Laveuse samsung code E6
No spin
2 Suggested Answers
  • 6277 Answers
SOURCE: Our samsung washer shakes violently
I love these- and don't worry- you are not alone- there are lots!!!
Hi from retired Englishman in SW France
I mostly answer front load problems but ' out of balance' is a common problem with both!
So- I don't know your particular machine but the initial cure is the same.
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine (sorry about my UK spelling!) and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning but I've not had any feedback of this nature.
Good luck,
John C
Posted on Feb 16, 2011
Can you tell me what e6 on the display means as the machine wont work when this shows
Not sure of the make/model, but with Samsung washing machines that usually means 2 things. If you get it when entering the spin mode and the system stops and displays the code, the water heater is heating too quickly. Press the power button once to clear the code and finish the cycle before repair.
If you get the E6 during the spin cycle that can mean a problem with the main controller board.
You can keep resetting to get past that code but if you continue to get it during a spin cycle or part of the laundry where hot water isn't used, then usually that controller board is bad.
Good luck.
Apr 08, 2015 | Washing Machines
Code e6 samsung B1215J
Hiya,
E6 is listed by Samsung as :- Water temperature rising/falling too quickly. Check thermistor.
The thermistor is the temperature sensor, normally a probe located in the heater.
Unplug the appliance, take the rear panel off and the heater is at the bottom rear of the tub. Check the wiring to it and check the heater for continuity.
Apart from these checks you're left with replacing parts on a "fit and see what happens" basis. I'd try the heater and thermistor first.
Hope this helps.
Thanks
Mar 30, 2014 | Kenmore Elite 45986 Front Load Washer
Lg top load washer e6
Oct 21, 2012 | LG WFT1071TP Top Load Washer
I have error 6E on my samsung washer
If during the spin cycle, the error code could be an error with the printed circuit board assembly of the washer. This means that the temperature readings are incorrect and the error will continue to display.
E6 error code indicates that the water heater is heating water too fast. Press the power button once to clear the error and finish the cycle before repair.
Check this link with additional info: original/457.jpg?1285349415
Hope this helps.
Apr 18, 2011 | Washing Machines
Its asking for unlock code i have forgot the code
Samsung Blackjack SGH-I607 Smartphone how to unloack the phone
May 24, 2009 | Motorola Mobility MOTOROKR E6
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
Samsung washing machine B1215J E6 error what is this
I have the same E6 error code and violent movement when in spin. have tried to level and such with the same results. Always acts like it's majorly unbalanced
Feb 08, 2009 | Samsung WF337AA Front Load Washer
Arr?t de la laveuse amana
Code 2E demande l'assistance d'un technicien. Remplacement du module de contrôle électronique. Problème réglé par le vendeur. Excellent service.
Jul 26, 2008 | Washing Machines
Computers & Internet Logo
David Payne
David Payne
