Question about Acer Aspire 5334 15.6" Hard Drive Caddy With Screws
My acer aspire 5334 will power up but windows will not load how do I fix this issue
Windows start to open but then the screen goes black and nothing.
  • Acer Master
  • 27,725 Answers
Check all connection points on your caddy power and data leads
Figure out whether you need a hardware or software fix.
Look for grinding sounds from your drive or humming that starts or stops.
These are signs that the actuator arm and discs are no longer in alignment and your drive is timing out.
If it seems as though nothing is wrong with your hard drive, it's probably time for a software fix.
Run one of the many software fixes, if you think the problem is related to software.
These programs feature on-screen directions, making it easy for you to progress through them.
If this works, you don't need to fix a physical problem.
Remove the many tiny screws that holds the drive together.
Eventually, you'll get to the innards of your drive.
Be very careful not to bend or force a piece to go where it doesn't want to.
Determine if you've set things straight.
Look to see whether anything was loose inside your external hard drive.
If you have recently dropped it or traveled with it, it is possible that something came loose.
Also check that all the arms and platters are straight and do not appear bent in any way.
If they are bent, straighten them with your hands or pliers.
Put everything back together and check that everything in your external hard drive is working properly.
Try using the external hard drive on another computer.
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers right click to reinstall drivers
if you can see your usb but its not working ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if it still cant be detected or If the hard drive that has failed is the same one that you are trying to recover from might the reason that you are getting this error.
This could be an issue where the part of the hard drive you are trying to access is corrupt and not accessible which would explain the reason that it would let you access the other partition.
Now I have seen cases where Malware can break the link of a Hard Drive.
So let's try a couple of steps.
Let's go back in to "Disk Management"
Lets right click on the partition that you are not able to access and select "Change Drive Letter and Paths"
Now try selecting a new Drive Letter.
This will restore the path if it has been broken.
There are also Data Recovery programs that might be very helpful to recover your important information.
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power
USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling
http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/
these can be purchased on Ebay cheap and easy to install
http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d
for roughly $9 or $10free postage
hope this helps
Posted on Oct 30, 2012
My Acer Aspire V5-571 does not load up it shows acer screen when turning on the laptop then loading floating ball comes on screen for a few seconds then black screen ? can any one please help ?
Hi Jim,
this seems like a no boot / no video kind off issue and mostly is coz of corruptions in softwares or drivers, try booting the computer in safe mode. if it does, then take a data backup. i would not recommend experimenting in this issue as it can crash the computer.
hence call 1-877-805-1027 for expert help.
Aug 18, 2015 | Acer Aspire V5 571-6614 : 1.6GHz Core i5 ,...
Black screen when power on my acer laptop
hi
try to isolate using external monitor,
check connection of lcd cable
replaced lcd panel
Apr 07, 2014 | Acer Aspire 5241 5251 5332 5334 5338 5516...
When i power up my Acer M3400, everything loads then after the 'welcome' windows part the screen goes black and i can only see the mouse cursor? I tried to restart but nothing happens. It keep
Not sure, but try loading Safe Mode by pressing F8 during boot and lowering screen resolution. In Safe Mode you can even run System Restore. It load to a previous date that you choose.
Jan 11, 2013 | Acer Aspire M3400 PC Desktop
My acer aspire 5532 just went black. The power button goes on' but no response whatsoever. Any clues?
Just try this steps
1) Shut down your computer and disconnect the battery and also the Ac adapter which is connected to your laptop, and then once your computer is Off just press and hold power button for at least 15-20 sec and yes do not lift your finger from the power button
2) Reconnect everything Battery as well as your Ac adapter, and try to see if the issue is resolved or not
3) Load BIOS setup Default
4) Try to go to safe mode
5) Do system restore when your computer was working fine
I hope this will answer and fix your issue
Regards
MAJID KHAN
Nov 30, 2012 | Acer Aspire 5241 5251 5332 5334 5338 5516...
I have an Acer Aspire 5517, the power comes on but the screen is black, what can I do to fix this?
open the case and try to remove RAM(memory)if you have just 1,put it to other slot for a few minutes the turn on pc
Feb 13, 2011 | Acer Aspire 5241 5251 5332 5334 5338 5516...
My acer aspire 5520-5334 won't start
Pull The Battery... Unplug The AC Adapter....
Press and Hold The Power On Button For 30 Seconds...
Reinsert The Battery, Plug In Ac Adapter... Attempt to Power On..
Also Try Removing The Battery And Powering Up Using The Power Cord Alone.....
If Still No Power.... Remove and Reseat The Memory Modules...
Still No?
You'll Next Need To Check To See If The DC Jack Is Faulty...
If It's Faulty, You'll Need To Desolder It, Clean The Board, Resolder a New One ON....
Check The Heatsink/Fan Assembly...it might be clogged...
Still No?
Possibly Faulty Video / GPU Chip....Or a Shorted Out Motherboard..
Dec 01, 2009 | Acer Computers & Internet
Black screen and windows won't load
It's possible that Windows got corrupted if you can enter the Setup page. Will you also try to boot up on Safe by pressing F8 during boot up. If Windows loads up on Safe mode, you may try System restore. If not, run a repair using the recovery disc of windows so you can recover all your files. If none of these resolved the issue, you have to do clean installation using the CD.
Jun 19, 2009 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5334 15.6" Hard Drive Caddy With Screws Logo
599 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
