Question about Jandy Aqualink Pda Ps4 Wireless Handheld Remote Control System Pool and Spa Combo
Jandy remote control will not turn on even with brand new batteries
The battery signal went from low to the unit completely turning off, so I assumed that new batteries would fix the issue. I have tried 2 sets of new batteries (verified polarity correct) and the unit will not turn on. It's approximately 5 years old. Any suggestions?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
Need new remote
Posted on Sep 25, 2014
4 Suggested Answers
thepool
  • 78 Answers
SOURCE: Jandy Lite 2 heater gives FL4 display
F is an igniter failure. Try the following. A. Check fuses on igniter wires. Identify and correct loose connections or broken wires. B. Measure room temperature resistance and ensure value is in the correct range. C. Replace igniter.
Posted on Apr 22, 2010
adamh294
  • 310 Answers
SOURCE: Have a 3.5 year old Jandy Aqualink RS 4 --- the
It is most likely not a bad reading on the on the display.
One culprit of a false temp reading could be:
If the temperature sensor is installed after the heater and the circulation pump is clogged or failing, this would allow super heated water to reach the temperature sensor and give you that reading. However, most pool/spa heaters have a high limit switch that would shut down the heater @ 150 degrees F. So this is also unlikely.
The most reasonable answer is to replace the temperature sensor.
If you refer to page 22 in this manual http://www.jandy-downloads.com/pdfs/Allbutton_manual.pdf
you will see that the temperature sensor is installed on terminals 5 and 6.
Trace these wires. They will goto a thermowell (which holds the temperature sensor) either in the pool plumbing, or to a temperature sensor in the heater itself. Temperature sensors when in the heater are located typically above the inlet/outlet header. There will be some disassembling required to access it in this case.
If it is in the heater and you need more help, e-mail me @ adamh@newconceptchem.com
Please take the time to give me a positive rating on this post if I have helped.
Thanks
adam
Posted on Nov 02, 2010
Testimonial: "Thanks for the prompt response. I'm at work now but I will follow your instructions when I get home. I had a feeling that it is a 'bad' sensor. "
  • 368 Answers
SOURCE: Pump will not run.
If the motor hums when you try to start it then do the following; Remove the cover on the non-pump end of the pump. This should give you access to the motor shaft. If it is hard to turn then it may be a bearing or some other problem causing too much friction for the motor to start. If you can turn it with your fingers then the next thing to do is find the capacitor and write down its value. It might be something like 30 UF with a voltage like 377 VAC. Find an electric motor store or pool store that has one or can order one for you. Install it and if the motor runs then you fixed it. If it doesn't run then it probably needs to be replaced. It is possible to replace the motor for less than the complete pump. I hope this helps.
Please vote on this answer. Thank you.
Posted on Aug 23, 2011
My MX-900 Universal Remote Control is completely draining new batteries after just 4 days (with minimal use). The remote is 6 years old and has never had this problem before.
There should be short circuited component/s inside the remote control. It will be good to buy a new one, rather than try to repair this remote control.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
Nov 10, 2015 | Universal MX-900 Remote Control
I turn the on switch on the remote control and ready to fly. The heli starts for about two seconds and shuts down?
I have a Hercules "unbreakable" helicopter that shows that"shut down" sympton when the battery is low. I assume it does that to prevent the battery completely dying while in flight.
Feb 23, 2013 | RC New 3 Ch Co-Comanche RAH-66 Helicopter
My Jandy Link control panel model 8157 turns on spa by itsself. It is not programmed to do so. Its says low battery. Can thisbethe cause?
No. Make sure there are no programs for the spa. Double check this. I assume this is a pool/spa combination. If so, check the valve actuators at the pool equipment. Do this by manually turning on the pool with your Remote control unit. There should be no water disturbance in the spa. If so, your valve actuators need to be reset. There is a metal toggle switch on the back of each valve that you can switch to set the valves to pool or spa.
*********** board at the equipment may also be the culprit. Try resetting it by pressing the small recessed reset button on the front of the panel with the tip of a pencil or pen. If neither of these slove your problem you probably need a new mother board. They are very expensive. Check to see if yours is still under warranty. Your builder can tell you this or you can email or call Jandy with your model and serial number found on the back of the board. Good Luck
Apr 18, 2011 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Fan works but compressor does not start. Its a brand new unit
Hi!!
By fan woks you mean inside unit right? assuming so, check remote control settings and battery, set temp.to 70 degrees, a light should come on at the display and seconds later, the compressor should kick in. If Unit is brand new, it should be it. If split units, try another remote, some times those remotes show the display but do not send signal strong enough that the unit can receive it. Try getting closer to the unit.
Keep me posted! Rate this post!!
Aug 14, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
My wireless cntroller will not flash its green center lights
sounds like.... the battery completely died on controller.. you charged it by plugging it in to system and never restarted the system to regain the wireless signal..
turn off 360... turn off controller.. boot system.. boot controller, if no signal is detected you have a hardware issue with controller (assuming other controllers work with system)
Aug 24, 2009 | Microsoft Xbox 360 Controller
Jandy Aqualink Pda Ps4 Wireless Handheld Remote Control System Pool and Spa Combo Logo
127 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
