Question about Kenmore 23822 Top Load Washer
Top load kenmore washer
My washer has all of a sudden started making a loud noise when it got to the spin cycle and does not spin. I also checked and it seems that the agitator does not agitate either. Would you please let me know what the probable reasons for this may be & how I might repair it? Also, what is the best way to remove the outer cover (I once removed the back to a washer only to find out I didn't need to!!) Thanks for your help.
I had a similar problem. After taking my washer apart from the back and wrestling it back together. I looked inside the tub and found that there was a nail stuck through one of the drain holes. Removed it! Ans, Voila! It was repaired and good as new!
Posted on Dec 29, 2007
  • 5,911 Answers
Your problem could be a bad gear case assembly (transmission), bad clutch, or a bad motor coupling. The easiest to diagnose and repair is the motor coupling (it's also the least expensive). All, however, will require access to the inside of the machine. This can be accomplished by: FIRST, UNPLUGGING THE MACHINE 1. Remove the console. Depending in the model you have, the console can be removed by removing the two end caps by placing a flat screwdriver in a groove on the top rear and gently lifting up. The end caps should pop off, exposing a philips screw under each one. Remove the screws and the console should lift up and back. If the end caps are not removable, then you need to place a putty knife under the front corner on either side of the console to release the retaining clips holding it on. Once the clips are released the console should lift off. 2. Disconnect the lid switch connector (white plastic plug with three wires going to it). 3. Remove the two brass-colored clips under the console. These hold the case to the washer frame. Once removed, the case should come off. 4. Lift the washer lid and place one hand under the front rim. Lifting the back up first, pull the case towards you and slide off the frame. 5. Check the floor under the wash tub area, first. If you notice any pools, or dripping of oil, then your gear case is probably shot. Once they start to leak, they should be replaced. 6. Now, you will see a small plastic (white or gray) pump with two hoses coming from it. This is the drain pump. DO NOT take the hoses off. Remove the two retaining clips with a flat screwdriver. Remember how they go back on. There will be a keyed slot on the top and bottom that they must go back in. Leave the hoses attached, remove the pump from the drive motor shaft and push aside. 7. The driver motor is attached in the same manner as the drain pump. Except, the drive motor clips usually have screws holding them in place and are a bit larger. In addition, you will need to remove the wire harness connector. Be careful when removing the retaining clips as the drive motor is heavy. Behind the motor is the motor coupling. 8. The motor coupling consists of two plastic triangular shaped pieces with three forks on each one, connected by a round rubber bushing with holes in it. Typically the plastic forks break off, or the rubber bushing rips apart. Also, the center hole of the plastic pieces can round out to the point that they just spin on the shaft. The center hole should have two flat sides and should NOT be completely round. The coupling usually costs less than $10 to replace. The gear case and clutch are a little more difficult to replace and generally are for the more seasoned techs to handle. If you inspect your machine and find that the motor coupling is fine, then let me know and I'll try to give you pointers to further diagnose.
Posted on May 21, 2007
SOURCE:
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
My washer is making a loud nosie when agitation starts
That is a normal sound when the transmission shifts from the last spin cycle to go into the agitate cycle. It should make a loud click sound that does not last longer than a second. There is nothing wrong with your washing machine.
Aug 07, 2015 | Kenmore 24032\24036 Top Load Washer
Loud noise during the spin cycle
Did you have an oil leak at the bottom of the washer? If yes, chances are your transmission oil leaked and your transmission needs changing or repairing.
Jan 15, 2014 | Kenmore Washing Machines
Kenmore washer MOD 110.24422300 SER CP4427442 the washer wont spin, it makes a harsh and loud noise when it comes onto the spin cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 20, 2010 | Kenmore 12502 Top Load Washer
Kenmore top load washer making loud noise in spin
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Apr 02, 2009 | Kenmore 22422 Top Load Washer
Top load washer machine will not agitate
Hi There,
Check to see that the belt is being driven by the motor when it goes into the wash cycle. Let me know if this helps and thank you for using FixYa!
Mar 10, 2009 | Kenmore 24902 Top Load Washer
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore front load washer
My Kenmore front-load washer starts to make the huge noise. The noise happens during the wash cycle, but is mild. During the spin cycle, the noise becomes really loud. It looks like the drum is getting loose and hitting other part of the machine.
I checked the drum, and I can sway the drum easily with my hand. So it looks some supporting structure is broken. I don't know if it is easy to open the washer to check what has been broken.
May 20, 2008 | Kenmore 44072 Front Load Washer
Kenmore 23822 Top Load Washer Logo
514 people viewed this question
Sal De
fordexpert
yobo007
yobo007
