Question about Lenovo A720 I7-3610qm 8gb 1tb Blu Ray Nvidia Gt630 2gb 27 Inch Frameless 10p
Disc stuck in lenovo a720
Cd is stuck in the drive and i cant find anyway to release it
A disc is stuck in my dell laptop
Please provide the model number. Also, assuming you're talking about a CD stuck in the drive. There should be a tiny pin hole on the CD/DVD drive bezel. Unplug laptop and remove battery. Then stick a tiny pin in that hole -- should release the catch that keeps the optical drive bay closed. You can then open the drive and remove the disc.
Nov 08, 2014 | Dell Inspiron Computers & Internet
Connecting A720 keyboard to the computer
you better buy a wired USB keyboard. the built in wireless connection wont work with your new wireless kyb. except you plug in the new USB donggle
Jan 19, 2013 | Lenovo IdeaCentre A720 Desktop
Lenovo Z570 Disc tray is stuck -outside of laptop
Open the try slightly, shut down the machine, tilt the machine to the side of the DVD/CD drive a gently shake to loosen the tray or whatever is causing the problem, Is the disk off the spindle? Is the dvd/cd broken? Can you insert something to clear whatever is obstructing it? Have you tried to eject using the software, Go to computer, right click DVD/CD rom drive, click on eject? Has there been any damage to that area, bent..etc? You may have to force it open or remove the drive and try to open it.
Nov 19, 2012 | Lenovo Computers & Internet
Is there anyway to get data off a corrupt hard disc drive
Yes, usually the operating system is what corrupts and the data is typically intact. You will need the following.
  • Hiren Boot CD Here Download the ISO file and burn it to a CD from another computer
  • An External HDD
With your Hiren disc in the computer with a corrupt drive, boot to CD/DVD. You will get the Hiren Boot Menu, select boot to Mini XPThis will load a live Windows XP image. Plug in the external drive open up "My Computer" and navigate to your data on the C Drive. Copy it to the external drive.Now you can proceed to wipe out your corrupted install and copy your data back.
Oct 02, 2012 | Lenovo IdeaPad V570
Stuck disc in Macbook pro
CD and DVD drives have a manual release.On the door,look for a small hole.You an usually insert a paper clip in this hole to manually release the latch and open the door.
Jul 31, 2012 | Apple MacBook Pro Laptop Computer with...
Stuck on start up page for my lenovo 3000 n100, no other buttons work.
try removing all removable discs from the drives like flash discs,cd's,dvds and try restarting again
Dec 08, 2011 | Lenovo 3000 N100 0768 - Pentium Dual Core...
I hav lenovo y510...my cd drive is stuck..i inserted a cd and now its not comming out...i restarted it but but still not comming out..please help urgent
On most CD-DVD players you got a small hole to eject the disk when the rubber band is destroyed or not functioning.
Try to straighten a paper clip and insert it into the hole, about 2.5cm (1"), then it should release the tray so you can remove you CD.
Dec 07, 2008 | Lenovo IdeaPad Y510 Notebook
Disc tray wont open
The small hole allows you to mechanically release the tray. Unfortunately, with the system still running, the drive will fight you. Shutdown the system and then try using the pin in the hole to release the CD. That should resolve the removal problem. As far as the CD drive goes, it may be attempting to read the disc and failing. Sometimes it just does not give up. You may need to have the disc lens cleaned or just replace the drive.
Hope this helps.
Dan
Mar 31, 2008 | Dell Dimension 3000 PC Desktop
Lenovo A720 I7-3610qm 8gb 1tb Blu Ray Nvidia Gt630 2gb 27 Inch Frameless 10p Logo
35 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
