Question about Xerox Phaser 7760 Laser Printer
Problem with Xerox Phaser 7600 Replaced Toner and Still Wants it to be replaced
  • 37 Answers
SOURCE: Xerox Phaser 6110 - what does continuous red light mean ?
Lemmor, without being rude it sounds like you know nothing about this machine at all.
The printer version of this machine has 5 lights in total. 4 of them refer to the toner carts (flashing means toner low, on solid means run out) the other light (the status light) can mean many things. The most common problem people overlook with red status light is that the waste toner bottle is full and needs replacing. It can mean lots of other things depending what colour it is and whether it is flashing or not. These can all be found in the user manual, or if the status monitor has been installed (usb connection) it should show on the PC screen. With a network install, you can browse to the machine using it's IP address to see the error message.
Posted on Jun 30, 2008
jaggujoshi
  • 119 Answers
SOURCE: i have refilled the xerox phaser toner it is
Dear,
Is there any chip identifier for that toner. If there you have to change the chip. Otherwise yiu refilled wrong toner posder for that toner.
Cheers
Jaggu
Posted on Oct 18, 2009
nakshatraipu
  • 241 Answers
SOURCE: Hello, how to reset toner cartridge for xerox
Through Module we can resetted Xerox 3100 permanently.
www.nakshatraworld.com
Posted on Dec 31, 2009
SOURCE: need solutons for xerox phaser
need solutons for xerox phaser 3100 after refill message toner empty. how to reset and usr this cartridge
Posted on Mar 26, 2010
  • 525 Answers
SOURCE: on Xerox Phaser 3100mfp., after
when you refill the cartridge you got to put a card {seem like a credit card} to reset a counter of the printer. the slot of card is in bottom of control panel {panel with buttons}
Posted on Jan 19, 2011
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Program to reset unit imaging xerox phaser 6110 please
Image units can't be reset by software. There is a chip that needs to be replaced on the cartridge if you refill it with new toner. It should be available from the same place you got the toner. (I assume you refilled it and it still says it is out of toner)
Dec 01, 2011 | Xerox Phaser 6110 Laser Printer
Xerox phaser 7400 replaced yellow toner, but still getting replace toner error. I've reseated it twice, reseated the imagining unit and tried turning it off.
You can try do a NVRAM reset. If after that you still have the error message then I would tell you to contact the Xerox team as you might have a wrong consumable (defected/wrong CRUM) information.
NVRAM reset: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=36,E=0000000002092637520,K=9394,Sxi=5,Case=obj(3085)
May 16, 2010 | Xerox Phaser 7400/N Printer
Xerox Phaser 6300DN is printing light black on right side of paper, replaced toner, transfer unit, imager with no luck
The laser window probably has either some toner or dust on it and needs to be cleaned. It will be under a shutter located in line with the drum.
It is less than 1/2 inch high and about 6 or 7 inches wide.
Clean that and your problem will go away.
Mar 25, 2010 | Xerox Phaser 6300DN Laser Printer
Xerox - replacement toner cartridge problem
Not that I know of. Did you receive a chip with the toner? If not that chip would need replaced to reset the counter;
Feb 20, 2010 | Xerox Phaser 6125 Laser Printer
Problem with Xerox Phaser 6110 black toner.
Yeah it is a problem with the chip that is on the cartridge. You can go to the Xerox.com site and contact them directly by phone or e-mail.
Just once at the xerox.com site, select your country.
Jan 06, 2010 | Xerox Phaser 6110 Laser Printer
We have a Phaser 7400. It continues to give us
If you've already changed out the toner cartridge and the problem persists, then it could be several other parts that are either defective, dirty or blocked.
You may want to contact a certified Xerox technician and have them look at the Imaging Unit Agitator Bar and the Low Toner Sensors for Cyan/Magenta. There could also be a faulty toner supply motor.
Sep 10, 2009 | Xerox Phaser 7400/DT Laser Printer
Need solutons for xerox phaser 3100 after refill message toner empty. how to reset and usr this cartridge
Aug 08, 2009 | Xerox Phaser 3100MFP/S Laser Printer
Xerox Phaser 6250 yellow line at far left of page
Sounds like it is time to replace the imaging drum. This is a consumable and usually done every 15-20k pages. Cost is about $250-300 and very easily replaced, fast as changing a toner.
I am assuming that you tried changing the yellow toner already? If not, do that first...
Jun 18, 2009 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 7760 Laser Printer Logo
56 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
