What could possible cause 97 cadi seville to run hot?
Check the thermostat hopefully you can in my car there is no way to get to it youreself. also check youre fluid level and hoses
Posted on Jan 04, 2009
How to pull codes for ac system on a cadY 97 98 sts northstar or a ac controll head calibration
well rightthere are no codes Perse to be pulled like engine control codes you have to enter the PCM into diagnostic mode and then select proper system then enter 3 to 4 digit codes to begin tests on the system of the specific subsystem the results of the tests will then let you know what you need to replace or repair I know you're going to ask but how to enter the diagnostic mode you hold down the cold and off I believe on the control the cold or hot I do not recommend you enter or starting the testing without knowing what you're doing that being said I'm not really sure what the numerical codes are for the test you need to run
for the problems you are having but I will look them up and give them to u if you really want to try it you could very easily end up worse off than you are now. but what do I know I'm only an
ASE Certified Master Technician Chevrolet certified 10
years with that will I know
Jul 06, 2014 | 1998 Cadillac Seville
ECU Location
1e2ba4f9-0002-47d1-91ca-4c5fd74d03e2.jpg9836d64d-81e9-4bd9-9478-f40b306f9e99.jpgThe engine computer (PCM/ECU) is located behind the passenger side kick panel. The pictures above should help. Hope it does.....
Jun 07, 2013 | 1992 Cadillac Seville
1993 cadi Seville running Hot
last time you change anti freeze, if over 40k miles drain flush system, replace thermostat, and new coolant, likely stuck thermostat or corrosion in cooling system. or both
Jun 08, 2012 | Cars & Trucks
98 cadi dies at stop lighs after a min or two but runs fine every where else
use gas treatment, i like stp concenstrate. in a black bottle. run a couple of bottles thru. one at a time of course. bottle recomends gas tank to be full. but i have used gas treatment with 1/4-1/2 tank of gas. it works
Jan 09, 2010 | 1998 Cadillac Seville
1996 cady seville sls 5.6L getting water in a
either inlet manifold or head gasket,big job best advice is to trade it in against the goverments trade in plan and buy a new small car like a VW polo or beetle or a mini ,or better still a citreon C3 diesel ,60mpg on this vehicle think of the saving on petrol and the enviroment
Dec 21, 2009 | 1996 Cadillac Seville CA Value
99 cadillac seville continues to overheat even though i put a new water pump
maybe the water pump wasnt the problem to begin with. if the engine temperature only goes up when you stop the car then most likely it is the FANS that are not engaging to cool the radiator which is a problem with the fan sensor, computer that controls the fans, relay/fuse. I had the same problem on my 1999 cady STS coming back from my vacation. the engine temperature would be normal only when I drove the car above 70km/hr because the air passing through the front of the car would cool the radiator. when I slowed down the fans wouldnt start and no air was passing through to cool the rad, hence the engine temperature would start to go to HOT. good luck.
Jun 02, 2009 | 1999 Cadillac Seville
Car overheating
if you have leaking in the cooling system the engine should ovarheat, first stop leaking.
Oct 24, 2008 | 1988 Mercury Grand Marquis
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
