Question about Coffee Makers & Espresso Machines
Red exclamation mark blinking- have checked water, tray, beans
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 65 Answers
Have you descaled it recently?
Posted on Oct 29, 2012
2 Suggested Answers
SOURCE: new Saeco Odeo Go has solid red exclamation mark, doesn't budge
You have to 'manually' prime the pump: When the red exclamation mark shows, press the water switch on the right side (the picture of the water drip), then open up the steam nozzle and let the machine pump hot water into a cup until the red light goes out.
Posted on Aug 23, 2009
Saeco coffee machine with a red blinking exclamation point light won't make coffee, how do I fix it?
When the red exclamation point is flashing slow, something is not where it is supposed to be, bean hopper lid, door, brew mech, water tank empty, dregs box or water tray on dregs container is full. If the red exclamation point is flashing quickly, open the steam valve for pump priming. If pump turns on, and water passes correctly, the light should go off and return to heating stage. If not, we have a blockage or a pump that is not working correctly.
Nov 16, 2015 | Saeco Odea Giro Plus Coffee Maker
Trouble with Saeco Vienna Deluxe
It sounds like you are doing everything right.
From what i have read, a lot of people have had the problem of the red light coming on and staying solid.
When they called to find out what to do they were told to clean out their machines.
I would take the whole machine apart (all of the parts you are supposed to), empty all the beans and all the water. Then try putting it all back together. Remember to prime and see what happens.
Sorry that i can't be more of a help. Others have completely taken the machine apart and emptied all the beans and water, and when they put it back together it worked for them.
If this doesn't work i would phone the company and see if its still covered under the warranty.
Good Luck
Apr 16, 2008 | Saeco Vienna De Luxe Espresso Machine
My SAECO Talea Giro is not working. I have cleaned it properly and coffee beans and water is filled up. The red exclamation mark and the warm water lights are flashing. I can produce steam without a...
The thing that comes to mind is the brew unit is blocked and or the grind is too fine. Remove the brew unit and clean the screen under the red o-ring.
Aug 06, 2011 | Saeco Talea Giro Espresso Maker -...
I just received my brand new talea giro plus in the mail today. went thru the instruction manual and set everything up step by step. when i turned it on the very first time the red exclamation point is...
I had a similar problem. I opened and closed the water tank, the top coffee bean coffee and the dreg door several times. I even 'stirred' the coffee beans a bit. Finally, after simply taking the coffee bean cover off and putting it back on, the light went to green. Even now, several months later, I sometimes have to open and close everything to make the green light come on, although it seems to be getting better with age. (like me :-))
Apr 27, 2011 | Saeco Talea Giro Espresso Machine
Red light from the coffe keep blinking
make sure all the doors are closed, brew group, tray, water, and disposal are all seated closed.
have you cleaned the brew group? something stuck in the grinder? got beans and water?
Sep 19, 2010 | Saeco Vienna Espresso Machine
Turn on switch but no noise as before when machine starts up
Hi
Check to make sure that everything is in place. The main culprit is usually the drip tray, or the brew unit.
Jul 05, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Bean and water fault(red) light blinking when i turn on solis master 5000 coffee machine. how to fix it. Regards vh
HI First make sure everything is in and locked (brew unit, drip tray, and dredge drawer). Open the knob on the right and flow water through the wand. Now turn the knob in the bean hopper to 16 and push the brew button. If that didn't work you might have a clog in the grinder, and will need to clean it.
Jan 26, 2010 | Solis Master 5000 Espresso Machine
New Saeco Odeo Go has solid red exclamation mark, doesn't budge
Jun 11, 2009 | Saeco Odea Go
Saeco Vienna Deluxe
ok which red light are you talking about. the water or the beans or the warning
Apr 15, 2008 | Saeco Vienna De Luxe Espresso Machine
Blinking red light
When you prime the machine, can you get a full cup of water or just a half?
If you only get a half then you have to replace the "water turbine" in the machine.
Mar 04, 2008 | Saeco Trevi Automatica Cappuccino
Coffee Makers & Espresso Machines Logo
97 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
