Closed caption is unavailable in my Samsung series 5 TV menu how to I get to it
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
It depends what input you are using and also keep in mind this may be normal if you have certain sat or cable boxes in line which also often have the CC in them-----if it is greyed out it may be wrong input being used on the set----if in tuner and not AV mode.
Posted on Oct 30, 2012
circuitcity
  • 137 Answers
SOURCE: closed captions will not disappear
Some TV will not display close caption in HD mode. This is why its Grey out in HD mode. If you switch to regular input, i can bet you your close caption will not be Grey out. The problem you are having is your cable box has close caption enable. You must go into the cable box menu and turn caption off. In some box you may have to call your cable provide for assistant.
Best regards
Circuitcity
Posted on Dec 09, 2007
  • 205 Answers
SOURCE: turn on closed caption on samsung LA32S81B tv
If you don't have the manual, go to this website:
http://www.samsung.com/in/support/productsupport/download/FileView.aspx?cttfileid=1383390&type=TV&typecode=&subtype=LCD+TV&subtypecode=&cmssubtypecode=&model=LA32S81B&filetype=UM&language=&LSSI=/in/module/ssi/left/lmenu_tv_sonomatrenz.sec&RSSI=/in/module/ssi/right/rmenu_tv.sec
and download it. I think Samsung refers to it as Teletext. Instrucitons are on page 31 of this manual.
Good luck.
crlee3
SOURCE: Closed Caption
Yeah, I'm now believing it's the tv. The captions on the other tv in the house work great. My samsung is only 2 yrs old. This model was 1080 i...Kinda of costly. Still no solution???? CR. LEE
Posted on Sep 08, 2008
SOURCE: how do i enable the closed caption on my samsung tv/direct tv?
Correct solution WITH DIRECT TV is NOT going to SETUP MENU on your Samsung TV and enabling it, this won't work with Direct TV!! I'll walk you through it. Grab your Direct TV remote, hit "Menu", pan down to "Parental, Fav & Setup", next click "System Set-up", next click "Display", now at the top of the screen between "Preferences" and "Clock" is "Captioning", click on it, now the first box reads Captioning TURN IT FROM OFF TO ON! You now have Captioning.
Posted on Sep 08, 2009
SOURCE: My brand new Insignia tv has closed captioning tha...
You can use the TV buttons to get access to close caption by pressing menu. go to features make sure that cc when mute is on.
then use the mute button on your universal remote to toggle to cc1 or off.
Posted on Aug 19, 2010
How do I get closed captioning on my samsung 6300 TV
A Google search suggested this:
To turn on and set the Closed Caption function options, follow these steps:
  • Turn on your TV and STB.
  • Press the Menu button on your remote control. ...
  • Highlight Setup, and then press the OK button on your remote control. ...
  • Highlight Preferences, and then press the OK button. ...
  • Highlight Caption,and then press the OK button.
Jan 14, 2018 | Samsung Televison & Video
How do i get captions for netflix streaming on samsung series 7 tv?
Is your Netflix being streamed from a box, or is the app built in to your TV. Either way, you would have to go into the user menu of the Netflix app for closed captioning. Not the TV menu. Hope fully this has helped. Try this link. https://help.netflix.com/en/node/372
May 01, 2016 | Samsung 55 LN55C750 3D TV
How do I get closed captioning?
According to the Samsung support website there is an option in the menu which is called "caption" which can be selected off or on.
This is a link to a copy of the manual.
Samsung UN65F6300AF manual
In the manual it says to select the onscreen menu and then ...
Subtitles
Screen Menu > Broadcasting > Caption Try Now
View subtitles along with subtitle-enabled digital and analog broadcasts.
Show Subtitles
Screen Menu > Broadcasting > Caption > Caption Try Now
Show subtitles. Subtitles will be displayed when you choose a broadcast that supports subtitles.
"" DVD Subtitles are only available when connected to an external input connector.
Mar 13, 2015 | Samsung 6350 Series UN65F6350 65" LED...
How do I turn off the subtitle / closed captioning on a Samsung series 6 6300?
Is the captioning coming from a source such as a Sky box? If so, you need to switch off closed captions on the source box and not the TV.
Sep 07, 2014 | Samsung UE40B7020 40 in. LED TV
Can't turn closed caption off on our Samsung Series 7000 LED TV
Make sure it isn't your cable or satellite TV service making the captions, as closed captions on your TV are separate from the ones produced by your service provider. If it isn't your cable/ satellite, open the TV menu and find the Audio/Visual properties section of the menu (audio and visual might be separate sections), and find the closed captions or CC options menu. When you do just change the setting from whatever it is on, to off. If your TV remote is fancier than mine (which it probably is), their could possibly be a closed caption button on the remote for easy access. In this case just push the button and change what you need to.
Jun 07, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
How do I turn on the closed captions
hi,
u can switch on the closed caption option for ur tv by the following setup.
1.Press the MENU button. Press the up or down button to select "Setup", then press the ENTER button.
2.Press the up or down button to select "Closed Caption", then press the ENTER button
3.Press the ENTER button to select "Closed Caption". Press the up or down button to select "On", then press the ENTER button.
4.Press the up or down button to select "Caption Mode", then press the ENTER button
5.Press the up or down button to select caption mode you want, then press the ENTER button. Press the EXIT button to exit the menu.
ok
Dec 22, 2010 | Samsung HLN437W 43" Rear Projection HDTV
How do I get closed captioning on a Samsung TV model TXJ2754?
Hello
Your TV displays the closed captions that are broadcast with some
television shows. These captions are usually subtitles for the hearing
impaired or language translations. All VCRs record the closed caption
signal and most pre-recorded commercial video tapes provide closed
captions. Check for the closed caption symbol in your television
schedule and on the tape's packaging: .
1 Press MENU repeatedly until you see the Setup menu. Press CH
to select "Caption."
2 Press VOL+ to open the Closed Caption menu.
3 Press VOL + to turn closed captioning on.
Misspellings and odd characters can occur in captioning. Also, there may be a
captioning delay after changing channels. Neither situation is a TV malfunction.
4 Press CH to highlight "Mode." Press - VOL or VOL + to choose
"Capt." (captions) or "Text." In caption mode, captions appear and
cover a small portion of the picture. In text mode, information unrelated
to the program, such as news reports, are displayed and
often cover a large portion of the screen.
5 If you wish, use CH , CH , or VOL + to change the captioning
channel or field. Then, press DISPLAY to return to normal viewing.
 Different channels and fields display different information, such as additional
languages or supplemental information
Nov 23, 2010 | Samsung TXJ2754 27" TV
Need to know how to put the tv on close caption
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option.
1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
  1. 2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
  2. 3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
  3. 4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
  4. 5)If you're watching a DVd on your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
  5. thanks.
Nov 11, 2009 | Televison & Video
How do i enable the closed caption on my samsung tv/direct tv?
Aug 05, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Closed caption
maybe in cable box setup?
May 27, 2008 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
