Washing Machine agitates only
maytag front loader washing machinne the drum agitates but does not spin
Feb 10, 2009 | Maytag MAH6500 Neptune Front Loading...
"jackhammer" sound coming from my washer
# Balance the load
# Level the machine
# Inspect the water pump for a blockage
# Inspect the coupling
# Inspect the transmission
# Adjust the drive belt tension
# Check the motor bearings
# Check the drum brakes
Jan 09, 2009 | Washing Machines
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag wahser not agitating
Either your transmission is bad which might carry a 5 year warranty or your lid switch needs replacement
Nov 14, 2007 | Maytag Atlantis MAV9750A Top Load Washer
Maytag top loader washer
The brakes are probably stuck or the cam that releases them is damaged
Sep 27, 2007 | Washing Machines
Maytag PAV2300 Top Load Washer Logo
55 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
