Question about Jenn-Air Ovens
Jenn-Air model # W156B oven problems
Wont heat on "bake"
catriver
  • 878 Answers
SOURCE: Jenn Air wall oven-Broiler element comes on and will not turn off....
Boone, by the sound of your post it sounds like the power relay board could be bad. If you had a stuck or shorted keypad, you should be getting a different code. The F2 code means an overheated condition. If it's a double oven it could mean a secondary board failure. The way to go on this would be to ohm out the temp sensor first. Should read about 1100 ohms at room temp. Another way to check it is to swap the bake and broil wires on the power relay board. They will be marked BA and BR. Fire the oven up again and if the bake element comes on then you know that the broil relay is stuck or shorted. Without being there to do the tests, I believe that the problem lies in the power relay board. The part number for the board is 71003431. Priced around 116.00. Jenn-Air usually has a 5 year warranty on these parts. Hope this points you in the right direction. Catriver..post back
Posted on Apr 10, 2007
the dr
  • 447 Answers
SOURCE: Jenn-Air w156 Single Wall Oven Problem
Most likely its the EOC (electronic oven control), it needs to be replaced. If you self cleaned the oven a lot the very high heat generated fatigues computers in modern ovens.
Posted on Sep 28, 2007
  • 1314 Answers
SOURCE: jenn-air expressions 27" convection wall oven model wm27460 won't heat
reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Posted on Dec 29, 2007
SOURCE: Jenn Air w30400b with F2 code
Since the elements are working fine, the thermostat seems to
be in question or, the contacts and connections to the thermostat
are loose etc. This seems to be a controller / temperature thermister problem and since it is intermittent, it might just be
bad contacts in that area of the circuits. see this description below.
INGLIS Royal 100 STOVE F1 F2 F3 ERRORS
Mode lUP 48500 ( thats eye you, not ONE U )
I got the dreaded F3 error on the Display Panel,
every time I pressed BAKE or BROIL, BUT, I could
hear the three relays click in, and then kick out in
sequence, just before the F3 appeared.
I called Westinghouse ( that services INGLIS ) and
was told that F3 " means unpug for 1/2 hour and then
press CLEAR 5 Seconds to reset ". Which is nonsense.
All functions on the clock and timer work fine, and the
three relays were working, so its not a computer problem.
I called service REPAIR companies who said it was the
THERMOSTAT, and replace it - $147.99 ... The Glass tube
of the display is $200 with no circuit board, the relay board
is $300 and the computer/display is $400.
I did tests on the thermostat, first heating it with a propane
lighter, and it raised from 475 Ohms at room temperature,
to 600 ohms, so I knew it was functioning.
Then, I plugged in a variable resistor where the thermostat
plugs in. I went from Zero Ohms resistance to 5000 Ohms in
200 Ohms steps.
Zero Ohms ( equal to burnt out or unplugged) gives you
an immediate F1, which you cannot clear.
From 100 Ohms to 400 Ohms, you get Error F2, which
means thermostat too low.
From 400 Ohms to 665 Ohms there is no error.
At 665 Ohms, the BAKE will beep twice, stating that you
are setting the temperature at or lower than the actual temperature
of the oven ( you cant set the oven at 200, for example, if it is
already at 450 Degrees )
Using this 2 Beep code, I raised and lowered the resistance
and made a graph of the reading on the display versus the
OHMS that the thermostat would send to the controller:
665 Ohms = 170 Degrees Farenheit, which is the
lowest reading in the BAKE MODE.
800 Ohms = 240 Degrees
1100 Ohms = 380 Degrees
1400 Ohms = 500 Degrees, which iis the maximum that
the unit showed in the BAKE MODE.
1430 Ohms to 2750 Ohms, there was no reading, an NO ERRORS.
ABOVE 2750 OHMS, the F1 ERROR appeared again, meaning
thermostat out of range.
Note that the computer module supplies 5 volts DC to the thermostat,
to see the changes in current with changing resistance.
You can easily check the thermostat to see if it is OK, with an
Ohmeter across the thermostat, which should read about 475 Ohms
at room temperature. If it reads Zero, it is burnt out. If it reads
over 2750, it is defective. Check to see if the thermistor in the
tube is SHORTED to the steel outter case as well, as this should be
infinite ohms ( no contact )- if it reads ZERO it is shorted to case.
I found that on the Internet, there are hundreds of people looking for
the F3 code for the ROYAL 100 ( model number IUP 48500 )
and a general search shows that for 400 " other" models of all kinds,
F3 = REPLACE THERMOSTAT ! Not on this model, and all typical searches
for technical support or diagrams or troubleshooting did not even list
the Royal 100 AT ALL, as if it never existed.
I then did tests on the relay board, and replaced the capacitors, a few diodes,
some resistors that were a bit out of value, and two transistors that were
a bit out of value. There was no change in F3.
I cleaned the contacts on the three relays using a typical board fingernail
file that ladies use for their finger nails ( I keep a supply for cleaning
relay contacts, since there is sandpaper on both sides, and they are
tiny enough to fit between most contacts ). THEN, I realized that the BROIL
contacts were bouncing apart - they were too far apart, and not closing
properly, so I bent the stationary contact a bit closer, and plugged in the
stove = NO ERRORS..
I analysed the circuit, and after turning on the 3 relays ( NOTE, when you
turn on BAKE, as in a regular oven, THE BROIL ELEMENT goes on at first
to quickly help the BAKE element get the oven up to temperature )
there is a feedback circuit that feeds 250 Volts back into the 5 Volt computer
chip ( ! ! ! ) It uses two 22 Meg Ohm resistors in series for a total of 44 Million
Ohms, which shows about 46 volts accross the resistors. Since the gas
tube display uses 30 volts to light up, the 46 volts is within the computer
board's ability to lower it enough to feed into the computer. There are transisors
on the back of the control board and Zener diodes etc. to " compare " the
voltage, where 46 volts in = 250, and Zero volts, means that the element
is burnt out, the element fuse in the fuse panel is burnt out, or, the relay
contacts are dirty. The relays are absolutely standard 24 volt relays,
with a plasic cover that snaps off if you pull and wiggle it. You will see
the round silver contact pads are blackened and probaly pitted.
Sand these flat until silver/brass shiny, and test to make certain that
when you press the metal lever that the magnetic coil pulls DOWN,
that the contacts touch! If they do not touch tight, bend the
stationary contact in a tiny bit and test again.
You can first check the fuses - there are two 120 volt fuses in the
fuse panel that give you 250. Then, you can unplug the stove,
and use an OHM meter to see if the element is burnt. The two types
of elements I checked were 3000 Watt at 18.7 Ohms, and 2500 Watt,
at 48 Ohms. If the elements are burnt out, you will get ZERO ohms.
If the element is burnt internally through the insulation in the tube,
and shorting to ground, between the ends and the steel back of the
stove ( ground) you will get a reading of X amount of ohms ( which
normally should be ZERO ) If the element is burnt or shorted to
ground, replace.
The F3 error is a really dumb mechanical errror of whether the 250 volts
is on the elements. It does not involve the computer or the thermostat,
or the relay " electronics" at all - it is just simply 3 contacts that supply
250 Volts, and whether or not the contacts work, the elements work,
or the fuses work. This the same 250 Volts that is on an ordinary
dial stove, and the dumbest part of the whole unit.
When I called service, they said they would order the $147.95 temperature
thermostat, and " see if this fixes the problem", if not they would start
replacing the modules - $300 and $400, plus labour, plus tax etc., and
since the problem was on the module, this would cost $147.95 + $300,
plus $75.00 for the first 15 minutes, and $15 for each additional 15 minutes,
for a total of about $466 dollars ( CDN ) which is about $460 dollars US.
A package of 25 fingernail files is $1.00 at the dollar store. That is all that
it cost to fix the problem. You need a square ( Robertson ) head screwdriver
to remove the 7 screws on the back panel, and then you wiggle the
covers off the relays, and clean them. It takes 10 minutes.
good luck ! Damned the manufacturers for not putting this information
in the user manual.
Robin Graves, January 2008, kidbots.com
Posted on Feb 01, 2008
tzweeb
  • 318 Answers
SOURCE: Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Posted on Jan 22, 2009
My old Jenn-Air W230 wall oven only gets to "warm" in the bake position - even at a temperature setting at 500 degrees. However the broil function works well. Could the problem be a bad thermostat o
the oven sensor could be bad,its a small rod inside the oven cavity near the top,or you could have a bake element with a "hot-spot" in it that can no longer pass enough current to properly heat the oven to the correct temperature setting(most elements with a hot spot will show a discolored area on the element where its been overly hot)this is the "hot-spot" it will soon break apart there
Nov 30, 2012 | Jenn-Air Ovens
Model: JDS8850AAS -- Oven won't preheat above 150
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
Hope this helps
Gene
Aug 02, 2011 | Jenn-Air Ovens
Broiler comes on and burns food when oven in bake mode
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Mar 28, 2011 | Jenn-Air Electric Double Oven
Older jenn air wall unit oven / turn knob
Yes, I just had same problem. The probe receptical is on the right inside wall of the oven. A little flapper door is secured by a single phillips screw. Remove this screw and the flapper door. Gently remove the receptical and its attached cable adapter. With your screw driver short the connector extension to the housing, just as the probe would. This should reset the meal temperature sensor. Try the bake and problem should be gone. If not permanently short this connection with a wire. You won't be able to use your probe, but the oven will work.
Feb 23, 2009 | Ovens
Jan 22, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn air bake element problem Model SVB46800w
At the family house we had an old counter top Jenn-air appliance and the connectors for the elements always burned until i put white sillicon grease on the contacts.This grease is intended to transfer the heat on transistors. Never had problem again.
Jul 29, 2008 | Jenn-Air Ovens
Jenn-air expressions 27" convection wall oven model wm27460 won't heat
Dec 27, 2007 | Jenn-Air JJW8530C Expressions Collection...
Sep 28, 2007 | Jenn-Air JJW7530DDS Electric Single Oven
Oven bakes unevenly and burns food
When foods are burned, soggy, or baked unevenly, it generally means heat isn't being distributed evenly throughout the oven, its escaping out the door or the controls are out of adjustment. 1) Remove any aluminum foil from racks or the bottom of the oven. 2) Check the door gasket and, if necessary, have it replaced. 3) Be sure nothing is obstructing the vent. 4) Reposition the oven racks so baking pans aren't too close to the heat sources. 5) Check your baking pans. If they're dark, they may be burning your food. Reduce temperature by 25 degrees F when baking in dark metal or glass pans. 6) Recalibrate the controls.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
