Question about Toshiba MD13P3 13 in. TV/DVD Combo
No remote need to program from front buttons - Toshiba MD13P3 13 in. TV/DVD Combo
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
Toshiba does not make this unit--it has their name---all programming is done from remote via the main menu---Google the model number or call Toshiba to get an original remote---they are not real expensive for this brand in most cases.
Posted on Oct 30, 2012
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
https://www.mydish.com/support/remotecodes
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
https://www.directly.com/.../dish-network-my-dish-remote-needs-progra...
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
https://www.directly.com/.../dish-network-how-do-i-program-my-dish-re...
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
Remote doesn't control on/off,volume or channels
Remote won't workThe most common reasons the remote won't work is that the batteries are dead or it hasn't been programmed properly. It's often easy to fix. Here are the steps to take to troubleshoot the problem.
Make sure you have a clear path between the remote and the infrared eye on your equipment. Clear any dust or debris that may be covering the eye.
Try unlocking the battery-saving mode. When a button is pressed for longer than three minutes, the remote goes into battery-saving mode. Press the SAT mode button at the top to unlock it. Your remote should work properly.
Check the batteries. When you press a mode button, does it light up? If not, you may be out of juice. Check to make sure they are in the right way, with the metal ends making good connections with the metal in the remote. If they're in correctly and you still don't get power, try replacing them. They may be dead.Learn about batteries
Check to make sure the remote is programmed properly, which basically means you reprogram it to work with your receiver, TV and any other components. Start with the receiver and work your way through programming each component that isn't working. We tell you how to program remotes in our guide to remotes.Learn about remotes
Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.Be prepared to tell us:What components you have.All of the steps you've been through to try and solve the problem yourself.Can't change channels on receiverThis is almost always caused by a programming problem with the remote. Here are the steps to take to troubleshoot the problem.
Make sure you are in SAT mode. The receiver will only change channels when the remote is in the correct mode.Look for a timer. If you have a timer set, the receiver won't let you change channels. This ensures you don't miss recording a program with an external device. If a timer is set and you want to watch another channel, simply turn off the receiver and turn it back on.Learn about timers
Make sure the problem is with the remote and not the receiver. Try the buttons on the front of the receiver. Try to change channels. If your model doesn't have channel buttons, try to turn the machine off. If you can't change channels or power off, the problem is with the receiver. Try unplugging it for two minutes and plugging it in again.
If you can change the channels or power off, the problem is with the remote. Press any mode button on the remote. It should light up. If not, you probably have low batteries. They should be replaced.
Try unlocking the battery-saving mode. When a button is pressed for longer than three minutes, the remote goes into battery-saving mode. Click on any of the mode buttons at the top to unlock it. Your remote should work properly.
Try re-programming the remote to talk to your receiver.Find the manual for your remote control
Check to see if your Shaw Direct Receiver is using the same remote control address as your remote control.If you are using the DSR 319, HDDSR 505, or HDPVR 530 receiver press the Options button on the front panel of your Shaw Direct receiver. An options menu should appear on your screen. Using the direction keys on the front of your receiver navigate to 6 - System Setup and then press the Enter button on the front panel of the receiver. Using the same directional and Enter buttons go to 4 - System Setup. Then 3 - Installation Settings. Followed by 2 - Remote control Address.If you are using a legacy receiver such as the DSR 315, DSR 405, or any other receiver with front panel buttons, press the Options button on the front panel of your Shaw Direct receiver. An options menu should appear on your screen. Using the direction keys on the front of your receiver navigate OPTIONS and then press the Enter button on the front panel of the receiver. Using the same directional and Enter buttons go to 6 - Change System Settings. Then 3 - Change Installation Settings. Followed by 2 - Set Remote Control Address.Follow the on-screen instruction to reset the remote control address on your receiver and remote control.Check the back of your remote, if you own the IRC/URC 550 or RT-U50 remote controls you will need to enter the remote control address differently from what is displayed on screen. To program these remotes, hold the ENTER and MUTE button on your remote at the same time until the mode buttons at the top start to illuminate then enter the last three digits of the number displayed in "Current Address" column on the screen, then press the MUTE button to lock in the code. For example: If the remote address on the screen displays 0002, you would hold ENTER + MUTE until the mode button illuminated and then enter 0 0 2, followed by ENTER on your remote control.If you own the IRC 551 or URC 551 remote control you can follow the instruction depicted on the screen, but you must substitute the follows numbers in place those specified: 00869 for 0000, 01870 for 0001, 01871 for 0002, 01872 for 0003, 01873 for 0004, 01874 for 0005, 01875 for 0006, 01876 for 0008. For example: If the remote address on the screen displays 0003, you would hold the SAT button until it flashes, press 01872, then ENTER, to lock in the new code.Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.What components you have.All of the steps you've been through to try and solve the problem yourself.Can't control TV volumeThis is almost always caused by a programming problem with the remote. Here are the steps to take to troubleshoot the problem.
Press the volume button on the remote. The TV mode should light up. If not, you probably have low batteries. They should be replaced.
If the SAT button lights up, you are in the wrong mode. Press TV and try again.
Try re-programming the remote to talk to your TV.Find the manual for your remote control
Still no go? You may have an internal problem with the remote. You'll have to talk to a Shaw Direct customer service representative. Call 1.888.554.7827.What components you have.All of the steps you've been through to try and solve the problem yourself.Thank you for using Fixya, Hope this will help your problem.Don't forget to rate me.thanks,Reymond
Oct 18, 2011 | JVC AV-27850 27" TV
How to take my viper remoter off vabration. a where can i find the manual for the viper remoter
To enter programming mode Press the Program button on the back of the remote or hold the four remote control buttons on the front of the remote simultaneously until one long beep is heard. Programming Mode has now been entered.
Beep/Vibrate Mode Within five seconds of entering Programming Mode, press Lock. The remote control will beep once for on, twice for off. The vibrate icon (13) will also turn on/off with each press.
Here's the owners manual for that system: http://www.directeddealers.com/manuals/og/viper/G5301V_05-06post.pdf
remote programming starts on page 15.
Mar 25, 2011 | 7701V Responder SST Remote
Programming remote, unit will not flash.
The easiest way to program is to hold the button on the remote while you press and immediately release the smart/learn button. If it worked before there is no reason for it not to work now unless it totally failed.
Oct 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
I need to program my new dishnet work remote
Turn the receiver off using the front panel power button and then press the channel up button and hold it until the unit powers on. This will bring you to the system info screen. There you will see the remote address the remote needs to be programmed to- usually 1. Now press and hold the SAT button on top of the remote until all buttons on the top lite up and release. Now key in the two digit number shown on the screen - numbers under ten will be preceeded buy a zero. Now press the pound sign on the bottom right of the keypad. The SAT button will flash three times and then you will need to press the record button . YOU SHOULD BE ABLE TO MANUEVER THE HIGHLIGHT ON THE SCREEN AND EXIT OUT OF THE SCREENS . Thanks for using Fix Ya. ---and if you can not bring up the system info screen perform the steps on the remote itself until you reach the correct number that will control the receiver- 01 thru 16. if you need further assistance please let me know.
Mar 28, 2009 | DISH Network 301 DTV Receiver
Program garage door opener.
press the two outside buttons at the same time. Hold while message reads "clearing codes"
Once you get a cleared message. hold the button that you want to program as your remote and press it down. The light will flash slowly. Take your remote in your other hand and hold it about 3 inches from your review mirror as close to the windsheild as possible. You must do this as soon as you press your designated button on the panel. Hold until your green light starts flashing fast. Once it flashes fast it means you have programmed your button properly.
Suggestions - do not do this in front of your garage as you remote will make you door go up and down the whole time. Also - make sure your batteries are new in your remote so you get a good signal to your button. Last thing - if one remote does not work after a couple of tries - use another remote.
Mar 25, 2009 | 2005 Cadillac Escalade
2001 XJ8 keyless remote programming
This is the procedure from the service manaul:
JAGUAR
XJ8 Remote Control Programming
1. Unlock the Boot/trunk with key.
2. Turn Ignition on.
3. Warning light on dash comes on.
4. When they go out, lift arm rest, inside their is a valley button, Press 5 times within 5 secs of lights on dash going out, Horn & Lights Flash.
5. Press any button on remote, remote programmed.
Jan 16, 2009 | 2006 Jaguar XJ8
Need to program my chamberlain #953CB from a working gate opener
the chamberlin remote only work with a chamberlin reciever, if you have this it will be a silver box that looks like diamond plate material inside you operator, take of the front cover on this box and you will see a black button that says program push and hold this button down then push your remote button down while holding it close to the box you will see a yellow led flash and then it is set. if you only have a single button remote you will only be able to set it to one operator.
Nov 26, 2008 | Chamberlain 950CB Remote Control
Don't Know how to program Dish satelite or tv with my remote.
to program the dish remote to the receiver you need to access system info, if there is no system info button on the receiver turn the receiver off and press the up arrow on the front panel, then press record on the remote, to change the remote address hold down sat until all buttons illuminate, enter number between 1-15, press pound sign, then press record
to address a remote to the tvyou need the remote code for that brand or you can do a power scan
Jul 20, 2008 | RCA DISH Network(r) 311 Satellite System
Toshiba MD13P3 13 in. TV/DVD Combo Logo
69 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
