Atwood t-stat showing L6 code - Heating & Cooling
L6 code on t-stat atwood
high limit blew replace and check burner tube on LP temp sensor and heater element
Oct 29, 2012 | Atwood Thermostat 110V AC 140 92943
I have an Atwood Hot Water Heater, Model GE 16 EXT, 10 gallon tank. It won't stop heating, gas or electric. Replaced the ECO/T-Stat with a new kit. It still will not stop heating. What else can I try?
Start is usually a momentary circuit. It closes a secondary circuit commonly addressed as the run circuit. Secondary. It sounds like the secondary (run) circuit is stuck closed and the thermostat cannot cancel it out when the temp is reached. The primary circuit is generally low voltage, 15vDC controlled by the t-stat and the secondary high voltage (110v A.C., is engaged on signal from the t-stat. You replaced the stat so that is not an issue. The low voltage controls a rela, Large and small wires are connected to this relay. These relays have or are contacts and they do fail. Either they stick or not work at all. Take caution with this relay because it will also make your hair stand on end if attention isn't given to the 110v side. Food Luck and be safe. -Ned
BY THE WAY, a TOWN CAR WITH AN aTWOOD 10 GALLON WATER HEATER?hMMM.
Jul 06, 2011 | 2004 Lincoln Town Car
I want l6 reset code
hi,
Go To Settings -> Initial Setup -> Master Reset-> Code is 000000
esle try 1234
thank you for using fixya have a nice day:-)
Jul 24, 2010 | Motorola Mobility L6 Cellular Phone
L6 code
Hi, this is a 5 ton unit you have. Is this L6 code coming from the indoor units circuit board? If so, remove the panel where you see this if there is a red led light that is blinking. It may kill power if you remove the blower panel as most have a kill switch for safety to shut all down when removed. To have the power on to check things you will need to tape this switch down good. I am not sure on your unit where you see this L-6 code, but on the panel there should be a trouble shooting chart telling you what this code is telling you. I know on gas furnaces they will tell you the problem. If this code is at the thermostat, you will need to go through the manual for programming it and it will say. Is the system cooling good, no problems that you have found? You might do what I have asked and if its on the stat check the manual. If you don't have one, get the name, Model, Serial numbers from the stat and call a appliance parts house not a sales show room, but a place that sell parts and they can look it up on there computer and tell you what the code is for that stat. Unless the unit has stopped cooling completely, I wouldn't worry to much, but would do your best to find out. If you can, let me know where you are seeing this code and how the system is working. This would be helpful for me. Please be kind when you go to rate me as that would be very kind of you. Please keep me posted on this unit. I will be around here if you need more help.
Sincerely,
Shastalaker7
A/C, & Heating Contractor.
Jul 03, 2010 | Carrier 38CKC060 Air Conditioner
What if i delete L1 and how do you get it back
To recover a list you have deleted (NOT the DATA IN IT) press [STAT][5:SetUpEditor]. All lists L1, to L6 will be available again.
Mar 16, 2010 | Texas Instruments TI-84 Plus Calculator
Does the atwood electronic Rv water heater have a temperature setting? Brad
NO. ITS FACTORY PRESET. YOU CAN INSTALL ANOTHER HOTTER T-STAT OR BUY A KIT THAT YOU CAN INSTALL TO ADJUST THE TEMP.
Oct 18, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Atwood. Will not light. Red light comes on and stays on.
A GOOD RV DEALER SUCH AS WHERE I WORK HAVE A BOARD TESTER AND CHECK IT FOR FREE. A DEALER NEAR YOU SHOULD BE ABLE TO DO IT FOR YOU AS WELL. THE SENSORS ARE THE ECO AND T-STAT. NO, THEY CAN'T BE BYPASSED. THE ECO AND T-STAT WORK IN CONJUNCTION BY REGULATING THE WATER TEMP AND PROVIDING POWER TO THE CIRCUIT. THEY ACT AS SAFETY DEVICES.
Sep 24, 2009 | RTO Atwood Water Heater - 6 Gal LP
Under Stat, Edit, only L5 and L6 appears. When I
You've accidentally deleted your lists instead of clearing your lists. Press the stat key and then select #5 (set up editor). You will now be back at the home screen. Now press enter and done will appear on the home screen. All of your lists should now be available.
Jun 26, 2009 | Texas Instruments TI-84 Plus Calculator
I have motorola l6 phone i want to restore it but its unlock code
Manually reset for L6 Phone
hold * 65512890 for reset
hold * 5806 sw version
hold * 487989 NS lock menu
hold * 482896 CP
hold * 574243 NS
hold * 967678 SP
hold * 362628 IMSI
hold * 787090 Lock net level
hold * 787292 Lock net level
here my little trick!
default code is 1234
press menu until the line show 6 digits and enter 000000
done!
Apr 07, 2009 | Motorola Mobility L6 Cellular Phone
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
