Question about Sony KP-51WS520 51" Rear Projection HDTV-Ready Television
Diodes used on sony kp-51ws520 boards - Sony KP-51WS520 51" Rear Projection HDTV-Ready Television
  • Sony Master
  • 8,617 Answers
The 9 blinks is caused by failed zero cross diodes you can get the repir kit for that issue which includes the diodes nd the CD with repair instructions from www.tvrepairworld.com the kit is listed under the Sony Repair kits catagory.
Posted on Oct 30, 2012
SOURCE: Sony KP-51Ws520
9 blinks means, "Zero Crossing Detector" and the probable cause locations listed are "D6166 or D6114 is open (G board)". I had the exact same problem so I just ordered a new G board and swapped it with the old one and now everything works fine! You could order a new one at this site: http://www.partstore.com/PartSearch.aspx?PartNumber=A1054157A&x=31&y=19. The Sony board number is A1054157A. Replacing the G board is rather simple; all you got to do is pull out the back cover of the TV and the G board is the first board on your very left. After that unplug the four connectors and replace it with the new one. Here is a picture of the G board inside your TV: http://img47.imageshack.us/img47/8396/backev6.jpg. Hope this helped!
Posted on Jul 16, 2008
ginko
  • 19396 Answers
SOURCE: Sony Wega stanby light blinks 5 or 6 times
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
Six blinks is also a fault related to video problems, and regards a fault concerning the digital board and the Jungle IC (the main CPU).
This means that there is something wrong with the video.
Try first unplugging power for few hours, if that does not work, call a technician, as several IC and components must be tested and eventually replaced.
Posted on Dec 01, 2008
ladywinn
  • 5138 Answers
SOURCE: 9 blinks
D6117- Change switching Regulator on G board you can also do Self-Diagnostic Mode Press display ,5 . vol- ,power. this should turn set on and show other codes telling you what else maybe wrong. TO Remove codes and clear back out Press display,5,vol+,power Now Press 8 and Enter.
Posted on Jan 05, 2009
ladywinn
  • 5138 Answers
SOURCE: My KP-51WS520 blinks 10 times
Type in Sony Blinking codes on Google you will find all blinking codes and what they mean.
Posted on Aug 06, 2009
  • 85 Answers
SOURCE: I have a Sony KP-51ws520. I cannot power on. says
Those LED flashs are a fault indicator...First thing to do is to try a reset:
With the TV plugged in push and hold down the reset button on your remote then press the power button on the the TV and then release the reset button once the screen has come up.
If you are handy you can replace D6301 diode and it fixed the problem. You can buy that diode at partstore.com for $3. good luck
If still no luck then this is going to require a serviceman.
Posted on Jan 28, 2010
I have sony wega sony wega tv kp 51ws520 no turn on just standby light blinking and i lost remot plz help me
Is the light blinking 9 times? If so thats a very common problem caused by failed diodes on the G board which will need to be replaced.
Jul 19, 2011 | Sony KP-51WS520 51" Rear Projection...
Stand by button blinking 9 times ...tv will not turn on at all
Replaced these diode at G-board
D6116 - part no (8-719-081-97) - MMDL914T1 D6301 - part no (6-500-567-21) - 10ERB20-TB5
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jul 13, 2011 | Sony KP-51WS520 51" Rear Projection...
Hey i have a sony kp-51ws520,, an its standby light is blinking 9 times .. but i can play with the remote every now an then an it will come on ..nothing wrong with picture or sound. can you help me out
The G board has a diode #6301. This board is a tan color farthest to the left. I went to Radio Shack and bought a 200V 1A silicone diode and replaced it. Worked like a champ. You will need a 15W pointed tip solder iron and a steady hand. You can replace the board if you like. I found one for $70 on ebay, but the diode is $1.
Aug 25, 2010 | Sony KP-51WS520 51" Rear Projection...
WHEN I TURN IT ON ALL THAT HAPPENS IS THE STAND BY LAMP FLASHES 9 TIMES THEN PAUSES
Diodes are blown on the G board (Power) which triggers the zero cross error. replace the G board or have yours rebuilt.
Nov 28, 2009 | Sony KP-51WS520 51" Rear Projection...
Sony KP-46WT520 TV won't come on.
That is a diode in the sub power supply, it is a small board with only a few parts on it to the left of the d board, for the zero crossing detector. D6301 sony part number 6-500-567-21
Sep 02, 2009 | Sony KP-51WS520 51" Rear Projection...
Tv wont turn on
You have a zero crossing failure.
Replace diodes D6301 and D6116 on the G board with 1n4002 diodes.
May 17, 2009 | Sony KP-51WS520 51" Rear Projection...
Sony KP-51Ws520
Apr 24, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony KP-51WS520 , lamp flashes 9 times but TV will not turn on.
open means they have to be replaced they are no longer good and chassis is what the tv is inside (its the electronics works)
Apr 14, 2008 | Sony KP-51WS520 51" Rear Projection...
My SONY TV (KP-51WS520) will not turn on...
a Diode allows electricity to flow in one direction and blocks it in the other direction. So when its open means its burnt out and nothing can pass through in any direction. they will need to be replaced.
Sony KP-51WS520 51" Rear Projection HDTV-Ready Television Logo
66 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
