Question about Indesit Dishwashers
Indesit dg6100w not draining
Why is my dishwasher not draining?
4 Suggested Answers
mrswiff
SOURCE: indesit DG6100W problem...please help!
Hi, I have the same dishwasher and it fills from the cold supply, not the hot and it doesn't have a cold cycle as is previously suggested, as you will know kellyemb :-)
The Indesit DG6100W does a fill from the cold and heats as it washes, so if it's sticking part way through, it could be the heating element. Have you tried opening the door when it sticks and seeing if the water is hot? The heating element went on ours and it kept tripping the electric whenever the it tried to start to heat the cold water. If it is the element, they don't cost much to replace, even cheaper if you know someone who can fit it for you! Ours cost us around £12 and hubby fitted.
The only other thing I can think of is it might be the timer, like someone has suggested but how to reset it, I have no idea. I have seen on another website that a replacement timer is around £55 plus VAT, which is a little expensive.
Hope you get it fixed.
Posted on Oct 04, 2008
  • 75 Answers
SOURCE: where dose the earth wire go on an indesit
it should connect to a metal cold water pipe
Posted on Jul 04, 2009
SOURCE: Indesit DG6100W dishwasher will not work
It sounds as though the micro-switch inside the lock mechanism is displaced.
Undo the 6 screws at the top of the door (on the inside) and remove the outer pane. This will give you access to the lock mechanism. Please switch it off first.
The micro-switch can then be adjusted so that when the handle is released, the switch engages (you should hear a very soft click).
Hope this helps.
Posted on Jul 26, 2009
Indesit IDL 40 slimline dishwasher does not drain completely
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Jan 05, 2011 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit di624
Firstly check the connection where the dishwasher hose connects to the drain. Remove this washe hose and see there is no stoppage at that piont. If all ok go to the dishwasher and see if there is no stoppage in the sump where the water goes out. If ok then the drain pump in the machine is either blocked or faulty. you will have to access this pump to be able to proceed further. good luck
Aug 02, 2010 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit D41 dishwasher, switch it on to program,
if applaince does not start draining then there is a possible fault with the door locking assembly,and the appliance thinks the door is open and this will not allow the appliance to start
Jun 28, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Hope this helps.
Jun 20, 2009 | Dishwashers
Indesit DG6100W problem...please help!
Jul 01, 2008 | Dishwashers
Dishwashers Logo
21 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
NOEL
NOEL
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
