Question about Haynes Ford Full-size Vans Repair Manual covering Econoline E-100 thru E-350 with gasoline engines for 1969 thru 1991
My 94 econoline van wont stay running - Haynes Ford Full-size Vans Repair Manual covering Econoline E-100 thru E-350 with gasoline engines for 1969 thru 1991
Bad gas maybee? Use gas treatment and change fuel filter i would try the most inexpensive solution first
Posted on Oct 29, 2012
  • vanna_hamilt
    vanna_hamilt Oct 29, 2012
    The serpentine belt came off we fixed it.it ain't ran since...we replaced.the coil..the fuel filter...the oxygen sensor.and it would start but if you try push the gas it'll die
How to do a tune up on a 1999 econoline v8
If you could be a little more specific as to what model Econoline do you have?
I found a list of DIY's for the econoline and have assumed that yours is a 250. Go through this diy for helping you work on the van without any difficulty. Be it changing the spark plugs or regular maintenance work or even overhauling!
http://www.automotix.net/autorepair/diy/1998-ford-e_250_econoline-repair.html
Feb 27, 2013 | 94-00 Ford Econoline Van Side View Mirror...
94 Econoline Van Overheats when under load but drives fine when it's not.
Radiator could be blocked or partial. Best way I check for that is to use a temp laser gun and check the fins of the radiator for temp differences. And has stop leak ever been used?
Feb 22, 2013 | 1994 Ford Econoline
94 caravan changed altnator now wont stay running
Hi James, Check the air ducts and vacuum hoses. I think maybe you pulled off something while doing the other work. If all are fine then check the up idle motor and replace it if need be. Regards John
Jun 16, 2012 | 1994 Dodge Caravan
I have a 1984 ford e van, 351, 4 barrel, i can leave it in the laneway running and wont stall, when i take it on the road, the van loses power, then stalls, and the battery is dead, i unhooked the battery...
sounds like you have a fule pump fault,,,the battery fault is strange??
unless the pump has a short on it, draining the battery,,,
the alternator will very soon pack up if you keep running it without the battery hooked up
Aug 08, 2010 | 1984 Ford Econoline
Fuse box ford econoline diagram
fuse box diagram for 94 econoline 250 van
Jul 23, 2010 | 2002 Ford E250
Where is the vacuum modulator located on a 1994 Ford 5.0 econoline van
This particular van should not have a vacuum modulator. That part is located on the transmission and controls shifting which is electronically controlled on the 94 models.
Dec 13, 2009 | 1994 Ford Econoline
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
See all Haynes Ford Full-size Vans Repair Manual covering Questions
Haynes Ford Full-size Vans Repair Manual covering Econoline E-100 thru E-350 with gasoline engines for 1969 thru 1991 Logo
76 people viewed this question
Top Haynes Heating & Cooling Experts
gbob59
Mike
Lawrence Oravetz
Are you a Haynes Heating and Cooling Expert? Answer questions, earn points and help others
