CMP5000WXE Pcb Board Power Hitachi (PP1809-30 REV.A1) PCB2310 A06-124196E)
2 Suggested Answers
  • 1779 Answers
SOURCE: Samsung HD 42inch TV Model No. PS42S5H Y Board
Your board numbers should start with LJ92. They will cross to both Samsung and LG. Oh, your model number goes nowhere, double check it.
Posted on Aug 25, 2009
Due to short circuit the board on my hitachi HD got burned.Can i still make hard disk work?
If the PCB board is burned, there is a possibility that your data is still in the drive and that the drive can still work. However, at the very least you will need a new PCB board from Hitachi.
Sep 07, 2013 | Hitachi (AU-160GBSATAHDHIT) 160 GB SATA...
Hitachi 55" plasma TV. 5 years plus old, used a
Please let me know whats the model number of the tv so that I can tell you what the PCB LED diagnostics are pointing to. It sounds like a power supply or Main board issue so I would like to confirm which one of them it is.
Dec 22, 2011 | Hitachi 55HDS69 55 in. Plasma Television
Hard drive clicks, fails to read but powers up. Approx 100GB of music files held and needs recovering. Laptop initially picks up drive on connecting to USB port but then drops out due to read failure.Drive...
Inside that plastic external case of the Hitachi XL 1000 external harddrive, is a regular desktop computer sized harddrive.
It is a SATA type of harddrive.
It is 3.5 inches across in Width. (3 and a half inches)
1 TB in size.
Looks similar to this example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5589521&CatId=2459
On the back end of the Harddrive is where it's power cable, and data cable are attached.
Inside the case of the Hitachi also is a small circuit board. (PCB or Printed Circuit Board)
The SATA harddrive is connected to this small circuit board.
The small circuit board, or Interface PCB , is attached directly to the Harddrive.
Or cables (Wires) are used to connect it to the Harddrive.
The Interface PCB is connected to the computer, via the USB cable that is attached to the Interface PCB.
It is this small circuit board that usually goes bad.
(Unless the external harddrive was on, and dropped. Then the problem is the Harddrive)
There are two solutions;
One, buy an 3.5 SATA external enclosure, and use the Harddrive as an external harddrive again.
Two, install it as a Slave drive in a desktop computer, and retrieve all your information. Burn to disk/s, or flashdrive/s.
When using a SATA harddrive as a Slave drive, there are NO jumper pins to mess with.
DO NOT change any jumpers on the back of a SATA harddrive.
(These are for the factory)
This is an example of a 3.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
There are no guides to open a Hitachi XL 1000's case, to my knowledge.
It isn't something the manufacturer wants stated.
However opening the external enclosure (Case) isn't that tough. It falls under the same as this model,
http://www.youtube.com/watch?v=hQ_vjyvK28A
Here we see at 3:00 through 5:00, that the Harddrive is attached directly to the Interface PCB.
Just remove the Harddrive from the chassis, and unplug it from the Interface PCB.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 02, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
Greeting, I have problem with SAMSUNG air condicioner inverter. The display shows me an error E1 A1 and does not include the external unit, please help what is the problem.
E-1 Room sensor and A1 Indoor PCB fault. Please you replace first,indoor sensor and reset.Sometimes indoor pcb shows fault code due to sensor short. After replacing sensor it will show only A! or sometimes no error. If it shows A1, you have to repair/replace PCB. Helpful?
Jan 24, 2011 | Samsung AW1203B Air Conditioner
In need of a pci/pnp 586 manual. anyone got?
BIOS INFORMATION :
BIOS MANUFACTURER : PHOENIX BIOS V.4.05 R 1.0 - (C) 1985/1995
BIOS ID : UNKNOWN
BIOS DATE : 11/23/95
BIOS ROM SIZE : UNKNOWN
CHIPSET : ALi M1511 REV.4
SUPER I/O CHIP : SMC 665GT REV.2 FOUND AT PORT 3FOH
CASE LABEL :
COMPUDYNE - PENTIUM PROCESSOR
P/N: 91.AA884.003
S/N: 1900001233
INSIDE THE CASE :
3 ISA SLOTS
3 PCI SLOTS
4 EDO MEMORY SLOTS
1 ALi CHISET - M1513 A1 - 9542 TS2 - AC7129SB
1 ALi CHISET - M1511 A1 - 9538 TS5 - B40958SB
2 ALi CHISET - M1512 A1 - 9537 TS2 - B40954SA
SOUND ONBOARD - CRYSTAL - CS4232 KQ EP - 33 PIN CN11 WAVE TABLE - 07 PIN CN12 AUDIO MIDI
PHOENIX MULTIKEY - PHOENIX 1987-1993 ER129
PHOENIX MB - 586 PCI PNP - PHOENIX TECNOLOGIES - A448416
INTEL PENTIUM PROCESSOR 133
NUMBERS IN WHITE INK ON THE BOARD TOP SURFACE :
95115-1
V50S MB
and
48.57001.011
MADE IN TAIWAN R.O.C.
Aug 29, 2009 | Intel Motherboard
Aug 25, 2009 | Televison & Video
Hitachi RAS-25CHA will not work after power supply -brown outage.
Is the unit responding to remote instruction at all? It does sound like your board is gone. This is usually a capacitor (blue or green and round flat disc) on the pc board, and possibly one of the diodes (small black cylindrical shape with a white line on one side) Often it is the compressor drive relay (rectangular black box) on pc board. If however you have managed to find a replacement board. The plastic heads holding the pc board are released by using a small long nose pliers and pinching the bit sticking through the board. The rest is simply a matter of changing one wire at a time from old board to new board. Or a good method is just to take a snapshot with a camera to refer to regarding the wire positions.
Jan 30, 2009 | Heating & Cooling
Televison & Video Logo
210 people viewed this question
Top Televison & Video Experts
Electro Med Services...
