Question about Kichler Lighting 300106OBB Ceiling Fan
I have a Kichler ceiling fan model #32-33192120BB and I am having problem with the pull for the fan. The round links of the chain are getting caught on the the hole that the chain passes through. This chain is not installed straight up the center. It is being pulled from the side to the center. I called a the store that the ceiling fan was bought to explain the problem and I was told that the set up for the fan pull is the most complained about. You must have many engineers working for the Kitchler company. Why can't one of them come up with a better engineering idea?
3 Suggested Answers
  • 3640 Answers
SOURCE: i have a kichler ceiling fan operated by a remote
there should be a switch to reverse it, on the fan itself. have a good day !!
Posted on Jun 05, 2011
  • 35572 Answers
SOURCE: I have a brand new Kichler Ceiling Fan/Light installed in new home. This one for the M-Broom came with Remote UC7206T. The function which controls Fan and Fan speed works fine but I cannot the Light f
Something that may work (based on my experience). Shut off power to the fan (the circuit breaker). Remove the battery from the remote and push all the buttons just in case one is stuck. Reinstall the battery. Turn the CB on. Check operation using the remote.
Posted on Dec 29, 2012
Does a kichler ceiling fan remote model # uc7206t have reverse?
www.kichler.com/customer-service.aspx
Almost all ceiling fans have reverse. The switch is usually on the side of the fan so one must get a ladder to get to it. Air flow to be up in winter and down in summer.
Nov 14, 2014 | Dryers
Kichler ferron 60" why ceiling fan will only move very slowly remote does not appear to be working
If your Kichler ceiling fan appears to have lost touch with the remote, try the usual routine of removing batteries from the remote, pressing all buttons to eliminate a stuck button as the cause, then reinstalling the old batteries (or new batteries) and testing operation. If no luck, disconnect power at the source, not the fan, pause briefly (to "reset" the fan control) and reconnect power to test operation. If still no luck, the remote receiver in the fan or the remote itself may be defective.
Aug 31, 2014 | Kichler Dryers
Rhine ceiling fan remote replacement
Where did you find the little black box?
Apr 16, 2014 | Dryers
I need remote control for for kichler fan model # 35005
THIS ITEM NUMBER IS INCORRECT. THERE SHOULD BE ATLEAST 1 MORE NUMBER FOLLOWED BY A COUPLE OF LETTERS. IF YOU CAN POSSIBLY FIND THE CORRECT NUMBER I CAN HELP BY GETTING YOU A PART NUMBER FOR THE CORRECT REMOTE THAT WILL BE NEEDED. PART NUMBERS ON FANS ARE CONSISTENTLY FOUND ON THE CANOPY, THIS IS THE PART WHERE YOUR FAN MOUNTS TO THE CEILING. I CALLED OUR REP AT KICHLER AND SHE SAID THIS WAS AN INCOMPLETE NUMBER. HOW OLD IS THE FAN IN QUESTION? ITS POSSIBLE IT MAY BE DISCONTINUED IS WHY WE CANT COME UP WITH ANYTHING.
Dec 04, 2013 | Kichler Lighting Dryers
How to reverse kichler ceiling fan, UC7206T
Stock Kichler ceiling fan c. 2006, works with replacement remote control 337001WH hand-held unit from Amazon 2013. Started running backwards when two remotes were activated at the same time by accident. Random button pushing on two remotes simultaneously got it to go back to forward. (Apparently original remote hand-held transmitter had forward/reverse setting, but the substitute 337001WH transmitter doesn't. When two transmitters run at the same time, the fwd/rev code may be decoded in the collisions at the receiver. Thank goodness!)
Jun 13, 2012 | Kichler Lighting 300105CTO Ceiling Fan
I pulled on my ceiling fan pull chain and it came out, do I have to replace the pull chain attachment
Hopefully not.
Can you see a part of the chain stickong out of the fan housing? If so, get a "link" and re-connect the piece that fell off.
You can get a link (or a small chain) at WalMart key-maker or any hardware store (Ace, TrueValue)...
Sep 21, 2009 | Dryers
Hampton Bay Ceiling Fan 476-317
you will have to order this switch direct from hampton bay
or one of there dealers
http://www.eceilingfans.com/switches_-_pull_chain_-_ceilin.html
this is the link needed shows what the pull looks like print out the page match with your wires in fan
this is there home link with phone number for ordering parts
May 31, 2008 | Hampton Bay 24002 Ceiling Fan
Kichler Lighting 300106OBB Ceiling Fan Logo
35 people viewed this question
Top Kichler Dryers Experts
Are you a Kichler Dryer Expert? Answer questions, earn points and help others
