Error 1 and Error 4 messages on display
SOURCE: shelf cds is blocked SONY CMT-HP7
To get the cds to play, and 5 to eject, you can try taking off the sides of the consul and using compressed air. As for the shelf problem, I'm not really sure.
SOURCE: sony cmt-ep 7070 cd 3
This kind of problem occurs when any loading gear in cd mechanism worn out or broken, this caused mechanism misaligned thus cd loading trays got stuck and mechanism wont eject.
It is bit complicated cd mechanism and professional will repair it.
If you want to fix cd mechanism problem then I can provide you service manual copy that has mechanism timing details, exploded views, part list etc and rest is your own skills/ expertise to get it repaired.
Let me know to upload service manual copy for you if that is required OR take unit in local repair shop and ask an estimate of repair.
Thanks.
SOURCE: Cannot open cd tray. Cannot
In some cases this is due to the main spindle getting jammed or there are mechanical errors which as mentioned needs a reset. Also in some cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
