Question about Refrigerators
What do the letters on dial on iceline u788 freezer mean n, ff with marks between n and ff
Would like to know what the letters mean on dial for this freezer so I know which is the best setting
  • 72 Answers
SOURCE: What does message: Er FF mean?
That means the freezer fan is blocked, you need to order a new High voltage board, the ice has built up enough from not defrosting that it is interfering with the operation of the evaporator fan.
Posted on Jun 22, 2009
  • 35 Answers
SOURCE: freezer and refrigerator run about 8 to 10 degrees
check freezer coil for ice, then defrost timer and then fan and switch fan
Posted on Jan 02, 2010
rylee_smith
  • 8619 Answers
SOURCE: what does ER FF mean on my Kenmore Elite bottom
Hi
Thanks for using FixYa. Error ff is freezer fan fault. This usually happens when either the rear board has gone bad or the freezer fan itself is bad and needs to be replaced. To check what is causing the error you can start with checking the fan which is located behind the back wall inside the freezer. Also check the rear board as it might not be putting the fridge into defrost long enough and is causing the ice to build up in the freezer and thus stopping the freezer fan from turning and so causing ff error. Leave the fridge unplugged for 24hrs which will melt all the ice then plug it back if still the issue is not resolved and you hear the fan running then it is the rear board that needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jun 30, 2010
heatman101
  • 43501 Answers
SOURCE: Iceline upright freezer model "de
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Posted on Jan 16, 2011
ercupa190
  • 12223 Answers
SOURCE: Iceline u788 instruction manual
go to www.fitness.manualsonline.com and download the inst.manual.
or www.manualsfactory.com
God bless you
Posted on Sep 07, 2012
What do o, ff, +, N mean on freezer dial
It means you haven't read the user manual
APPLIANCE911
Apr 15, 2016 | Refrigerators
Iceline deluxe 77
check for air leaks the gasket perhaps
Dec 09, 2013 | Refrigerators
My LG display is reading ER FF what does this mean and what can I do to fix it?
Error Code Er FF
This code is not to be confused with the O FF or demo mode error message. The "Er FF" error code indicates a problem with the unit's freezer fan. The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. Contact customer service if the error code continues to be displayed after having thawed the unit.
Hope helps.
Apr 03, 2011 | Refrigerators
The display is showing ER FF WHAT DOES THAT MEAN
error fresh food means refrigerator probably bad thermistor in refrigerator ( ff refrigerator ) fz freezer
Jan 27, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
How to Buy
heatman101
Jan 16, 2011 | Refrigerators
Error message Er FF
er ff means that the control board is not sensing evap fan motor operation this means either a bad fan motor ice in the fan motor or bad control board. you can verify fan operation by opening freezer door and feeling for old air blowing from back of freezer compartment. you will have to push in the light switch to get fan operation.
for corndo that has same problem you actually have a different problem. er dh means the control board is not sensing defrost heater operation. the most common culprit is a bad defrost sensor. message me back if you need instructions for trouble shooting..thx peyton
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
LRFC22750TT French Door/Bottom Freezer ER/FF Error
the ff error code means freezer failure.you need to replace the defrost control assembly in the freezer compartment behind the back panel..and the evaporator fan may be out also..mark at applianceliquidators@verizon.net or 503-406-7179
Aug 16, 2008 | LG LRBC22544 Bottom Freezer Refrigerator
LG refrigerator isn't cold but bottom freezer is freezing the food
ff is fresh food may be the ff thermisor but i would first check the freezer back wall is it frosted up can you hear the fan in the freezer blowing the air up to the ff section
Jan 05, 2008 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
15,334 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
