Question about Car Audio & Video
Jvc ks-a102 power amp 9 pin schematic
I am looking for a diagram of the 9 pin connector. I need to know what each hole in the connector is to. I have no wires in it
  • Rocky Degelman Oct 29, 2012
    Just get a new wireing harness for it, It would be easier then trying to figure it out.
Inferno77
  • 6 Answers
SOURCE: Lose wire with 6Wires connector... need diagrams of pin out
(There are different versions of the ba-200, so I'm assuming they al use the same wiring/pinout...) if you look at the amp on the enclosure(right-side up... so the writin goes left->right): The top left pin is #1, beside it is #2, then #3. The bottom left pin is #4, beside it is #5, then #6. #1 Right speaker positive input #2 Empty #3 12 Volt Constant Power #4 Left speaker positive input #5 Remote turn on / Acc power input #6 Ground Now there's supposed to be a 15-amp fuse on pin #3 (12v constan power).
Posted on Jul 27, 2007
  • 7 Answers
SOURCE: Connector Pin Out
Posted on Jul 21, 2008
  • 631 Answers
SOURCE: Rockford Fosgate 120a2 amp
You can get it from Rockford.
Let me know if you need any help repairing it.
Posted on Aug 19, 2008
  • 631 Answers
SOURCE: MTX 1501 SCHEMATIC DIAGRAM
MTX never released any of their schematics.
What sort of problem are you having with it?
Posted on Sep 29, 2008
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
I need help with the schematic diagram of a JVC RX-5THPBK power amplifier
Have you checked into SAM'S FOTOFAX or other searchers, or do you have schematic and need interp. of it?
Aug 03, 2016 | JVC Audio Players & Recorders
My jvc ks-ax4302 goes straight to protection when I turn it on, just curious what could be the cause and where could I find a schematic of the mother board?
If the Power/Protect LED is red, usually the speaker wiring has a short-circuit or the speaker total impedance is wrong for the system. The most common issue is a bare spot on a speaker wire that is coming in contact with part of the car or another bare wire. Sometimes, it just means that the system got too hot.
Before you look for a problem with the KS-AX4302 board, look at your wiring and replace any damaged wires.
I hope this helps.
Apr 11, 2015 | JVC Car Audio & Video
Wiring diagram for jvc model no ks-fx460r
http://books.jvc.com/booklist.asp?Model=+ks-fx460r this should take you to the down loadable manual for that head unit.
Jan 12, 2010 | Car Audio & Video
Diagram for adaptor ks-u57
There's nothing to it--look 'inside' the connector and you'll see three metal contacts close the metal connector (somewhat similar design as a USB jack). The center is common for the line out, and the left/right are the positive for the left and right channels. The metal connector itself is not part of the circuit.
So if you were connecting RCA jacks to it, the outer ('negative') of both RCAs connects to the center contact on the KS-U57, and the center ('positive,' or 'signal') of the left and right RCAs go to the contacts bracketing the center.
KS-U58 and KS-U57 are wired the same.
Oct 31, 2009 | JVC Ks U57 Line In Adapter
JVC CarAudioModel KS-RT404 lost rear panel containing connections
http://files.ddrservice.info/Audio/jvc/ks-rt404.pdf
This link will take you to the manual. On page 7 you will find the connection Info. you need.
Sep 18, 2009 | Car Audio & Video
Color code for speaker out on a JVC KS R140 car casette player
White - left front
Grey - right front
Green - left rear
Purple - right rear
Yellow - memory power
Blue - remote power (power ant, amp or eq power)
Mar 20, 2009 | JVC KS-F150 Cassette Player
Wiring Harness for JVC KS-R127
I can uually find those on ebay for a few bucks. You will need to count the number of pins then go shipping.... Also look for a seller called cali car stereo if they dont have it listed they probhably have it at thier store..
Sep 08, 2007 | JVC KS-R127
JVC KS-AX4700
It sounds like you have blown your Output amplifier MOSFETs (Metal Oxide Semiconductor Field Effect Transistors) You will see some components with metal tabs, these are some of those along with some secondary stage pre driver transistors also screwed to the metal case (heat sink). Ok you will need some pieces of equipment. First you will need a schematic of the unit (never work without a schematic), second you will need a volt ohmeter (yes I am old) you might call it a multimeter. Now this is the bare minimum of equipment you need. first open ope the scematic and find the main voltage rails and test points, these will be important as you traces the source of your problem down. I want you to take measure ments of the test points and compare them to the measurements in the schematic, the places where the diffences are dramatic are the places the problem may be. remeber take these measurements and compare them to the schematic and then try to isolate the problem down to the components that are truly bad. Also pick up a book on how to repair audio amplifiers. This is the best I can do over the internet, happy hunting my friend.
Aug 17, 2006 | JVC KS-AX4700 Car Audio Amplifier
Car Audio & Video Logo
243 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
