Question about D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point
Cann't access the IP address that dlink instructs me to type in m
I have a dlink DWL-G700AP. The 1st thing it asks me to do is type in 192.168.0.50, to start the setup wizard. ????
  • jochum Jan 03, 2009
    The 192.168.0.1 took me to a screen, but it wasn't dlink. The other IP address went no where.
  • Anonymous Mar 03, 2009
    first I set up the d links and after it said that the internet is local. when i finally got it it goes to comcast web and it doesn't let me use the web...
  • 61 Answers
Try 192.168.0.1 or 192.168.1.1
Posted on Jan 03, 2009
Wizard admin dap. i reset the dlink airplus xtreme g dwl 2100ap but i cannot get into it with the default ip that is 192.168.0.50
Connect your computer to the router.
Under Windows 7, click the "Start" button.
Type 'cmd' into the search-box, and press ENTER.
Enter 'IPCONFIG /ALL'.
Look for the IP-address of the "gateway" (or "DHCP-server").
Type that IP-address into your web-browser.
Dec 11, 2013 | D-Link AirPlus Xtreme G DWL-2100AP...
Connecting wireless router to server
If routing and remote access is enabled on the server, it should handle the bridging automatically between the two nics...
Otherwise, simply turn off the DHCP in the router, have the server and all the clients connect to the LAN ports, and they will automatically get their address from the server. In this scenario, you don't need to worry about the WAN port on the router.
But you might want to think about using the WAN port on the router to provide an added layer of security rather than exposing your server directly to the internet. You can set up all the port forwarding you need on the router.
More info here:
http://www.dlink.com/us/en/support/product/dwl-g700ap-high-speed-2-4ghz-802-11g-wireless-access-point
The manual is here:
http://www.dlink.com/us/en/support/product/-/media/Consumer_Products/DWL/DWL%20G700AP/Manual/DWL_G700AP_Manual_EN_US.pdf
You need a pdf reader (adobe) to read the content.
Good luck.
Nov 18, 2012 | D-Link DWL-G700AP 802.11g/b Wireless...
Can I use the dwl-g700ap as a repeater?
Yes, the DWL-G700AP can be setup as an AP or a repeater as long as your current wifi router is also 802.11g/b.
You can find instructions here: http://www.docstoc.com/docs/2583739/How-do-I-configure-repeater-mode-on-DWL-G700AP
Regards, Chris
May 18, 2011 | D-Link DWL-G700AP 802.11g/b Wireless...
How can i find the ip address of my Wireless Access Point device? (model DWL-G700AP)
Hi, here's how you can find your access point's IP address:
The access point is also your default gateway, because it's the device that you use to access the Internet, right? Open up a command prompt window (go to the Start menu, click on Run, type "cmd" and then hit Enter) and type "ipconfig" and hit Enter.
A bunch of information will appear. The one you want to look for is the one called "Default Gateway." The IP address that appears following "Default Gateway" is your access point's IP address.
Please rate this solution based on how helpful it was. (If you still can't find the IP address, add a comment and I'll be happy to reply.)
Sep 18, 2010 | D-Link DWL-G700AP 802.11g/b Wireless...
Unable to reset my DWL-G700AP by holding in the reset button and can not connect to or ping via 192.168.0.50
Under Windows 7, press the "Start" button.
Type 'ipconfig /all', and press ENTER.
Look for the IP-address for the "gateway" (or "DHCP-server").
Jun 22, 2010 | D-Link Air Xpert DWL 7000AP (DWL-7000AP)...
I cant istall dlink dwl 2100 acess point.prescribed site is not opening
be sure to check every point on this TIP
to connect to "prescribed site" (I assume the default router IP address 192.168.0.1) you must be on same subnet and connect using a cable to router.
Consult Quick install Guide
or follow user manual Page !0 instructions:
First, disable the Access the Internet using a proxy server function. To disable this function, go to Control Panel > Internet Options > Connections > LAN Settings and uncheck the enable box.
Open your web browser program such as Internet Explorer. Type the IP address of the DWL-2100AP in the address field (http://192.168.0.50) and press Enter. Make sure that the IP addresses of the
DWL-2100AP and your computer are in the same subnet.
If you need help in the matter let me know and I'll send you instructions
Jan 24, 2009 | D-Link AirPlus Xtreme G DWL-2000AP...
But the DWL-G700AP...
Is this access piont connected to a router? Can you get online through the router? If you can go online through the router also check the status of your wireless connection. Make sure its connected and it's getting a valid ip address.
Aug 22, 2008 | D-Link DWL-G700AP 802.11g/b Wireless...
DHCP option is disabled when LAN IP is Dynamic on DWL-G700AP
that is right the access point does not have a dhcp server. that will give an ip address to all of your computers or device connected to it wireless. If you have a modem with a dhcp server there will be no problem with the IP but if the modem does not you must have a router and now an access point.
Aug 07, 2008 | D-Link DWL-G700AP 802.11g/b Wireless...
D-Link DWL-G700AP Access Point
You need to connect the access apoint directly to a pc with a CAT5 cable then set up a static ip on the pc which I assume you know how to do it, for the static ip put 192.168.0.5 subnet is 255.255.255.0 and gateway is 192.168.0.1 then save the settings, then check first if there's a good connection between the access point and pc, go to the command prompt then type PING 192.168.0.50 if you receive 4 replies go now open the http://192.168.0.50 if you receive 4 request time out reset the access point and and ping it again if still 4 request time out after you reset it replace that access point.
Jun 06, 2008 | D-Link DWL-G700AP 802.11g/b Wireless...
D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point Logo
656 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
