Question about Apple Performa 5320CD Mac Desktop
How to boot perfoma 5320cd - Apple Performa 5320CD Mac Desktop
    Sergeant:
  • 446 Answers
Hold the power button
Posted on Apr 08, 2014
My maytag perfoma dryer sometimes does not dry my cloths
have u open your unit up and vacume and lint that might be in your unit or use a aire hose me a good strong vacume and see if any loose wires and dont forget too unplug.
Apr 09, 2011 | Maytag Dryers
I placed a small load of clothes in the dryer turned it on and came back to the dryer 5 minutes later and smelled like somthing was burning. I don't believe the dryer ever started. I unplugged the cord...
Normally what happens in this case is the dryer belt snaps. You can test this by turning the dryer on without any clothes in it. If the drums heats up but does not turn/rotate the first thing to check is your belt. You could check the belt yourself if you have the knowhow or the expertise or you could get someone to have a look for you.
Dec 30, 2010 | Maytag Dryers
Hi, my Maytag Perfoma PYE/G200 doesn't dry the clothes in one cycle. It usually takes 2 cycles to get damp dry. Also, the dryer sometimes won't start unless it has been sitting for 10 or 15 minutes and...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Nov 09, 2010 | Maytag PYE2300AY Electric Dryer
How to lift the top of Maytag perfoma PYE3300AYW?
You will only need a putty knife. Unplug the dryer. In between the front panel and top there are 2 clips holding the top down on the left and right side. The clips will need to be depressed one at a time toward the back of the dryer and lift up on the top at the same time. The thermal fuses are both located on the element mounting assembly on the back top of the dryer. They will measure 0 ohms if good. Click this link, schematic diagram, number 3 is a picture of one of the clips. They are located anywhere from 2 to 6 inches in from sides of the washer.
Thank you.
Jan 25, 2010 | Maytag PYE3300 Dryer
My perfoma washer is not working on the last Spin CYCLE
timer bad as far as balance is unit level on flat surface
Jan 18, 2010 | Washing Machines
Water will not fill.
If no water comes in on hot or cold, replace the water valve. That is the valve the hoses connect to.
Mar 21, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Perfoma washing machine won't go through rinse cycle.
Hi
After investigating the logic of the machine and how the timer works, I traced it down to the cold water solinoid rubber stopper It had crud in it and just hummed. After cleaning it out it ran just fine..
This is an easy fix.. If it cant run water it wont go to the next part of the cycle.
I hope this helps. I have more info if required.
Ashley
Feb 07, 2009 | Maytag Performa PAV2200
Maytag Perfoma 2300
check to see if they have rubber washers in them
Jan 28, 2008 | Maytag Performa PAV2200
Apple Performa 5320CD Mac Desktop Logo
32 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
