Question about Dayton G73 Utility Heater
Thermostat (?) in utility heater
I have an Air Tech utility heater (translation: cheap) that isn't heating or blowing air, though the power indicator light comes on. Is there a thermostat in these types of heaters, and if so, can it be replaced or repaired? I am thinking that may be the problem, though I am a novice at such things. I just don't want to keep replacing these heaters and contributing yet another heater to the landfill. Goodwill doesn't want them if they don't work! Thanks. and Brrrrrr.... chill55@peoplepc.com
  • Dayton Master
  • 2,364 Answers
Have you clean it ? put a vac on blow and blow the dust out of it could just be blocked with dust , works some times could be that simple
Posted on Jan 04, 2009
Why dos heater only stay on for a minate and stop
Posted on Feb 09, 2011
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
Honeywell thermostat blows cold air on heat
Thermostats don't actually blow anything, the heating system might though. Check the breakers for your heat system, then call a heating specialist. They're really not that expensive.
Oct 06, 2014 | Honeywell Heat/Cool Thermostat
Heater blows cold air in 98 s10 blazer
Pull thermostat out and check to see if it is stuck open. If it isn't, put thermostat in a pot of water and heat to boiling. If thermostat opens before boiling it is fine. Reinstall thermost or replace it.
Oct 30, 2011 | 1996 Chevrolet Blazer
Doesn't seem to heat up as well as expected. I did have to change the outlet for the heaters plug. can run for hours and still be able to tough heater grates.
If this is an old unit you can try cleaning it with compressed air and a blow gun, blowing air forward and backwards thru the ceramic until it is clean. Please do this only when it is off and unplugged. If it is new I would return it these from Dayton are not cheap.
Dec 27, 2010 | Dayton 3VU36 Utility Heater
My honeywell heater thermostat is only blowing cold air, there is no heat blowing regardless of setting. how can i fix it? it won't even turn off.
the wiring for thermostats are color coded. R(red)power, Y(yellow)cooling, G(green)common, W(white)heating. O(orange), E(emergency)heat. Make sure that you have the right thermostat because there is an air condition thermostat and there is a heatpump thermostat and they wire up differently.
Nov 27, 2010 | Honeywell Programmable Thermostat Heater
No heat
your blower motor resistor needs to be replaced if you only have one speed its a small inexpensive part runs about 15 dollars easy to replace.
Jan 17, 2010 | 2000 Oldsmobile Silhouette
Heater will not blow warm air, only blows cool air even when the engine is warmed up
Sounds like the thermostat is jammed, I would replace it anyhow for how much it will cost, or possibly the heater matrix, thats the small radiator inside the car behind the dash that takes the hot water in and the fan then blows the heat through the vents, this may be blocked doubtful though more likely the thermostat be careful driving the car in case it overheats and blows the gasket.
It could just be air locked, meaning if you have topped the water up lately or put anti freeze in it it has pulled some air in the water system, much like your house heating you will have to bleed it.
Jan 14, 2010 | 1998 Ford Expedition
No interior heat until I start to drive
You most likely have an "AIR LOCK" within the Heater Core. This requires one to pressurize the Cooling System and loosen the heater hose at the HIGHEST POINT and bleed the Air out of the Heater Core. I am not familiar with the Nissan but have encountered this problem numerous times over the years. Most late model vehicles are equipped with Air Bleed devices which must be utilized any time coolant is drained and refilled.
Most all reputable Auto Parts stores sell and/or rent a pump that temporarily replaces the Pressure Cap that may be utilized to pressurize the system for this purpose. If you don't feel capable of performing the bleeding operation take your vehicle to an ASE Certified Mechanic and have it done correctly.
Dec 07, 2009 | Nissan Xterra Cars & Trucks
My heat in my truck doesnt work
the blendoor on the heater box maybe broken ck lines going to heater core and make sure they are hot. does the heat temp change at all from cold to hot?
Dec 05, 2008 | 2001 Ford Expedition
Edgestar 12,000 portale air conditioner and heater
There are 3 possibilities beginning with the most likely problem
1) If your heater heats up for a few minutes and then quits, chances are there is a blockage in the air flow, check for dust and grime blocking the air intake coarse filter , airgun blow to clear accumulated dust and otherwise clean the coarse filter .
2) If the heater fan blows but there is no warm air, the heating element needs renewal ( this happens very rarely)
3)If the fan stalls and the heater heats up and the thermostat kicks in, then this will be not be a DIY job. This is least likely as you said the air cooler works.
Apr 25, 2008 | EdgeStar Portable Air Conditioner Heater
Dayton G73 Utility Heater Logo
171 people viewed this question
Top Dayton Heating & Cooling Experts
paulcarew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
