Question about Sony RMYD028 Remote Control
THE REMOTE SEEMS TO BE DISABLED
Does not turn t v on, no power, have to turn it on directly from the tv
    Top Expert:
  • Sony Master
  • 14,553 Answers
Have the remote tested to see if sending a signal---battery or problem in the remote if not----Google the RMY number to price a original only for this set.
Posted on Oct 30, 2012
When pressing the remote's 'on' button tv won't come on
does it power on using the power switch on the tv itself instead of the remote? if same thing happens when pressing the power on switch on the tv directly, try to test it on another power outlet. if it is connected through a surge protector or avr, see if connecting it directly through the outlet works.
try to also check if the power on switch of the tv is somehow stuck which may cause it to try to cycle on and off and same thing on the remotes on/off button.
now if this is specific to the use of a remote, replacing the battery might help.
Mar 09, 2014 | LG 60PK550 TV
Mitsubishi
have you tried using your remote control?
does it shuts off?
its something to do with the circiut board of your tv. if not its simply the power switch of the tv. that can be replaced bby repair man.
Jan 27, 2008 | Mitsubishi WT-42311 42" Rear Projection...
Olivea tv rc-lte remote
Do you mean that the source button on the TV itself does not switch to the input of the TV that you are connected to?
Apr 22, 2013 | Olevia LT32HVM 32 in. LCD Television
The TV will turn on from remote many times and then won't turn on at all from the remote or directly from the TV itself so we end up unplugging the power which seems to reset the TV and then it
Having to unplug suggests a issue where the set is getting confused, if using any kind of box for signal or have a receiver in line remove power from all and after several minutes plug back.
Dec 17, 2012 | Vizio VS420LF1A TV
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
Tv will not turn on
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power suppply board just have dead leakages gases capacitors.These capacitors alway bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole rerfurbish power supply board for the replacement.
May 23, 2010 | Akai LCT3701AD 37 in. LCD Television
My 26" TV/DVD combo remote seems Kaputt. Nothing works from power up on. Of course new batteries added. Seems very weak design (composite buttons direct on PCB). Any solution or source for replacement...
Try a universal remote, however I would advice you to try the buttons on the set to check if it works. It might just be a problem with the TV itself..........sodeep
Oct 09, 2009 | Mintek DTV-263 26 in. LCD Television
CONTROL CODES FOR HITACHI DV-RMPF2
I found the user manual online - directions are:
Turn TV off
Hold RED TV Power button down
and at same time per manufacture of TV...
Hitachi - 1
Sony - 2
RCA - 3
Sanyo - 4
Zenith - 5
Panasonic1 - 6
Panasonic2 - 7
Sharp1 - 8
Sharp2 - 9
Toshiba - 0
JVC - Clear
Mitubishi - +10
Magnavox - SUBTITLE
Funai - AUDIO
Goldstare - DISPLAY
voyageurs60
Jul 10, 2008 | Televison & Video
I want to program my remote control to work with my direct t.v.
Look in the user manual for your remote.
You should find a table with brands and types of devices.
Your direct tv should be listed as such.
There will be a number code for the direct tv that you will need to program the remote with.
The manual should also tell you what buttons to press in order to program.
Otherwise, have only the direct tv receiver ON.
point your remote at it and press the tv button and then the power button on the remote and hold it down while pressing the cursor up and down buttons. (not channel up and down. The up and down are the ones to select other things on the remote with.
When you have the right code the tv will shut off.
After it has shut off stop pushing buttons and then press the power button on the remote.
Your direct tv should now be programmed to turn on and off with the remote.
Note: be sure when you turn various devices on or off, have it selected for that devices you are trying to turn on or off.
Apr 30, 2008 | Televison & Video
Programming the remote
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
Oct 22, 2007 | RCA RCR412C Remote Control
Sony RMYD028 Remote Control Logo
182 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
