Question about KitchenAid KGRS807SSS Gas Kitchen Range
Remove back splash on KGRS807SSS
I want to remove the back splash on model KGRS807SSS . Can this be done? If so how?
How hard is it to change the belt on 2003mazda mpg
It's just a little more complicated than average. They recommend you do it from below, so you'd have to jack up the front, put it on stands, and remove the splash shield. Here is the procedure in the manual:
3.0L Engines
  1. Disconnect the negative battery cable.
  2. With the vehicle in neutral, position it on a hoist.
  3. Remove the splash shield.
  4. Rotate the accessory drive belt tensioner clockwise for 2000-02-2004 models and counterclockwise for 2005-2006 models. Remove the belt.
  5. To install, reverse the removal procedure.
The only tool I use is a flex handle and a socket that fits the tensioner, but you will need some small tools to remove the splash shield from below.
Jul 06, 2017 | Cars & Trucks
Do i need to remove the drive shaft to remove the alternator
if you bought a repair manual for it you could read all about it .
Nov 12, 2015 | 2006 Mazda MPV
Where is the horn location under hood of a 2007 mercury mountneer?
Remove the LH front fender splash shield !
Fender Splash Shield Removal and Installation
  1. Loosen the running board bolts and lower the running board to access the front fender moulding pin-type retainer.
    • To install, tighten to 23 Nm (17 lb-ft).
  1. Remove the lower pin-type retainer from the front fender moulding.
  1. Remove the 2 rear pin-type retainers from the front fender moulding.
  1. Position the front fender moulding aside and remove the splash shield lower screw.
  1. Remove the front splash shield screws.
  1. Remove the front splash shield pin-type retainers.
  1. Remove the front splash shield.
  1. Remove the front fender splash shield.
  1. To install, reverse the removal procedure.
Mar 25, 2015 | 2007 Mercury Mountaineer
Remove alternator on 99 eldorado norhtstar
Okay, i will start by saying this is a job that should only be done by someone who works on cars, first thing first is if your car has onstar you must disable the back up onstar battery, if power is removed the back battery will be turned on and run until it drains out and then will need to be replaced , does not matter if you reconnect battery quickly. so first make sure key is off and out of ignition next open driver door , leave open , dissconnect battery, this way the back onstar battery is not turned on.
With that done you will next remove the belt then remove the front alternator bolt.then you will need to drain and remove the radiator,next you will need to raise and support car, remove front splash sheild, next loosen rear alternator bracket from engine.
Remove top bolt,front lower mounting bolt and lower rear mounting bolt, remove upper rear mounting bolt.
Remove air duct from rear of alternator. Disconnect wiring from alternator. next remove front alternator/ A/C bracket. rotate alternator and remove. To install reverse procedure .
GOOD DAY.
Sep 02, 2012 | 1999 Cadillac Eldorado
Procedure to replace alternator 2006 mercury mariner 3.0 v6
  2. Remove the lower splash shield bolts and the pin-type retainers.
    NOTE The LH lower splash shield must be removed before the RH lower splash shield.
  3. Remove the lower splash shields.
  4. Rotate the front end accessory drive tensioner counterclockwise and position the accessory drive belt aside
  5. Disconnect the alternator electrical connector.
  6. Position the alternator B+ protective cover aside and remove the alternator B+ terminal nut.
  7. Remove the A/C compressor bolts. Use a tie-strap and position A/C compressor aside.
  8. Loosen the alternator nuts.
  9. Remove the lower alternator studs.
  10. Remove the upper alternator bolt and the alternator.
Feb 18, 2011 | 2006 Mercury Mariner
I want to change the amber side marker light on a 2005 Mercury Mariner but the manuel says to take it to a dealer to have it done. Is it that hard to do myself? Thanks
Side Lamp/Front Turn Signal Lamp Bulb
  1. With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-02.
  1. Remove the 2 fender splash shield bolts.
  1. Remove the 3 fender splash shield pin-type retainers.
  1. Remove the screw and position the fender splash shield aside.
  1. Remove the front turn lamp bulb holder from the lamp assembly.
  1. Remove the front turn lamp bulb.
Dec 07, 2010 | 2005 Mercury Mariner
I need to replace the alternator on my sisters car and its not here right now and was wondering where the alternator is located so i will know if ill be able to get to it to fix it
if you have the 2.3 liter engine follow these steps...
  1. On models with anti-theft audio system , refer to Technician Safety Information .
  2. Disconnect battery ground cable.
  3. Remove lefthand charge air cooler, then righthand upper seal board, Fig. 3 .
  4. Remove condenser fan assembly.
  5. Disconnect alternator, then alternator electrical connector.
  6. Remove lefthand splash shield.
  7. Remove drive belt.
  8. Remove A/C compressor, then, with pipe still connected, position A/C compressor away from generator for easy access to alternator.
  9. Remove alternator from under vehicle.
  10. Reverse procedure to install, noting the following:
    1. Torque lefthand splash shield bolts to 70 - 95 in.lb.
    2. Torque condenser fan bolts to 70 - 95 in.lb.
    3. Torque lefthand charge air cooler nuts to 12 - 16 ft.lb.
if you have the 2.5 liter engine then follow these steps....
  1. On models with anti-theft audio system , refer to Technician Safety Information for system deactivation procedure.
  2. Disconnect battery ground cable, then remove electrical harness, Fig. 4 .
  3. Disconnect terminal B wire, then alternator electrical connector.
  4. Remove righthand splash shield.
  5. Remove drive belt.
  6. Remove A/C compressor; then, with pipe still connected, position A/C compressor away from generator for easy access to alternator.
  7. Remove alternator from under vehicle.
  8. Reverse procedure to install, noting the following:
    1. Torque upper alternator bolt to 12 - 16 ft.lb., then lower alternator bolt to 24 - 33 ft.lb., Fig. 4 .
    2. Torque A/C compressor bolts to 12 - 16 ft.lb.
    3. Torque righthand splash shield bolts to 70 - 95 in.lb.
Aug 04, 2009 | 1995 Mazda Millenia
Need to replace alternator
Here's a link to the alternator diagram:
http://www.chiltonlibrary.com/content/images/0601/images/06017-FREE-g02.gif
Instructions:
  2. Raise and support the vehicle.
  3. Rotate the drive belt tensioner counterclockwise and remove the accessory drive belt.
  4. Remove the right lower splash shield.
  5. Disconnect the crankshaft position sensor.
  6. Disconnect the wiring harness locators from the alternator splash shield.
  7. Detach the alternator wiring connector.
  8. Remove the positive cable nut.
  9. Remove the alternator splash shield and the alternator.
Here's a link to a website to put the serpentine back on, just insert the year,make,model, and engine size to get the "Routing Diagram" for your car.
http://www.mvreader.com/multiview/dayco/index.php?bgInterchange=1&l=n
All the best on your repair.
Greg
May 30, 2009 | 2005 Mercury Montego
Ford focus 05 model changing dip headlamp bulb?
US Focus has one headlamp attachment that you have to raise car on hoist to remove it.
Headlamp Assembly Removal
  1. Remove the fender splash shield lower retaining screw.
    • Push the fender splash shield to one side.
  1. Remove the headlamp assembly lower retaining bolt.
  1. Remove the radiator grille.
  1. Remove the headlamp assembly.
    • Disconnect the headlamp assembly electrical connector.
Feb 25, 2009 | 2005 Ford Focus
Honda accord
Unfortunately, u must remove the timing belt. This is why it is recommended to change the water pump when the timing belt is changed.
Here's the procedure : Disconnect neg. battery cable, remove splash shield at wheel well, (after removing wheel to help gain access, turn the engine to align timing marks and set #1 cylinder at top dead center on the COMPRESSION stroke. Once this is done, u can NOT disturb engine or u will have a fun time trying to figure out how the heck to set the timing. Drain anitfreeze, remove timing belt, remove water pump bolts (be aware that bolts may be different lengths, don't mix them up, remove water pump and O ring.
Put it back together: install new O ring and water pump, be careful Oring doesn't slip or move out of position, tighten to 9 ft lbs, install timing belt, refill antifreeze, reconnect battery cable, start car, check for leaks, bleed cooling system, replace splash shield.
Oct 19, 2008 | 1995 Honda Accord
KitchenAid KGRS807SSS Gas Kitchen Range Logo
160 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
