My centreal vacume just turn off by itself
I have can vac it just turn off by it self
    Top Expert:
  • 14,553 Answers
If when it turns off no power at all find the filter to see if real dirty--a lot of these have a filter that will block air flow and the motor cuts off from getting too hot---some have to be replaced but some can be washed.....
Posted on Oct 30, 2012
Kenmore vacume
after turning the switch on, jiggle the electric cord at the vac end, not the plug end.
Anything happen?
Most of the time the cord gets frayed from repeated bending. To fix, you just unplug the vac, cut the cord behind the frayed place, and reconnect it to the switch after removing the housing.
Jan 08, 2014 | Washing Machines
I have an 2003 pontiac grand am replaced the heater core but still blows hot for a bit than goes cold turn the temp knob and it blows hot again for a bit than back to cold
the blending door runs on vacume check your vac lines around the heater to make sure they are plugged in sounds like u turn it and it works for a bit until it loses vacume i believe the temp switch on the dash works off vac too so it might be your problem
Apr 04, 2013 | 2003 Pontiac Grand Prix
No vacuum going to heater and ac control panel
you dont have any vacume at the ball resivore under the hood.. some are located on the hood its self and some under inner fender.. look for a black plastic ball lookin thing with 2 vac lines running to it.. one should be all rubber and one should be plastic with rubber ends.. the all rubber one is the in line follow it back to the engine and see if it is damaged somewhere, if so repair or replace.. one other place i have found problems is under the dash by the dog house or just above the dog house in the center.. improper installation of the house will kink or pinch the vac line and you will not get any vac at the control head
Jul 16, 2012 | 1993 GMC Safari
2003 4.0 V6 explorer with the vacume line off the egr it runs, but runs rough. when the vacume line is hooked up to the egr it cuts off. i put a new egr on and it did the same thing please asap..
First. Check the vacum routing from the egr. facing the engine, the vac.
line should go to the right and connect to the egr vacum regulator
solenoid. The line from the solenoid to manifold vacum. The solenoid
is also connected to the powertrain ctrl. module And some models,
have a egr sensor. the two vac.lines from the sensor(if equipped)go to
the exaust below the egr valve. The three wires from the sensor go to the pcm. At this I would plug in the obd2 scanner if no vac.leaks or
bad connections have been found. This can narrow the field greatly.
You can stop by an autozone/napa etc. they will scan it for free.
I hope this helps. Good luck.
Feb 03, 2010 | 2003 Ford Explorer Sport
Windstar 2000 no vac at the booster-have great vac at the carb. just have regular brakes , no power brakes. don't believe to have a leak or at least one that I can hear engine runs fine
Check vacum at brake booster if you have vacum there bad brake booster, if you don't follow vacum line check there, vacum line should go to intake, if you do have vacum replace vacum hose.
Dec 13, 2009 | Ford Windstar Cars & Trucks
How do i change from leaf blower tovac? vac will only blow i need to cahange it to vac mode
fell on top of vacum for the place where the air is being sucked in that is the vacum port put hose on this port
Oct 22, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Need a vacume diagram for an 86 ford taurus mt5 manual trans
Do you have a Vac leak? easy way to find is to let run and open hood.. buy a can of starting fluid.. sprey around the Vac hoses and when the engine RPM picks up you have found your Vac leak.. hope it helps
Jan 20, 2009 | 1986 Ford Taurus
Self propelled wind tunnel vacum will notpropell itself
Must be a Hoover, The flat belt may look ok but I am sure it has stretched to the point where under load it won't drive the wheels or the brush roll. Could also be a bad brush roll.
Nov 06, 2007 | Vacuums
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
