Question about Honda Wp20x Wp30x Trash Water Pump Screen Strainer 2.5" Nipple
Why won't my honda wp20x starter cord fully pull?
This water pump hasn't been ran since this time last year. At that time it was serviced fully (just in time) as it had sat for quite some time prior as it hadn't been needed. In CentralPA and its being used by my 'elderly' father in his basement. There is no reference to this issue in the manual.
  • 3 Answers
SOURCE: karcher k2400hh pressure washer, water pressure cuts out.
Hello cikanek:
Try this:
From your posting, I assume you have removed the splash cap and the nylon bypass valve cover. Connect the water supply to the pump and connect the high pressure hose and wand to the pump outlet. Wad up a small towel and place it over the bypass valve opening to catch the valve insert when it pops out. With the engine throttle closed, pull the starter cord several times to see it the valve insert will pop out. If it doesn't come out after two or three pulls, set the throttle to low and start the engine. I have performed this procedure a number of times and the valve insert always pops out. There is no real danger of the valve parts getting seriously airborn since the actual pump output volume is very low (2.5 Gal/min).
Good luck,
Ed
Posted on May 23, 2009
  • 78 Answers
SOURCE: 2004 honda civic overheats
You might have a sticking thermostat. If it's sticking shut, it won't open when needed and the engine will overheat. Even though the water in the radiator is not hot then, the water in the block of the engine is boiling.
After that overflow, the cooling system was underfilled, so when the thermostat finally did open, it had plenty of room to refill, which is what you saw when the water got "suddenly sucked in".
My recommendation is to replace the thermostat (and gasket), because as a point of diagnosis, it is a relatively cheap part but can have terribly inconvenient consequences when malfunctioning. If you're handy, get a Haynes or Chilton manual from the auto parts store and do it yourself.
Also, the radiator cap is not good to mess with when the engine is hot. Doing as you did by opening it while overheated upsets the balance between the coolant in the block and radiator. There's a small rubber hose from the top corner of the radiator to a plastic (probably translucent) overflow tank on one side of your engine compartment. Under normal circumstances, you should check the coolant level there, as it exists to keep the system in balance. Note that I said "normal" - which means anytime it hasn't overheated to the point of leaking out of the radiator cap or leaking elsewhere.
Posted on Jun 10, 2009
  • 491 Answers
SOURCE: 1994 Honda Civic LX\overheating within 2 mile drive
Remove and raise upper hose at thermostat end and remove lower rad hose.
Fill rad with a hose and watch for flow from bottom rad hose and/ or bottom rad hose connecton.......water should fall though rad easily.
Honda rads are cheap.....any restriction....replace rad.
Remove thermostat....fill thermostat housing with hose and watch for water flow at bottom rad hose.
Flush good.
Remove heater hoses.......flush back and forth until a good flow is present "With heater control set to hot" if no or poor flow....replace heater core.
Stop leak can plug everything.
Also.......not likely causing over heating....but ....at your mileage,if you do not know if the timing belt has been changed.....CHANGE IT NOW!
Water pump is optional at this mileage.
Posted on Aug 24, 2009
Testimonial: "thank you for the very clear, step by step instructions for diagnose and remedy"
roadtech7
  • 293 Answers
SOURCE: Honda water pump, wb20x/wb30x Left water in it
Remove the spark plug, this will rule out hydrostatic load on the engine. Try to pull it again. If it is still stuck, You will need to try to turn the pump.
Make sure there is engine oil too.
Posted on Nov 04, 2010
  • 3 Answers
SOURCE: Missing operating instructions / manual for Honda Sat Nav system
did any of you find one? i have just bought a SECOND HAND 2004 CRV but no sat nav manual - nothing on the net- any help appreciated.
Posted on Feb 06, 2011
Honda Accord keeps blowing fuse and won't start
Recently we had to put a new fuse in the starter ???????????? What fuse ? location , size . A fuse blowing means a electrical short to ground .
May 29, 2017 | 1998 Honda Accord
My 2000 Vespa et150 won't start. Battery is fully
try jump starting as well as checking you connections
Sep 17, 2012 | Cars & Trucks
1985 Honda shadow vt500c how to replace front turn signal stem, after engine gets hot and you shut bike off try to restart bike won't start, also I have a noise sounds like coming from water pump
Hi, Luther the answer to all those questions is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
Good luck and have a wonderful day.
Jun 21, 2017 | 1984 Honda VT 500 C Shadow
I have a 1985 Yamaha maxim that hasn't been ran
Spray starter into the carb intake with no choke, if she runs for a few seconds then you know its fuel starvation
clean jets & airways & blow through with compressed air
Nov 20, 2011 | 1985 Yamaha XJ 700 S Maxim
Truck lost power and died, started and wouldnt gain power to run ribbed to 800RPM and died caughed a little. replaced fuel filter same problem. Disconected filter turned key on pump ran for a second ane...
Modern fuel injected vehicles will only run the pump for a couple of seconds to pressurize the fuel system at stat-up. The pump won't run after that until the engine is running or you are actively engaging the starter. The fuel pump and relay are doing exactly what they are supposed to do. Now, that doesn't mean the pump is building pressure like it should but the pump running for a second then shutting off after you first turn on the key is normal operation. You may have entered it, but I can see no information about what vehicle you are working on other than it is a truck. More information about the vehicle would help. In the mean time, I feel a compression check is an order and you should take a look at the oil to make sure there isn't any water mixed in. Some history would help as well, like if you have done any type of service in the last month, when the basic maintainence was done, how many miles are on it, etc.
Oct 30, 2011 | 2002 Chevrolet Silverado 1500HD
The battery is charged, but there is no turnover, just a continuous clicking sound.
sometimes a battery will go bad even though it shows 12 volts it hasn't got the cranking amps to fully engage the starter. Try another battery and if you still have the problem you will need to replace or rebuild the starter
Sep 21, 2011 | Honda Shadow Spirit 750 Motorcycles
Hello. My 1997 Chevy Tahoe refuses to start. The problems began with a bad fuel pump. I changed. It worked. The fuel pump died again. I changed it again and it has been working. I parked it for two weeks....
Now you have a good battery & a starter that turns over the motor
Have you cycled the key on & off with a fuel pressure gauge on the
fuel rail?
Do you have a fuel filter that isn't over 3 or 4 years old?
Have you checked for spark while cranking ? Use an old plug on the wires,
if you have ignition wires,don't ground the wire without resistance
If you removed the ducting & MAF Sensor it won't start
Tell us what you checked & exactly how that was done.
Jun 09, 2011 | 1997 Chevrolet Tahoe
Karcher k2400hh pressure washer, water pressure cuts out.
Hello cikanek:
Try this:
Good luck,
Ed
May 17, 2009 | Honda Karcher G2400HH-R Pressure Washer
Honda Wp20x Wp30x Trash Water Pump Screen Strainer 2.5" Nipple Logo
54 people viewed this question
Top Honda Plumbing Experts
Matt Olenzek
Matt Olenzek
Tony Crow
JonSnell Electronic
JonSnell Electronic
Are you a Honda Plumbing Expert? Answer questions, earn points and help others
